i messed something up now polisy is useless
Hi,
for one reason or another. I decided to factory reset my polisy pro (hold multiuse button until all 3 LEDs are blinking, about 40 seconds.) but that did nothing, my installed nodes are still there which are also useless. I have since removed them and one remains with a "No Details Available" button that I cannot do anything with. I've clicked all the restarts possible in the dashboard - restart polygot, reboot isy, update polisy, reboot polisy.
I no longer see the "Node Servers" button on my ISY admin console either.
What are steps to "factory rest" a polisy, like actually factory reset as if I just got it new, with all the right stuff installed? I'm afraid to remove the files on the server because I wouldn't know which git packages I would need to install to get everything working again? Just follow these instructions? polyglot-v2/README.md at master · UniversalDevicesInc/polyglot-v2 (github.com)
Thanks for any insight, Patryk
Edited by patryk.szady
11 hours ago, patryk.szady said:
Hi,
The instructions are in the wiki, here is what it says about factory resetting:
Factory Reset
Press and hold the button till all LEDs start blinking then release. This action resets the credentials, removes all configurations from Polyglot/Polisy, and resets networking.
The link for the full guide is here:
https://wiki.universal-devices.com/index.php?title=Polisy:User_Guide
I would suggest you read through it before doing anything. There is a note that says if the factory reset doesn't work you need to update Polisy.
Edited by DennisC
Added note.
@DennisC Thanks, that's the first thing I did but it didn't do what the name suggests. Any corrupt files on the server didn't get deleted and I think those steps don't delete and reinstall all the required git depositories.
From my original post:
I'd also suggest that you open a ticket and get some direct one on one help from support@universal-devices.com  They'll get you back on track...
Thanks @Javi, I'll give those steps a try later, I'm fairly familiar with ssh and have access to the server on my PC. That link might be the solution. Now that I think about it my problems started to appear when I did an automatic polisy update in the dashboard, I think I saw a few errors in the log and ignored them.
@MrBill thanks! I'll reach out to @Michel Kohanim if the solution above doesn't work.
Thanks everybody!
A successful update fixed about all my problems.
1. Your are already on 12.2 (uname -a) //To make sure your're on 12.2 only i believe, uname -a returns a version number only//
2. Make sure udx is on 2.1.2_1 (pkg info udx). If not, upgrade udx (sudo pkg upgrade udx)
3. Run
cat /usr/local/etc/udx.d/static/update13.sh | sudo bash
This will upgrade you to 13, upgrade Python to 3.8, and then goes through all your node servers and upgrades them to use Python 3.8.
