Determine unknown device address
I have a Dimmer Micro Module that has an unreadable device address label.  The module has not been added to the ISY.
Is there a technique to query the address of a uninstalled device?
You can do the Start Linking method. That will add it to the ISY setup with its six digit ID.
Another way is to Set Button manually link it to a module already in ISY. Then Tools, Diagnostics, Show Device Link Table on the module you manually add the unknown modules address. There should be an extra  link listed that the ISY setup does not know about.
