February 22, 20197 yr 10 hours ago, simplextech said: I asked about and would like this. How do I prevent the scene from turning Off from the door sensor when the door closes? It's not like a MS II with the on-only option. I'm hoping to learn something here, and I apologize if this was answered somewhere else, but I didn't find it. I'm curious if you tried what was suggested by user @kclenden in this thread and what the results were: Thanks for your time.
February 22, 20197 yr Author The newer door sensors can't be changed to send "On-Only". I'm going to toy with doing scene adjustments today and see if I can configure it so that when the sensor does send the Off command the switches will ignore it. I don't know if the scene adjustment will happen fast enough for this to be usable.
February 22, 20197 yr 6 minutes ago, simplextech said: I don't know if the scene adjustment will happen fast enough for this to be usable. That's what I was hoping to learn. I don't have any of these devices currently, but I do see an application for them if this actually works. Again, thanks for your time.
February 22, 20197 yr Author In early testing I tried to adjust the switches to ignore the commands like this. This did not work. SC.Adjust-Deck.Lights - [ID 0029][Parent 001A] If 'Living Room / Door Sensor / LR.door.sensor-Opened' is switched On Then In 'Scene.Deck.Lights-All' Set 'Deck / Switch / Flood Lights' To ignore In 'Scene.Deck.Lights-All' Set 'Deck / Switch / Front Light' To ignore Else - No Actions - (To add one, press 'Action') The second test I then changed it to modify the scene at the controller (door sensor). SC.Adjust-Deck.Lights - [ID 0029][Parent 001A] If 'Living Room / Door Sensor / LR.door.sensor-Opened' is switched On Then In 'Living Room / Door Sensor / LR.door.sensor-Opened' Set 'Deck / Switch / Flood Lights' To ignore In 'Living Room / Door Sensor / LR.door.sensor-Opened' Set 'Deck / Switch / Front Light' To ignore Else - No Actions - (To add one, press 'Action') On the first run this did work. However the amount of time it takes to perform the adjustment (20-30 seconds) will not work for my use case. Another item to note is that I duplicated this program but changed the 'ignore' back to a 'default' when the door sensor 'switched off'. Because of the time it takes for the re-linking to occur the programs collided and things went all wonky. I'll do some more testing and see if there's some combination that may work. I think for slow entry doors where they are held open for a period of time like garage doors this may work. However for a normal entry door I don't normally stand there with the door open long enough for the scene to be re-linked. Hopefully someone more versed with ISY has some ideas on making this functional.
February 22, 20197 yr Thanks for the investigative work. One more idea: I realize its wireless, but I wonder if the device to ignore is the sensor itself? Its tricky because updates can only be made during transmissions. But probably worth a try Paul
February 22, 20197 yr Author 3 minutes ago, paulbates said: Thanks for the investigative work. One more idea: I realize its wireless, but I wonder if the device to ignore is the sensor itself? Its tricky because updates can only be made during transmissions. But probably worth a try Paul I tried it both ways. The speed of the re-linking with a battery device stops it dead. FYI: I did sent a note to insteon support others should as well asking for an update for "On-Only" capability for open/close sensors. Edited February 22, 20197 yr by simplextech
