UD mobile error on sync
I get this error when I sync (iOS app v0.6.8, ISY 994i v5.3.1). Any idea what it means?
It’s error 1. (I don’t have any network items).
Don't worry about the 2. error. It just means that you don't have any network resource. I get the same.
However, investigate error 1.
The first error indicates a parsing error for the National Language Support (NLS) file.  What Node Server is installed in slot 1?
I don’t think I have any node servers, but looking in slot one it says:
polyglot (Network )
I’m not using polyglot though.
Edited by NWaterton
Typos
If not using polyglot, and you are not having any issues with the app, then the errors can be disregard as it relates to the Node Server slot 1.
If you would like to remove the error I can ask you for some additional information. Correcting the error will have no changes to a system not using polyglot, and may be corrected automatically when/ if you start using polyglot in the future.
As long as it doesn’t matter, I’ll ignore it. Everything seems to be working OK.
Thanks for the info.
