Send alert on communications error
Hello forum folks, I haven't quite found a definitive answer. I understand how to manually inspect the log for communications error, and I understand I see them in console, but is there a way to send email or push on comms errors once detected? I'm using java console and portal integration with all Insteon devices.Thanks in advance.
  • 1 month later...
So, the sole purpose of the "is Responding" condition is to catch devices that have not responded? Over what time period, or does the query reset the count?
* Orest
@oskrypuch,
The purpose is that if you send a direct (not scene) command to a device (i.e. on/off/query/dim/ etc.) and the device does respond, then this condition will be true. If not, this condition is false. In short, every time you one of those "cannot communicate" dialog boxes, this condition will be false.
