Trouble finding AIR after move from PG2 to PG3
tmorse305
Hi @bpwwer, Sorry if you have watched the edits on this message.  There were additional configuration instructions that came up on the NS after the station ID is entered which I didn't see initially.  There still seems to be a problem, it's not happy with the Station ID.  Do I have the configuration entered correctly?
Thank you.
Errors:
2022-02-20 16:04:23,984 Thread-1   udi_interface      ERROR    weatherflow:query_station: Station Query failed for Station ID: [Errno Expecting value] <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head><title>GlassFish Server Open Source Edition  4.1.2  - Error report</title><style type="text/css"><!--H1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;} H2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;} H3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;} BODY {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} B {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;} P {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A {color : black;}HR {color : #525D76;}--></style> </head><body><h1>HTTP Status 500 - Internal Server Error</h1><hr/><p><b>type</b> Exception report</p><p><b>message</b>Internal Server Error</p><p><b>description</b>The server encountered an internal error that prevented it from fulfilling this request.</p><p><b>exception</b> <pre>javax.servlet.ServletException: java.lang.NullPointerException</pre></p><p><b>root cause</b> <pre>java.lang.NullPointerException</pre></p><p><b>note</b> <u>The full stack traces of the exception and its root causes are available in the GlassFish Server Open Source Edition  4.1.2  logs.</u></p><hr/><h3>GlassFish Server Open Source Edition  4.1.2 </h3></body></html>
2022-02-20 16:04:24,226 Thread-1   udi_interface      ERROR    weatherflow:query_station: Station Query failed for key: [Errno Expecting value] <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head><title>GlassFish Server Open Source Edition  4.1.2  - Error report</title><style type="text/css"><!--H1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;} H2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;} H3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;} BODY {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} B {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;} P {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A {color : black;}HR {color : #525D76;}--></style> </head><body><h1>HTTP Status 500 - Internal Server Error</h1><hr/><p><b>type</b> Exception report</p><p><b>message</b>Internal Server Error</p><p><b>description</b>The server encountered an internal error that prevented it from fulfilling this request.</p><p><b>exception</b> <pre>javax.servlet.ServletException: java.lang.NullPointerException</pre></p><p><b>root cause</b> <pre>java.lang.NullPointerException</pre></p><p><b>note</b> <u>The full stack traces of the exception and its root causes are available in the GlassFish Server Open Source Edition  4.1.2  logs.</u></p><hr/><h3>GlassFish Server Open Source Edition  4.1.2 </h3></body></html>
Edited by tmorse305
@JimboAutomates Hey Jim, Made the conversion tonight from PG2  to PG3.
Got it running. Parameter instructions could be improved a bit, or examples given. Had to play a while to get it.But am not getting forecast info. Not sure what I should be putting for the station info for the forecast. I am using a Tempest on site for other data.  Any suggestions? Thanks. 1155679065_ScreenShot2022-02-20at8_52_23PM.thumb.jpg.379a5d7088c9d2072621df3e4b003309.jpg
UPDATE: The forecast data has now populated. Just took a while. However Forecast conditions for Forecast 1 &2 are both "unknown" . Not sure if this is an error or just an update issue.
Cheers and thanks again for all the hard work you are doing on this stuff!!
@bpwwer Thanks Bob!  Great NS.  One very minor and not important note: on the UD Mobile app, the “Conditions” are reporting as a number vs text. Not really important but just wanted you to know!
All values for every node are currently numbers.  It's up to the UI to convert those to text based on the mapping provided by the node server.   It's possible that there's something in the mapping that is causing UD mobile to fail, but I believe the admin console isn't having problems with it.
If conditions are showing up as unknown, then WeatherFlow probably added some new ones that I don't know about.  If they add something new, the mapping has to be updated so that the node server knows what to do with it.
Yes, it takes a while for the forecasts to populate.  There's something wrong in the node server and it ends up waiting for one LongPoll interval before it makes the query to WeatherFlow for that info.
I think you have to restart ISY then resync UDMobile
  • Like 3
Something is wrong with the station ID.    When the node server contacts the WeatherFlow server to get the information about the station, the WeatherFlow server is responding with:
Quote
That is coming from WeatherFlow, not the node server.
Thanks @bpwwer, I reinstalled Weatherflow on PG2 and it comes online with the same station ID (1866) so it seems to be something related to the PG3 version or perhaps the new token requirement.  I double checked the token to make sure it is correct.
It works fine for me even with your station ID and the error is coming from WeatherFlow.  So it has to be your configuration.
The only error in the node server is because it's not getting valid data from the WeatherFlow server.
It appears that value 14 for GV13 is creating the UNKNOWN conditions result. I have it in two forecasts.
Thanks Jim. worked. Rebooted ISY, resync UDMobile, now conditions show up as names not numbers. T
@bpwwer, thanks for your reply.  Its strange that it works for you (without the token?)  Here is my configuration, does it look correct?
I created a 2nd token, same result.
This is a long shot but maybe related?  The first time I set this up I incorrectly created a key "Station ID".  When I restarted the blue message about needing the Station ID was gone so I thought I was all set.  @jimboAutomates set me straight on that but could that be a left over somehow?  I have deleted and re-added the NS twice so I would think that would clear everything but just thought I would throw that out there.
Thanks again for your help.
Edited by tmorse305
That configuration looks ok to me.
I can't actually get any data from your station with my token so I don't really know if it's OK on the WeatherFlow end.
@bpwwer In working through my programs have noticed that Celcius and Farh. are gettin mixed up.
I have chosen F in config. In the Device tree in Admin cons, it shows correctly as F. However in programs, when choosing a temp it only appears in C.
See screen shots for better explanation.  Thanks.
Scroll down farther, you can select temperature in either F or C, just the C values come first in the list.
      377k
