zooz scene controller help
I recently installed the Zooz Zen32 scene controller in my house. I would like to use more of these because i like the ability to decouple the control from the main button and the ability to control multiple scenes from the controller but i cannot seem to figure out how to program it.  I am a beginner at ISY but I can't seem to figure this controller out. I have the on/off of the main switch/relay down, it works fine but the scene control buttons have issues. I can get them to turn on scenes but not off (in both scenes and programs). It seems there is no off event that ISY recognizes. i can make it where i set 2 buttons to control a scene (one on, one off) but that leads to needing double presses on the buttons witch can get annoying and that uses 2 buttons where 1 should work.
Please help.
Again I am not very experienced and maybe missing something simple or just going about this the completely wrong way ?‍♂️
Thanks in advance,
Robert
I have played a little more with this and have gotten it to work... kind of...
I wrote two programs to control it but the lights on the keypad would not always be guaranteed to be in sync....
Test bulb on - [ID 0003][Parent 0004]
        'ZW 019 Binary Switch / ZW 019 Scene Button 2' is switched On
    And 'Ilumin test bulb' Status is Off
        Set 'Ilumin test bulb' Fast On
Test bulb off - [ID 0007][Parent 0004]
    And 'Ilumin test bulb' Status is not Off
        Set 'Ilumin test bulb' Fast Off
I doubt this is the best way to do this
47 minutes ago, Michel Kohanim said:
@roberthleeii,
If they are indeed scene controller:
1. Create a scene
2. Drag and drop the controller as Controller
3. Drap and drop others as Responders
Click on the Controller within the newly created scene and that choose Z-Wave Scene or Z-Wave association for each responder.
This does not seem to work.
I have figured out how to get it basically working with the programming and changing the parameters of the LEDs within the program ?‍♂️
I guess this is good enough.
I am not sure to understand and generally I am still struggling with Zwave scenes.
On 2/6/2022 at 3:44 PM, Michel Kohanim said:
@roberthleeii,
1. Create a scene
6 hours ago, Michel Kohanim said:
@roberthleeii,
Do you see Scene or Association in the drop down?
I am sorry but I don't see that. Tried looking all over in the scene and the controller in the scene and was not able to find a dropdown with that text.   The scene will turn on the z-wave light I am using and the scene light on the controller will show the scene is active, but when press the scene button again the light on the controller shows the scene going off but the light stays on.  this is the first z-wave controller I have really played with and have only used some insteon ones before and it does not seem to work the same.
On the other hand i really have liked playing with the programing aspect of ISY
18 minutes ago, asbril said:
there is some real power with the programming. I am now thinking about buying a POLISY now to get more devices in my control network but that is a big expense ?‍♂️
Polisy and the nodeserver are a new and very nice experience. Worth the money.
2 hours ago, Michel Kohanim said:
@roberthleeii,
Thank you. If you are on 5.3.4, and if Scene or Association do not show up in the dropdown (when you drag/drop them into the scene and click on each), then those devices are not capable of supporting Z-Wave scenes.
Hi Michel
I must be overlooking something, but I am lost with this.  The particular switches that I want to use as controller and responders have each  scene nodes ( 1 and 2). After adding these to the scene that I created and click on these nodes, then nothing shows, other than the choice of Command, Default, Ignore.
1 minute ago, asbril said:
Hi Michel
What do you get when you click command
  • All ON
  • All OFF
  • ON
  • OFF
  • Query
  • Set Configuration
  • Write Changes
2 minutes ago, asbril said:
  • All ON
  • All OFF
  • ON
  • OFF
  • Query
  • Set Configuration
  • Write Changes
When I set both Controller and Responders to Command - ON, then that works, but when switching the Controller OFF the Responders do not go OFF
3 minutes ago, lilyoyo1 said:
Click "on" then hit update for the scene
What does the event viewer show as being sent when you turn off
this is the log for my scene that turns the light on but not off:
Wed 02/09/2022 05:19:58 PM : [D2D EVENT   ] Event [ZW019_201N004] [DON] [0] uom=0 prec=-1
Wed 02/09/2022 05:19:58 PM : [ZW019_201N004]      DON   0
Wed 02/09/2022 05:19:58 PM : [D2D EVENT   ] Event [ZW019_1] [DON] [100] uom=78 prec=0
Wed 02/09/2022 05:19:58 PM : [     ZW019_1]      DON 100 (uom=78 prec=0)
Wed 02/09/2022 05:20:01 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:20:02 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:20:02 PM : [D2D EVENT   ] Event [ZW018_1] [ST] [100] uom=51 prec=0
Wed 02/09/2022 05:20:02 PM : [     ZW018_1]       ST 100 (uom=51 prec=0)
Wed 02/09/2022 05:20:02 PM : [D2D-CMP 0007] STS [ZW018_1] ST op=6 Event(val=100 uom=51 prec=0) != Condition(val=0 uom=51 prec=0) --> true
Wed 02/09/2022 05:20:02 PM : [D2D-CMP 0003] STS [ZW018_1] ST op=1 Event(val=100 uom=51 prec=0) is Condition(val=0 uom=51 prec=0) --> false
Wed 02/09/2022 05:20:03 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:20:04 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:20:05 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:20:12 PM : [D2D EVENT   ] Event [ZW019_201N004] [DON] [0] uom=0 prec=-1
Wed 02/09/2022 05:20:12 PM : [ZW019_201N004]      DON   0
Wed 02/09/2022 05:20:13 PM : [D2D EVENT   ] Event [ZW019_1] [ST] [0] uom=78 prec=0
Wed 02/09/2022 05:20:13 PM : [     ZW019_1]       ST   0 (uom=78 prec=0)
Wed 02/09/2022 05:20:13 PM : [D2D EVENT   ] Event [ZW019_1] [DOF] [0] uom=78 prec=0
Wed 02/09/2022 05:20:13 PM : [     ZW019_1]      DOF   0 (uom=78 prec=0)
Wed 02/09/2022 05:20:16 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:20:17 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:20:18 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:20:19 PM : [ZWAVE-TX        ] ...
