Can you make a dimmer, beep by a program?
Beep is available from the option box to the right of the device (along with on, off, etc.)
Yes.
Doesn't work for me
        Control 'Back Porch Light' is switched On
        Set 'Outside Lights' 13 (Beep Duration)
Edited by Blackbird
My 2477D SwitchLinc Dimmer at hardware 7.6, firmware v.44 Beeps.
Can you post the Program as well as an Event Viewer trace at LEVEL 3 showing the Beep command.
aaahhh, ok what is the duration for?
Duration is how long something lasts.
