More Motion Control Madness
Hi All,
I have much motion control going on in my house thanks to Rand. No one is going near the switches.
However my wife and daughter often sit at the dining room table doing homework, almost no motion.
What I want to do is have it so if they actually go over and press the dining room table light it will stay on for one hour or until they manually shut it off, with or without the dual motion sensors.
It seems to me I could tackle this by running a program when the dining scene is turned on and then before I shut it off via the motion sensors test if it has been more than one hour since that program triggered.
But how do I get a new event 1 hour after another event. Because the room might be off, I am not sure how to get another program to run one hour later.
Any thoughts would be appreciated. Is there a Programming Guide somewhere?
All the best,
Devon
I'm glad the program works for you Devon.
Hi All,
I almost put this in the program yesterday. You just need a condition to check the dining room switch:
            Status  'Kitchen Motion Sensor' is Off
        And Status  'Motion Sensor 2-Sensor' is Off
   And (
            Control 'Kitchen Motion Sensor' is not switched On
         Or Control 'Motion Sensor 2-Sensor' is not switched On
   And Status  'Dining Room' is Off
       Wait  1 minute
       Set Scene 'Kitchen Low' Off
You may need to make some changes to this:
       Status  'Dining Room' is not Off
   And Control 'Dining Room' is not switched On
       Wait  1 hour
       Set Scene 'Dining Room Low' Off
All the best,
Devon
Our best guide is the Wiki, the User_Guide and the How-To_Guide contain some step-by-step examples.
Rand
Hi DevonSprings,
Here's the link to our wiki wherein you'll find a lot more information on programming:
http://www.universal-devices.com/mwiki/ ... w-To_Guide
As far as your requirement, this is what I would do (I like folders):
Folder: DiningRoom-On:
  Control Dining-Room-Switch is Switched On
  Or Control Dining-Room-Switch is Switched FastOn
  And
  Control Dining-Room-Switch is not Switched Off
  Or Control Dining-Room-Switch is not Switched FastOff
In the DiningRoom-On Folder:
Program: motion-sensed
  Status motion-sensor is on
  Wait 1 Hour
  Set Dining-Room-Switch off
Now, a folder for when the dining room switch is not on
Folder: DiningRoom-Off
    Control Dining-Room-Switch is Switched Off
  Or Control Dining-Room-Switch is Switched FastOff
  Or Status Dining-Room-Switch is not On
Now, in the DiningRoom-Off Folder:
Program: no-motion
  Set Dining-Room-Switch On
  Set Dining-Room-Switch Off
You'll be using the motion sensor's timeout.
Hi All,
All the best,
Devon
