[OpenADR] Not Connect VEN (ISY) to VTN
PoPo
@Michel Kohanim
Thank you for information
I have installed as follows
1. I installed VTN ((https://volttron.readthedocs.io/en/develop/core_services/openadr/VtnServerGuide.html)  in Ubuntu using VMWare. Set up a network adapter bridged for external connection using IP 192.168.1.102:8888/vtn.
And create user as followsVTN-1.thumb.jpg.0e31375462d6cb71e9c518b3bfe42322.jpg
2. I bought the OpenADR Certificate: https://www.universal-devices.com/product/openadr-production-certificate/
And install in VEN (ISY994i ZW + IR PRO) and install OpenADR according to https://wiki.universal-devices.com/index.php?title=Main_Page#Installing_New_OpenADR_Client_Certificate completed
3. Setup to be able to connect to VTN as follows
But cannot connect as in the picture
4. I tried to set up Auto Registration in OpenADR Settings of VEN. I found that VEN has tried to connect to VTN.
But there is an error as in the picture
Not Found: / vtn / EiRegisterParty
11/11/2019 09:27:26 AM Not Found: / vtn / EiRegisterParty
[11 / Nov / 2019 09:27:26] "POST / vtn / EiRegisterParty HTTP / 1.1" 404 7133
Please help me
@Michel Kohanim
Thanks for the infomation
I would like advice on VTN about which ones can connect to VEN (ISY994i ZW + IR PRO), but
I installed VTN (EPRI) because in wiki universal-devices (https://wiki.universal-devices.com/index.php?title=Main_Page#OpenADR) there is the installation procedure. But cannot be installed because http://torquebox.org/release/org/torquebox/torquebox-dist/3.0.2 /torquebox-dist-3.0.2 -bin.zip The link has an error preventing download. By following this document on page 14-2.
OpenADR.VTN.Software.Manual.pdf
Please help me
I would like you to recommend another VTN that can work perfectly with VEN of ISY994i ZW + IR PRO
Best Regards
@PoPo,
We have our own instance of EPRI (Nebland) VTN which works perfectly well with ISY. Honeywell, IPKeys, Fujitsu, AutoGrid, and Siemens have all be tried as well and they all work pretty well.
What is your application? If you wish, you can send a direct email to support@Universal-devices.com.
5 minutes ago, Michel Kohanim said:
@PoPo,
No, I mean you should try the following URL with your ISY:
http://192.168.1.102:8000/vtn/OpenADR2/Simple/2.0b
@Michel Kohanim
Oh, I'm sorry for misunderstanding I will try to edit the link according to you.
3 minutes ago, Michel Kohanim said:
@PoPo,
I will send the desired application. Go to that email.
Best Regards
