Everything posted by tlightne
Insteon Leak Sensor 2852-222 Programs
@haroldunger Think of it as one device that has three nodes. XX XX XX 1 Is the dry contact XX XX XX 2 iS The wet contact XX XX XX 4 is the Heartbeat XX XX XX is the Insteon address of the Leak sensor...
Procedure to add virtual Controller and Switch Nodes
@BHaus After the plugin is installed it will generate the nodes. The Admin Console is never used to configure plugins. In the plugin store after you select plugin there is almost always a more info button click on that and it will help you configure the plugin if it needs more information from you.
Creating a button to run Then statement in a program
@Techman Thank you.
Is it possible to create a button in UD Mobile to execute the then statement in a program. I am running the Harmony plugin and have several streaming services on my home screen of the TV. I can go to my programs in UD Mobile and run the then sttement but I would like to make is simple for my wife. Thank you all in advance for any assistance...
Kind of scary. Update to 14.3/IoX 6
@jkmcfadden I just did the upgrade this morning. I have Zwave locks, motion detectors, Fan controls, switches and a few others. I had no issues at all. All my Zwave functions as designed as well as my insteon. Like the looks of the new Eisy-ui cant wait for it to become full functioning. UD team did a great job with this upgrade.
Don’t upgrade to Alexa+ !!!
Harmony hub will work with Alexa+. I had to remove the Harmony skill and relink it to my Alexa account and it works without issues now.
Linking new insteon devices not working
Since the 994 is no longer supported by UD I believe you can no longer upgrade to the PRO.
eisy 6.0.0
Reading the complete article produces this information. – Using eisy? You’ll be notified of the upgrade availability for OS 14.3 and IoX 6.0.0 no later than 09/29/2025. Be sure to subscribe to our Product News and Announcements so you don’t miss it.
What a night
You do not need to do a restores of a backup. Go back and reread the previous posts. Techman has given you the information to restore the PLM.
The portal integration is down.
I am working just fine...
New Release v3.3.15 in Production Plugin Store
I am ok with not having position support at this time. I may upgrade to the Bond Pro at some time. I am good with having the stop command. My only concern is PG3 not reporting the correct version of the plugin. Thank you for all you do here...
@Goose66 I have the Bond Bridge BD-1000 not the Bond Pro..
@Goose66 Happy to report the stop command works with my Allen & Roth shades. Unfortunately these shade do not report status so I can not test any of that. After upgrading to 3.3.15 PG3X still shows the version as 3.2.14. and the blue bar showing an update is available is still present.
Stop command in Bond plugin
Solution @Goose66 Posted January 31, 2024 (edited) But yes, I will put a note in the plugin to add in the next release a "Stop" command for all blinds. The plugin will just ignore it for blinds that don't support stop, or maybe go ahead and send it and let the Bond bridge deal with the lack of support. Edited January 31, 2024 by Goose66 Still waiting any hope of this being added??? Thank you
Backup Procedure
With Chrome the next step is the save button. Which displays to the right of the filename.
Ambient Console not reporting all data
@bpwwer I do not see it in the debug log. Thank you...
@bpwwer Installed Ambient Console nodeserver and is not reporting Feels Like, Dew Point, and Lightning Strikes per hour. This data is displyed in the AmbientWeather nodeserver Main node. Can this be added to AmbientConsole? Love not having to get my data from the API. Thank you...
Cannot connect to eisy via Admin console
Do you save the ISY Finder file?? If you do you can just reload it when the Java app resets the IP and port number..
Z-Wave remote wake-up every three minutes
@walkman9999 I gave up on my remote because of the battery issue. I just use UD Mobile to operate Balli/Zwave shades independant of my Eisy.
Can’t link to UD Nest SDM Plugin
@Goose66 I am not worried about a refund you put up with a lot from people like me for the little you recover. I will try a second attempt in setting up a project in a couple of days after the hurricane has passed.. Thank you...
@Goose66 It has been a week is there any information from @Michel Kohanim on the status of the project???
@Goose66 Thank you for the update. I will wait for a response after you hear back from @Michel Kohanim...
@Goose66 Still getting the same error Can't Link to UD Nest SDM Plugin.. I went ahead and purchased the plugin and installed it in a different slot on my eisy and still get the same results..
@Goose66I installed the trial version 1.0.7 from the production store. When I authenticate it brings up the Google choose an account screen. I select the account to authenticate with and brings up a screen that states:Can’t link to UD Nest SDM Plugin Please contact Universal Devices if the issue persists Do I need to setup anyting additional with google? Thank you...
Ambient Weather API Parse Error
Ambient is having problems. I see them everyday several times a day...
