Aeotec Smart Switch 6 (Gen5)
I just purchased this as a hedge against failure of one of my Syncrolincs.  I can see status (on/off and power usage) on ISY change when controlling  the Aeotec device locally  but I can't control the Aetoec Device (simple on off )from ISY.  I added in first in non-secure and then in secure mode (including 20 second device reset )and got same results.  What am I missing?  I'm sure it's something simple. Probably a Z-wave parameter enabling remote control or I'm screwing up the secure mode add (it was 2 meters from ISY)...
I would exclude it and include it again. I have a few of these sensors and you don't have to change the parameters just to control it. For the energy stuff yes but control no.
Thanks, I tried several times -- no go.
I'm having the same problem. Aeotec support suggested there's an issue with the current ISY firmware with multi-sensor devices until the 5.x firmware is available.
Sorry, I just don't know enough about the transition path from 4.6.2 and the issues I'm likely to have to deal with in my case moving to 5.0. I'm still holding out for a released version before I switch.
