Beginner Question
I have Mobilink Pro on my iphone5 with ios7. When I use my ip address I can connect fine. I forwarded my port to 33443 on my router and changed it in my ISY program. When I use myname.asuscomm.com:3343/admin it hangs up, it starts downloading then hangs. I can use https://myname.asuscomm.com:33443 on my computer and it works.
Hi chrsb,
Are you referring to the ISY's Admin Console? You might have better luck asking this question in a general ISY forum since this subforum is limited to MobiLinc specific questions.
Wes
Nope, I'm referring to setting up my mobilinc. Under lighting controller.
Hi chrsb,
Ah, ok. I misunderstood what you were trying to do. To set MobiLinc to talk to your ISY via HTTPS, just enter the IP or DNS in the HTTPS field. For example:
myname.asuscomm.com
For the HTTPS Port enter:
33443
Wes
That did it, great program btw! Started tinkering with the geofence stuff....
