While a then is "waiting" does If have to remain true?
edokid
I think the answer is yes based on the program I just wrote and noticed working.  If I have conditions like:
If Status Kitchen Light is On
And Status Laundry Light is On
And Status Bathroom Light is On
Then control Living Room Light On
Wait 30 minutes
control Living Room Light Off
Else no action
So basic example, I turn all 3 of those lights on the If becomes true, lights go on and we wait 30 minutes.  If I turn the Bathroom light off, am I correct in that the If is no longer true therefore the program stops?  And if I turn the bathroom light back on, If is now true and the 30 minutes starts over?  I'd assume that no actions after the "Wait 30 minutes" would occur once any of the If conditions are no longer true?  Thanks!
When the Conditions are no longer True the Wait is terminated and the Else clause runs.
Should the If Conditions become True again the Program is triggered and the Then clause runs fron the beginning.
Edited by LeeG
You are correct. Yes, to keep running true the conditions must remain true. Additionally, any reevaluation of conditions will cause 'Then' to start over.
So, dimming one of the lights (still on though, and still evaluating true) will cause the If to reevaluate and restart the timer.
Michael.
That's great thanks so much, stumbled upon that by accident and was wondering why it was happening but now it will be so much easier to code.  :)
One note, if any of the lights are dimmed the If is False as On means 100% On.   To cover  dimmed value the If would state
If Status 'xxxx' is not Off
rather than On.
If you always want the living room lights to turn off after 30 minutes then create a second program. Add run program 2 "then" after the line to turn the lights on, delete the rest.
Program two:
If. Blank
Then. Wait 30 minutes
Turn control living room lights off.
There are a lot of ways to set things up. I would typically create a scene for the living room lights and control the scene with the program. One reason to do this if you add any cross linked devices such as a Kpl with a button to control the living room lights, then you would add those to your scene. Your program would then turn on and off all scene members keeping them in synch.
Eric
Oh that program I just made up as an example to explain what I meant, I don't actually have any need to do that.  I was writing a program to delay setting off security alerts if the doors are opened when the house is in Away mode and it popped up.  Was easier to use the 3 lights example instead of mine :)
rather than On.
Forgot that little nugget! Thanks!
Based on the learnings in this thread, I need to rethink this program. It kills my sprinklers if enough rain falls during the 4 hour sprinkling cycle. On my way out, I reset both variables that I check in the 'if' to see if I need to do it at all...
        $Sprinkling_Now is 1
    And $Ok_to_Sprinkle is 0
        Stop program 'Sprinklers - Normal Run'
        Set 'Yard / Sprinklers / Master Valves / EZ1 Master' Off
        Set 'Yard / Sprinklers / Zone 01' Off
        Set 'Yard / Sprinklers / Master Valves / EZ2 Master' Off
        Set 'Yard / Sprinklers / Zone 08' Off
        $Partial_Sprinkler_Cycle_avoided += 1
        Send Notification to 'Default' content 'Sprinking Canceled In Flight'
        $Ok_to_Sprinkle  = 1
        $Sprinkling_Now  = 0
If enough rain falls during the 4 hour cycle, cancel the remainder
  • Do you think the last variable assignment step gets run, or does the previous step kill it?
  • If not, do you think moving those two steps to an inactive program, and calling it's 'then',  instead of resetting the variables will work?
        $Ok_to_Sprinkle  = 1
        $Sprinkling_Now  = 0
The first program can still re-initiate the second program's then will  redo everything.
IMHO this would be better. Use the "one and only one" technique.
Program 1
    trigger event
     Run Program 2
Program 2   (disabled)
    Disable Program 1
    do stuff.....
    Enable Program 1
Wait 30 minutes
Else no action
Here is a way some use to cancel the whole thing without leaving the light on.
   Set Living Room Light On
   Wait 30 minutes
   Run This_Program (else)
    Set Living Room Light Off
paulbates
There are no Wait or Repeat statements in that Program.  The Then clause will run all the statements.  The issue that started this topic was a Wait that allows the change in if Conditions to terminate the clause.   When no Wait or Repeat is used the clause runs all the statements.
This is not correct in all situations.  In your particular example, it is correct, because all the conditions are "status" conditions, which are triggers upon any change in status.  For a "wait" to terminate, the program must trigger, and not all conditions are triggers.
example
if
status light is 100%
and
$integervariablex is 1
something
wait
something else.
The above program DOES NOT abort the wait if the variable changes to something other than 1 because integer variables are not triggers.  Only if the status of the light changes does the program abort the wait.
Edited by apostolakisl
      378.5k
