Mustang65
Everything posted by Mustang65
  1. Just received this if anyone is interested: As of June 1, 2023, the RadioRA 2 main repeater, all starter kits containing the RA2 main repeater, and all Grafik T RF controls for RadioRA 2 will be discontinued.
  2. A few years ago I decided to change out the original whole house surge protection with the Levinton unit below. I have not had any real issues since then. Since then, the highest AC voltage monitored on the incoming power lines was I believe 128volts, I am not sure, although I could dump the db. We do get a lot of power outages whether it is for a second or two to a few hours and I am thinking that when the power comes back on may be the issue. I believe I counted 30+ of those outages this year with most being just for a few seconds. For the short term I am going to install a few of my Zigbee outlet modules, but I am planning to hold out for the RA3. I just received an email from U-D that the Matter card for the Polisy is shipping now. Back to Amazon for Zigbee modules and a wall switch or two to keep the wife happy
  3. @MrBill The PLM versions are (1) 24135 (V2.3 or V2.4)Trashed years ago (2) 24135 V2.5 [471B] (replaced the capacitors with no luck) (1) 2413U V2.6 [452B] (died a few weeks ago) As far a as I am concerned, it is time to switch from Insteon to Lutron or something like that. Heck my X10 held up from the late 70's into the 2000's with little or no problems, still have a box full of X10 modules, remotes and other accessories in the shed, that all worked when I switched to Insteon years ago. I am not interested in WiFi or a Cloud based system. I will download the node server for something like the RA2 (since there is nothing available for RA3 yet) and start changing out the Insteon devices. Not sure, but I do not remember seeing any Remote Modules or AC Receptacles for the RA2 or RA3 so I may have to find a work around for those 6 items. Was looking at Zigbee (not sure of its future), but leaning more toward Lutron now.
  4. Over the years I have gone through 3 RJ45 versions of the PLM and now my last one which is a USB version, died. So, I believe it is time to move away from the Insteon product line to one of the other options. Now I just need to narrow down which to go with. Not a big fan of Z-Wave, looking more toward the ZigBee type. The hunt is on
  5. It has been a while and I was just looking at my Polisy "To--Do" list and came across the "Ecobee Forecast" info. I would like to access some of the forecast fields that are in the forecast but for the life of it I have no clue as to where to start. I am sure I will need to do something like Node red or something like that. The only thing that I have running using ecobee is the attic fan based on the difference between the outside temp and the attic temp. Hints
  6. Even the "Wired" magazine picked up on the Insteon debacle. https://www.wired.com/story/insteon-shutdown/?bxid=5e9da520f543e6336310d1de&cndid=60773587&esrc=profile-page&mbid=mbid%3DCRMWIR012019 &source=EDT_WIR_NEWSLETTER_0_DAILY_ZZ&utm_brand=wired&utm_campaign=aud-dev&utm_content=WIR_Daily_042122&utm_mailing=WIR_Daily_042122&utm_medium=email&utm_source=nl&utm_term=P6
  7. Don't forget to add any required subscriptions and links to them for portals, support.... ID's and passwords I have a "Work in Progress" that I call "Death Star" (no comments please) and the iCON sits in the middle of my desktop screen. My son is aware of it, but breaks out in a cold sweat when I mention it. i set up a VLAN to my UniFi network for him to access all this stuff. Wife not interested in any of it.... well only the lights coming on and off and the alarm system. Son will probably remove the bulk and install in his house. He spent a lot of time in IT so that is half the battle.
  8. I just tested my ISY on Polisy messaging response using myphonenumber@vtext.com (Verizon) and it took exactly 7 seconds, which is longer than normal. When I first started using this feature, I did create a gmail account for my ISY use.
  9. You may want to try to assign a Static IP address. Eventually when the Polisy connects to the WiFi, while it is connected, go into UniFi and give it a Static IP address. After that, even if it gets changed back to DHCP it will still use the UniFi Static assigned IP address.
  10. In UniFi, do you have "Hide WiFi Name" turned on. You may have to turn it off to set it up and then turn in back on after it is connected. Unfortunately, for some of my media center and IoT things, I have to leave IoT visible.
  11. I got the downward model and the upward the dongle is pointing toward the ceiling.
  12. I purchased the Zooz S2 stick 700 and ConBee 2 Zigbee USB stick for Polisy. I figure that the signal will get a few extra meters being in the upright position and not flat, so I purchased a package of 90 degree USB adapters. I checked them out on my laptop with a regular USB modem and it worked just fine. I probably could have just used USB extension cables to accomplish the same thing, but I decided to go with this method. It fits perfectly in Polisy with the USB cord for the PLM plugged in below it. I will need one additional USB port as I still have the ConBee 2 Zigbee USB - Gateway to plug in, which means I will need to find my USB to serial dB 9 adapter cable for the PLM. Would a powered USB HUB work with Polisy? That may be another option. A nice enhancement for Polisy2 would be a total of 4 USB connections, with the 2 additional connections spaced away from the existing 2 for wider dongles.
