AT&T to end email-to-text ×
Merging my Forum and Portal Accounts
PLCGuy
Hi
I’ve had this forum account for about a decade and would love to keep it. However not realizing that the portal and the forum were going to be connected someday, I created a portal account with a different user name a few years ago. Now I have two portal accounts, one unused account with my portal short name and this one with my forum name.
Is there a way that I can merge them without losing my forum history? Or associate this old forum name with my Portal access?
Regards
Eric (PLCGuy)
If you have two ISY Portal accounts with two different names then the forum cannot be related to one of them.
I have a forum name that is not related to my ISY Portal, ISY, or polisy.
I believe Forum Login was moved to ISY portal for better security.  I don't think this can be changed manually, try opening a ticket.
  • Like 1
It's a simple process...
  • Click on your name in the top right of the forums.
  • Click "Account Settings"
  • Select "ISY Portal"
  • Then "Sign in with ISY Portal"
  • Use the account you're actively using for ISY Portal.
It's been a while since I did it so I'm not entirely sure what happens with the display name on here, but you can then change your display name if it alters it during this process.
In the ISY Portal settings it offers this:
So you'll still have your Forum account (with history), but can now sign in to the forums with either the forum account or the ISY Portal information. My settings allow me to use the same email for both, but I have different "user names" so I have not checked the option to update my display name here when the ISY user name changes.
Should be a simple and easy process.
