Google Home won't turn on light without %
Looks like I jinxed myself, I replied to another thread yesterday saying my Google Home's have been working great.
Now when I ask to turn on a light, it says the light is being turned on, but nothing happens. If I ask to turn on the same light to 100% it works. Everything that is defined as a switch works fine, it's only lights. Anyone else see this issue or know how to resolve?
Sent from my Pixel 2 XL using Tapatalk
So in the admin console all my devices show blank on level. I had query on restart disabled since installing the new zwave module, but the 3am query all should have fixed it. The program ran this morning so no idea why all the device levels are blank.
Michel,
But, as I said, running the Query All did nothing, I edited the program saved it and still it won't Run Then?  The Query doesn't happen, I have to run manually.
I open the AC and the device "On Level" is blank, so I right click the device and "On Level" goes to 100%.  Then GH will properly turn on the device.  So I manually ran Query on ISY and now all my "On Level"s and "Ramp Rates" are correct.
- Jim
But when I right click "ISY" and select "Query" it did update the On Level.  And that seems to be what my Query All program does, so I'm confused :)
Although, nothing is happening when I run then on my query all, so I'm even more confused.
Hi Jim,
Let me try again:
ISY Query != Program.QueryAll
ISY Query (right mouse click on node | Query), queries EVERYTHING including properties.
Program.QueryAll only queries the status (ST) and NO properties.
So, if you do not have Query at boot up enabled, all you get is ST and NO properties (on level).
      377.1k
