April 21, 20179 yr I have a device that doesn't report its status without being queried. Its an iolinc. I tried "restore" device, and I get Could not open file [CONF/######.REC] Could n ot open config file to read [CONF/######.REC] Is there some easy way to address this by getting the .rec file from a backup file, or should I delete and re-add the device and its scenes, program steps, etc? Paul
April 21, 20179 yr I've had this happen a couple of times. Deleting the device from the ISY, air gapping it then re-adding it has resolved the problem. Fortunately, I haven't had this happen to devices that are used in a great number of scenes, programs, etc. If you are able to extract the needed file from the backup.zip, I don't understand how you would get the file back into the ISY's file system, other than with a system restore or through the "Configuration | Networking | Web Server" Tabs, which only exposes "/USER/WEB", not "/CONF", if that's even the correct path. Maybe there's a method using telnet (it looks like there's "List files/directories" command), or some REST command? I couldn't find it, and gave up.
April 21, 20179 yr Author Hi Bumbershoot Thanks, I was pretty sure that was the answer. Its up in the attic which is why I was hoping to avoid the re-add. Its still reasonably cool out, I can head up there this weekend and do it Thanks! Paul
April 21, 20179 yr Hi Paul, 1. Are you referring to the Sensor part of the IOLinc? 2. You already have the address for this device. You really do not have to go to the attic to relink it With kind regards, Michel
April 21, 20179 yr Author Hi Paul, 1. Are you referring to the Sensor part of the IOLinc? 2. You already have the address for this device. You really do not have to go to the attic to relink it With kind regards, Michel Hi Michel 1. No, the contact. It doesn't show off in the ISY even though it was commanded off by a scene and definitely turns off. The ISY won't catch up until queried. A "restore device" should have addressed I think, but won't work. 2. This is one of my older devices. I've had similar problems with it over the years a few times, typically going up and putting in linking mode is required to get it talking again. Its controlling the output from a 24vac transformer that's plugged in all the time. I'm eventually putting an outletlinc there so I'm not powering the transformer when its not actually in use, which is a majority of the time Could this potentially be the symptom of a failing SD card? Thanks. Paul
April 21, 20179 yr Hi Paul, Thanks. Yes, this could be a symptom of failing SD Card. If you have another SD Card handy: 1. Take a backup 2. Restore your LAST good backup 3. If you have the same issue, then it's probably not card (your backup has the same configuration) 4. If you don't have the same issue OR if it just completely fails, then there's a likelihood that it's your SD Card 5. To replace SD Card: - Unplug ISY - Replace the SD Card with a new one - Reinstall the firmware - Restore your backup With kind regards, Michel
April 22, 20179 yr Author Hey Michel Checking in. Fortunately I got the same results from a couple of week old restore, so I don't think its the card. The PLM is pretty close to 3 years, but its link table is still what's expected I eventually had to factory reset the iolinc to get it working, but I've had that exact problem with it in the past and prior to having the ISY. We had a major power incident a few weeks before the backup, I guessing whatever happened is traceable to that Thanks! Paul Hi Paul,Thanks. Yes, this could be a symptom of failing SD Card. If you have another SD Card handy:1. Take a backup2. Restore your LAST good backup3. If you have the same issue, then it's probably not card (your backup has the same configuration)4. If you don't have the same issue OR if it just completely fails, then there's a likelihood that it's your SD Card5. To replace SD Card:- Unplug ISY- Replace the SD Card with a new one- Reinstall the firmware- Restore your backupWith kind regards,Michel
April 22, 20179 yr You may want to look at this thread here. I found some differences in the different hardware revisions of the I/O Linc. Maybe a hardware issue adding to the problem you are seeing. http://forum.universal-devices.com/topic/21417-io-linc-hardware-differences-between-revisions/ Edited April 22, 20179 yr by Brian H
April 22, 20179 yr Author Thanks Brian. I should have caught this before I came back down from the attic. I have 1.8 and 1.9 in the garage. I'm not sure about the one in the attic, other than its older than the other 2.
July 10, 20187 yr I'm getting a few of these, never noticed them before but 5.0.13 gives me a popup every time I connect. How do I know which device they come from?
July 11, 20187 yr Jimbo, The filename is the hex value of the INSTEON address. With kind regards, Michel
July 11, 20187 yr Jimbo, The filename is the hex value of the INSTEON address. With kind regards, Michel Duh, that was too obvious to see! [emoji3] There are 3 different ones showing in my error log back to 3/10, do I have to delete and re-add them? Or should I try a new sdcard as mentioned?Sent from my Pixel 2 XL using Tapatalk
