Possible to reset Floor Plan Only?
I have two locations on my floor plan that I need to delete, but due to some sort of bug, I moved them too far to the right and now I am unable to select them or right click on them to delete them.
Any thoughts without doing a reset on the ISY?
Mike
The easiest way would be to Restore the ISY from a backup. There are some bugs in the Floorplan and we are researching a replacement/update.
I hope that doesn't inconvenience you terribly.
Rand
  • 1 month later...
Only problem with restoring from backup is that I have done so much since... I would rather be stuck with this issue than have to redo a lot of the programs, scenes, etc.
Hi mikestreb,
You have two options:
1. Removing all the floor plan objects
2. Telnet into your ISY, login, and then issue: RF /CONF/UDFLPL.XML