i am new to this so i have no idea what i am looking at
here it is again with different settings on the event viewer:
Wed 02/09/2022 05:22:10 PM : [ZWAVE-RX ZW019_1] [5B/03] Central Scene Notify key=4 act=0 (Press) seq=55 slow=T ACK,AUTO,EXPLORE From=0x13
Wed 02/09/2022 05:22:10 PM : [D2D EVENT   ] Event [ZW019_201N004] [DON] [0] uom=0 prec=-1
Wed 02/09/2022 05:22:10 PM : [ZW019_201N004]      DON   0
Wed 02/09/2022 05:22:10 PM : [ZWAVE-RX ZW019_1] [20/01] Basic Set val=0xFF ACK,AUTO,EXPLORE From=0x13
Wed 02/09/2022 05:22:10 PM : [ZWAVE-TE        ] [26/01] Dimmer Switch Set val=0xFF rr=0xFF ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:10 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:10 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[0B0282C9CD63EE59] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:10 PM : [D2D EVENT   ] Event [ZW019_1] [ST] [100] uom=78 prec=0
Wed 02/09/2022 05:22:10 PM : [     ZW019_1]       ST 100 (uom=78 prec=0)
Wed 02/09/2022 05:22:10 PM : [D2D EVENT   ] Event [ZW019_1] [DON] [100] uom=78 prec=0
Wed 02/09/2022 05:22:10 PM : [     ZW019_1]      DON 100 (uom=78 prec=0)
Wed 02/09/2022 05:22:13 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [00] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:13 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:13 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[0140974BA398095F] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:13 PM : [ZWAVE-RX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:13 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:22:13 PM : [ZWAVE-RD        ] [010B001312043304000025000F]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:14 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [01] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:14 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:14 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[6AC2595D67001974] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:14 PM : [ZWAVE-RX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:14 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:22:14 PM : [ZWAVE-RD        ] [010B0013120433040100250012]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:14 PM : [ZWAVE-RD        ] [010B0013120433040100250013]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:14 PM : [ZWAVE-RD        ] [010A00131203260363250067]              REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:14 PM : [D2D EVENT   ] Event [ZW018_1] [ST] [100] uom=51 prec=0
Wed 02/09/2022 05:22:14 PM : [     ZW018_1]       ST 100 (uom=51 prec=0)
Wed 02/09/2022 05:22:14 PM : [D2D-CMP 0007] STS [ZW018_1] ST op=6 Event(val=100 uom=51 prec=0) != Condition(val=0 uom=51 prec=0) --> true
Wed 02/09/2022 05:22:14 PM : [D2D-CMP 0003] STS [ZW018_1] ST op=1 Event(val=100 uom=51 prec=0) is Condition(val=0 uom=51 prec=0) --> false
Wed 02/09/2022 05:22:15 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:15 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:15 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[CA8AC516CBEA0A65] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:15 PM : [ZWAVE-RX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:15 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:22:15 PM : [ZWAVE-RD        ] [010B0013120433040200250016]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:15 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [03] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:15 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[52DB4E249F4AEAE2] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:16 PM : [ZWAVE-RD        ] [010B001312043304030025001B]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:16 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [04] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:16 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:16 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[5E770BD204107CDD] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:16 PM : [ZWAVE-RX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:16 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:22:16 PM : [ZWAVE-RD        ] [010B00131204330404FF2500E7]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:16 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:16 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[6E14F0238131D1C7] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:17 PM : [ZWAVE-RX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:17 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:22:17 PM : [ZWAVE-RD        ] [010A0013120326036325007A]              REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:20 PM : [ZWAVE-RX ZW019_1] [5B/03] Central Scene Notify key=4 act=0 (Press) seq=56 slow=T ACK,AUTO,EXPLORE From=0x13
Wed 02/09/2022 05:22:20 PM : [D2D EVENT   ] Event [ZW019_201N004] [DON] [0] uom=0 prec=-1
Wed 02/09/2022 05:22:20 PM : [ZW019_201N004]      DON   0
Wed 02/09/2022 05:22:20 PM : [ZWAVE-RX ZW019_1] [20/01] Basic Set val=0x00 ACK,AUTO,EXPLORE From=0x13
Wed 02/09/2022 05:22:20 PM : [ZWAVE-TE        ] [26/01] Dimmer Switch Set val=0xFF rr=0xFF ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:20 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:20 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[988423DD78482FB0] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:20 PM : [D2D EVENT   ] Event [ZW019_1] [ST] [0] uom=78 prec=0
Wed 02/09/2022 05:22:20 PM : [     ZW019_1]       ST   0 (uom=78 prec=0)
Wed 02/09/2022 05:22:20 PM : [D2D EVENT   ] Event [ZW019_1] [DOF] [0] uom=78 prec=0
Wed 02/09/2022 05:22:20 PM : [     ZW019_1]      DOF   0 (uom=78 prec=0)
