text alerts no longer received
A little while ago I noticed that the alerts I have configured to go as text (Bell Canada xxx@txt.bell.ca) no longer got to my phone. The emails alerts work fine.
I double checked that Bell hadn't changed the domain, it hadn't. I can email/text to my phone direclty from my laptop.
I thought that perhaps Bell didn't like the domain the text was coming from, I'm using the USE DEFAULT SMTP method. I used to use my own SMTP, but a year or so ISY could no longer send with it, the config just stopped working, so I switched to default.
In any case, I set up a forwarder email on my own domain. Again, emailing to it directly from my laptop will send a text message to my cell phone, but the ISY alert message, after forwarding, will not reach my cell phone.
So I am wondering if Bell for some reason doesn't like the format of the text being sent.
Any thoughts on this?
* Orest
Hello Orest,
Is your controller a 99 or 994 Series Controller?
994, and running the latest firmware.
I would humbly suggest you use a personal SMTP address instead of the *Default* one being offered by UDI. As its been known to be over loaded, down, etc.
Most folks create a dedicated GMAIL account just for the ISY Series Controller. Doing so ensures this SMTP address has only one goal and that is to send alert messages.
I use the sms conversion link my mobile phone provider provides.
Some time back things changed and I now have to make domain names match and accounts match in the field parameters.
I always did before, using my own domain SMTP, and then ISY stopped sending with no parameters changes. I played around a bit with it, and couldn't get it reconfigured. Will give it another shot.
* Orest
* Orest
There are several threads on this back about a year ago. People blamed it on google but I never used google anything.
My ISP doesn't even accept a password on a tight input channel from me but it stopped working without a domain that matches the other field with a domain in it. I changed everything to match and it started working again.
AFAIC this was all ISY upgrades in security and nothing to do with ISPs or google.
I played around with the settings, and seemed to get it working again with my own domain SMTP. Interestingly, it works with text message alerts as well.
Will monitor it.
* Orest
Will monitor it.
* Orest
Excellent, keep the group updated on the final outcome . . .
* Orest
So about a month ago I was having the exact same issue with Bell Canada. Every time I called Bell half the people I talked to didn't even have a clue what I was talking about. I was even told that Bell didn't offer email to text service even though I had been using it for 5 years. So I requested a service ticket be created for the issue and about a week later I received a call from Bell Canada saying the issue was resolved and everything has worked fine since. All I was told was some settings had been changed on their end.
Sent from my SM-G920W8 using Tapatalk
  • 1 year later...
My test messages stopped working.  When I click on test the address the test message is received but the program alerts using the same address do not.  THoughts?  Everything had been working fine for years.  I am using default at the server