  13. I have just purchased my "LAST" PLM and it of course is a USB model. So, as I look at replacing all my Insteon devices one at a time I am now trying to research my replacement options, with one that I hope will be around for years to come and "NOT" require the purchase of a HUB for connectivity. Sitting on the side, I already have an Insteon hub and a Hubitat hub collecting dust. Maybe a little premature, but I have retired my ISY994I as the Zigbee module (For the Brultech Energy Monitor connection) stopped working and I do not have anymore PLM's for the ISY anyway. I was going to replace the capacitors on the mother board of the old ones, but I have decided against that at this point in time. So my Polisy is up and running using the USB-PLM. If the PLM goes, I will be dead in the water. Now the new dilemma, which to go with for future installations? Zwave (908MHz) or Zigbee (2.4GHz - crowded frequency). Granted Zigbee does have 915MHz but that I do not think is going to be used. If you look at the NEW MATTER Alliance, Zigbee is already part of it, but as of my last search Zwave has not joined the Matter Alliance. Is there going to be a Matter hub coming out in the future? Hope not! I have been leaning toward the Zigbee based product lines as the companies that produce Zwave products require the device mfr to license ($$) their product which makes the Zigbee products a little less expensive. I am not totally sure but I believe the Matter Alliance fee is $28K, not sure if that was to join or annual. Either way I need to wait for the Polisy Zwave and Zigbee update to be able to use either one, but I would say the Zwave will be first. I already havef the ConBee2 USB-Gateway and the Zooz S2 stick 700 for Zwave. Just have to wait now.
  14. Add a VPN connection to your home network, a lot safer anyway.
  15. You should have received an email about a month ago from Google indicating that they were going to disable the "low security" feature on any gmail accounts with email's that appeared to being generated by devices as a security move, "IF" they were not actively being used. Not sure as to what they define "Active" as. I checked and sure enough they disabled the low security feature on my gmail account that my Raspberry Pi uses to notify me with the newly assigned Public IP address, when the ISP changes my Public IP address. It has been running for the last 5 years and only sent me a new Public IP address about 5 times or so. I reset the gmail account back to "Low Security". Since they indicated that it would be on gmail accounts that are not that active, I decided that I would have the Pi send an email to my regular email account once every 24 hours. So at 11:15PM each night it generates an email to me. So far it works fine and I do not mind moving it with the "Junk" mail to the deleted folder each morning. Time will tell if this works. It also lets me know that the Pi is still doing its job.
  16. Dunedin, Howdeeee
  17. Miami, and the Sunrise time and Sunset time is/was correct.
  18. Since my PLM bit the dust and I received the USB version I am officially moving to ISY on Polisy. I shut down my ISY994i and decided that I am going to stick with the Polisy version of ISY. So, after getting through some speed bumps with the help of support I am moving on. I am setting up Polisy one device at a time. For me it was time to move on. I may have encountered my first device/program issue and it includes Sunrise/Sunset (Next Day) with a Motion Sensor II. Program 1: The basic program works perfectly WITHOUT Sunset/Sunrise. Program 2: Added Sunset/Sunrise and the Car Port light comes on, but does not turn off. Tried reversing the order of sunset/sunrise and motion sensor in the "IF", with no luck. Worked fine on the old ISY. PGM-1 Lights - Car Port - [ID 000D][Parent 0001] If 'Motion Sensor - Car Port' Status is On Then Set 'Lights - Car Port - On-Off Mo' On Wait 1 minute and 15 seconds Set 'Lights - Car Port - On-Off Mo' Off Else - No Actions - (To add one, press 'Action') PGM-2 Lights - Car Port - [ID 000D][Parent 0001] If 'Motion Sensor - Car Port' Status is On And From Sunset To Sunrise (next day) Then Set 'Lights - Car Port - On-Off Mo' On Wait 1 minute and 15 seconds Set 'Lights - Car Port - On-Off Mo' Off Else - No Actions - (To add one, press 'Action')
  19. Sounds like my REAL memory issues
  20. Come on..... build yourself a device that will take advantage of your sidewalk access, program it to use your Google 501Mbs and your done. Now there is a new product to be sold to the masses. A sidewalk JAMMER!
  21. About 2 months ago I read about this and it still is not displayed on my iPhone. I check each day. My son had it and deleted it. Strange!
  22. As a teen, I had a lot of proof reading classes
  23. What would be great is if the interface manufactures would design their modules/door locks.... with an interchangeable ZigBee chip module so that the end user could change the desired frequency between 2.4 and 915. The module firmware could determine which module is being used and adapt accordingly. This would be a nice security feature for door locks.
  24. Probably not in my lifetime:-(
  25. They also have units with the 915Mhz frequency, which are the ones that I use on some of my home DIY installs.
