Mounting Polisy
System Management Controller?
Southwestern Michigan College?
Santa Monica College?
SMC Corporation (Pneumatics)?
Here's what I ordered to mount Polisy in my Leviton can:
https://www.pcengines.ch/brk1d.htm
The plan is to attach them to something like this:
https://www.leviton.com/en/products/47612-fsb
or this:
https://www.leviton.com/en/products/47612-1sb
I've not had time to do it yet, so I don't know all the gotchas, but it should work.
It's really quite annoying that Polisy doesn't have slots in the case for sliding it on top of screw heads like the ISY does, would have made mounting a lot easier, cheaper, and wouldn't take up as much room. I'd have just mounted it to one of the half-width universal security plates:
https://www.leviton.com/en/products/47612-hsb
the same as I did with my ISY. If you're not opposed to using velcro, you can just use the adhesive velcro strips that come with the plate and call it a day.
Be sure to double check dimensions, I was doing some digging this morning and even the full size security plate may not be tall enough. You may have to go with the security brackets to make it work.
Sent from my SM-N9500 using Tapatalk
