Insteon Motion Detector set up help
I have a insteon motion dector near my front door.
My current lights come on a sunset and stay on tell 10pm. What I would like to do is after 10pm if the motion detector goes on, the front lights turn on for 3 minutes then off.
So I have this program.
From 10:01:00PM
To Sunrise (next day)
And Status 'Front Yard Motion - Sensor' is On
Set 'Outside - Front Porch Lights' On
Wait 3 minutes
Set 'Outside - Front Porch Lights' Off
The problem is between sunset and 10pm if the motion dector goes on, the lights go off.
Any ideas?
I did something similar with a Togglelinc and 2420M motion detector. My front porch lights come on only at night for 10 minutes if motion is detected. I also provided for a Fast Off override in case I wanted to go outside and keep the lights off.
In another post on this forum, Michel gave me the key hint of using Enable/Disable on a program to ensure the Wait command isn't interrupted with new motion events.
The diagram and source code is posted here: http://www.handymanhowto.com/2009/05/31/automate-exterior-lights-with-an-insteon-wireless-motion-sensor/
I think you could readily adapt the code to suit your needs.
Bob