Wed 02/09/2022 05:22:23 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [00] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:23 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:23 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[3A10F2C6D2550EFB] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:24 PM : [ZWAVE-RX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:24 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:22:24 PM : [ZWAVE-RD        ] [010B0013120433040000250017]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:24 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [01] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:24 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:24 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[1607BF3687074BB4] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:24 PM : [ZWAVE-RD        ] [010B001312043304010025001A]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:25 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:25 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:25 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[39B24DA1F0D50F9C] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:25 PM : [ZWAVE-RX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:25 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:22:25 PM : [ZWAVE-RD        ] [010B001312043304020025001D]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:25 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [03] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:25 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[B0BB15F5C2EADC07] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:26 PM : [ZWAVE-RD        ] [010B001312043304030025000B]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:26 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [04] ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:26 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:26 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[5FEA933E0591C783] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:26 PM : [ZWAVE-RX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:26 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:22:26 PM : [ZWAVE-RD        ] [010B00131204330404FF2500F7]            REQ ZW_SEND_DATA
Wed 02/09/2022 05:22:27 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:27 PM : [ZWAVE-TX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x12
Wed 02/09/2022 05:22:27 PM : [ZWAVE-RX ZW018_1] [98/80] Security Nonce Report - nonce=[B8378F8E9C4600A2] ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:27 PM : [ZWAVE-RX ZW018_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x12
Wed 02/09/2022 05:22:27 PM : [ZWAVE-TX        ] ...
Wed 02/09/2022 05:22:27 PM : [ZWAVE-RD        ] [010A00131203260363250067]              REQ ZW_SEND_DATA
Controller =  ZW 101
Responders =  ZW 028 and ZW 013
Wed 02/09/2022 08:25:15 PM : [     ZW101_1]       ST 100 (uom=78 prec=0)
Wed 02/09/2022 08:25:15 PM : [     ZW013_1]       ST 100 (uom=78 prec=0)
Wed 02/09/2022 08:25:15 PM : [     ZW028_1]       ST 100 (uom=78 prec=0)
Wed 02/09/2022 08:25:16 PM : [ZW101_201N001]      DON   0
Wed 02/09/2022 08:25:21 PM : [ZW101_201N002]      DON   0
Wed 02/09/2022 08:25:21 PM : [     ZW101_1]       ST   0 (uom=78 prec=0)
Just now, asbril said:
Controller =  ZW 101
Now I use Scene to switch these ON and a Program to switch OFF, but I'd like to understand to do ON & OFF with Scene
I am fooling around again with a very old Monster IWC600 z-wave scene controller on my Vera, and the behavior is similar.  It has 4 buttons, and they have mutually exclusively lit LEDs.  The idea is that there is always a scene selected.  Maybe that's what they were going for with the Zen32.  To turn something off with the Monster controller you have to make a direct association with the button.  If you do, the second press will turn off the associated light.  The second press of any button also reports a button 0 push for each of the 4 buttons meaning, I guess, that the scene hasn't changed.  Or something.
-Tom
-Tom
The zooz zen32 has leds (configurable so behavior be changed) for each of the 5 buttons and they are completely independent and only affected by the button is on.
I feel like the zen32 only sends the on command but then I see that the led is kept in sync with on/off status....
I haven't set this switch up in Polisy yet but I have used it in Homeseer and it pointed out to me the baffling and unnecessary complexity of the Z-Wave protocol. It is pretty basic and the expectation is that it would provide 11 devices to work with; 5 buttons, 5 LEDs, and 1 relay, and that there would be a register that tracks the status of each and allows for control of them. Instead only the relay is available for status reporting and direct association. For some reason not adequately explained, the 4 small buttons just change the value of a single Central Scene register and do not maintain any status of their own. The LEDs toggle when the associated button is pressed but that state is not exposed any place so you have to track status in your controller logic and use parameter commands to force the LEDs to reflect the actual state of the scene, load or whatever. I have never found any documentation to explain why Z-Wave is set up this way but it makes it a lot more complicated than it should be both for end users and for anyone trying to design a home automation controller with an easy to use rules engine. I know this doesn't help Robert in setting it up in Polisy but if in the process of resolving his situation somebody could explain why Z-Wave is designed this way in the first place it might provide some perspective on how come things that are simple with Insteon can become so challenging when translated to Z-Wave.
Edited by upstatemike
