RainMachine - NodeLink v0.5.3 errors out with RainMachine configuration
Hi.  Thanks for building NodeLink, and I appreciate the time you spend on this.
The new version of NodeLink (v.0.5.3) errors out with the configuration file previously created for my RainMachine.  I can start NodeLink without a config file, but using the config.xml that worked with the previous version, or a newly created config file, NodeLink quits with the following command line errors:
brad$ 2016-06-20 09:04:56 - ISY NodeLink Server v0.5.3 started
2016-06-20 09:04:57 - ISY resolved to 192.168.0.30
2016-06-20 09:04:57 - Web config server started (http://192.168.0.2:8090)
Unhandled Exception:
System.ArgumentNullException: Value cannot be null.
Parameter name: source
  at System.Linq.Enumerable.Count[TSource] (IEnumerable`1 source) <0x2baa410 + 0x00203> in <filename unknown>:0
  at NodeLink.RainMachine.AddNode (Boolean fullWrite) <0x2baa118 + 0x00087> in <filename unknown>:0
  at NodeLink.RainMachine..ctor (System.String deviceName, System.String description) <0x2ba9ab0 + 0x0046f> in <filename unknown>:0
  at f.a (System.String A_0, System.String A_1, LinkDeviceTypes A_2) <0x2ba9618 + 0x0023f> in <filename unknown>:0
  at f.f () <0x2b25940 + 0x01327> in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.ArgumentNullException: Value cannot be null.
Additionally, when I add the RainMachine device to a new configuration, the device web page displays the following:
Error adding device - Value cannot be null. Parameter name: source
Below is a sample of a newly created config.xml that does not work:
<?xml version="1.0" encoding="UTF-8"?>
<sections>
  <section name="web config">
    <item key="port" value="8090" />
  </section>
  <section name="general options">
    <item key="auto update" value="True" />
  </section>
  <section name="isy admin">
    <item key="address" value="192.168.0.30" />
    <item key="login" value="me" />
    <item key="password" value="secret" />
    <item key="nodeprofilenumber" value="4" />
  </section>
  <section name="advanced rest">
    <item key="timeout" value="5" />
    <item key="retry delay" value="30" />
  </section>
  <section name="saveddevices">
    <item key="device0" value="" name="irrigator" nick="Irrigator" type="6" />
  </section>
</sections>
Again, thanks for your time.
Bumbershoot
My bad,
I'll cut a new version to fix this today.  Your old config file will work fine.
