12 hours ago, Michel Kohanim said:
All,
You don't have to download UDX; that's only for the geek batch. So, @larryllix, please do NOT do anything. And, if you have, please see below:
For Geek batch:
sudo service udx stop
sudo pkg delete udx
sudo pkg install udx
sudo service udx start
@MWareman, I responded to your ticket.
Thanks Michel. However no help for these polyglot errors. Something basic missing since v2.2.6
2020-1-3 20:05:04 [polyglot] info: Successful login by admin
2020-1-3 20:05:04 [polyglot] info: MQTTS: polyglot_frontend-Vz3PR authenticated successfully.
2020-1-3 20:05:04 [polyglot] info: MQTTS: Client Connected:
2020-1-3 20:05:04 [polyglot] info: MQTTP: Frontend Websockets interface Connected.
2020-1-3 20:05:25 [polyglot] error: MQTTS: connectionError: null Cannot parse protocolId
2020-1-3 20:06:25 [polyglot] error: MQTTS: connectionError: null Cannot parse protocolId
2020-1-3 20:07:25 [polyglot] error: MQTTS: connectionError: null Cannot parse protocolId
2020-1-3 20:07:53 [polyglot] info: Ecobee(1): Processing command: command
2020-1-3 20:07:53 [polyglot] info: Ecobee(1): n001_controller :: DOF sent sucessfully
2020-1-3 20:08:25 [polyglot] error: MQTTS: connectionError: null Cannot parse protocolId
14 hours ago, MWareman said:
@larryllix - Is your Polisy beeping every few seconds as well?  If so - your symptoms exactly match mine...
No. I finally got down to that location...no beeping.
Via ticket, Michel has found a parsing error in UDX that looks to be the likely cause of my issue. Hopefully, it’s the cause of others issues as well... and an update takes care of it.
  • Thanks 1
@larryllix Did you import a custom SSL cert into Polyglot?
I did - and just wanted to see if this was common between us..
Michael.
No cert. I am not using any https or SSL.
Sent using Tapatalk
On 10/31/2019 at 8:23 AM, larryllix said:
How are you editing these files? Is there a resident editor in the o/s somewhere?
I loaded NANO or what ever the normal editor is called. Works fine.
Thanks but now  the question is how to get nano into the system. The normal editor on original unix style systems is vi and most find it very clumsy.
6 minutes ago, Bumbershoot said:
sudo pkg install nano
Thanks. So nano has been included in later versions of polyglot then? It wasn't in the original geek batch version.
I loaded it a while back.
15 minutes ago, Michel Kohanim said:
I love vi so much that I have its plugin in my Eclipse and VSCode! And, I am so used to it that, when I do email or the forum, I keep using vi keys and then sigh!
I have the vi plugin for PyCharm :)
vi is to real text editors as a bootloader is to operating systems. :-)  That said, I'd agree that everyone should know at least the bare basics of VI.
  • Like 2
Hello everyone,
The issue is that for some reason (either a GUI bug or user error), all network ports are disabled. Polisy should NOT allow all network interfaces to be disabled. This is something we are working on. In the meantime, we do have an update for udx which will make things a little more stable. If you can access Polisy via a browser, please click on System | Update Polisy and then reboot.
If you have ssh access:
sudo pkg update
sudo pkg upgrade
@Michel Kohanim I know things are hectic now after the Polisy release, but at some point can we start having a changelog for Polisy like we do for ISY. Alway nice to know what's being fixed and when new features are rolled out.
Mike
@Michel Kohanim has found and fixed the issue I was having with udx - and my beeping has stopped and I can now access Polisy's settings screen.
In my case - I had a purchased SSL certificate - it's private key is 4096 bits. The udx binary was not expecting that - causing it to throw an error on start. 4096 bit keys are now being properly accommodated.  This is resolved in udx version v1.0.26_8.
Thank you!
Michael.
  • Like 1
      37.8k
      377.6k
