Jimbo.Automates Posted March 30, 2022 Posted March 30, 2022 I will have a release of the ELK NS soon which will support sending text to keypads, but it will have the same issue as mentioned here: https://forum.universal-devices.com/topic/35543-pg3-notification-node-server-330-question/#comment-332635 Please let me know your thoughts on pushing out this update, I hate to break anyone that is currently relying on it. 1
Bumbershoot Posted March 30, 2022 Posted March 30, 2022 It won't hurt me, as production is on PG2, and will be for a while yet. I like the sounds of what this update will provide, however. I'll probably install the notification Node server as well due to the Short Custom Content functionality. 1
DennisC Posted April 1, 2022 Posted April 1, 2022 I have been playing around with sending text to Elk keypad. Previously, using the Elk Module, I was sending the OA temp to my keypads and I wanted to reinstate this. As a test, I have been successful placing the following in the body: ${sys.date} ${sys.time} I have even placed ${sys.date} ${sys.time} in the subject and it has worked (does $ & {} count has a character?), even thought I am not sure if it exceeds 16 characters. However, I can not get the Tempest temperature or humidity value to appear on the keypad using either one in the subject or both on two lines in the body. Is this a limitation of the 16 characters and if so, can that be upped so we can pass node server values to the Elk Keypad?
glarsen Posted April 1, 2022 Posted April 1, 2022 (edited) There is also a restriction on which characters the ELK can display...for instance if a degree or percent symbol is embedded in the string, nothing will display. Ask me how I know this...? Edited April 1, 2022 by glarsen
Jimbo.Automates Posted April 1, 2022 Author Posted April 1, 2022 The $ and { do not count, what counts is what they resolve to. The 16 character limit is on the ELK, nothing I can do about it. For illegal characters like the degree, I though the API I was using already took care of that, but sounds like it's not. I'll put in a fix when I get time, but for now you can add .raw to not get the formatted value. 1
DennisC Posted April 1, 2022 Posted April 1, 2022 On 4/1/2022 at 8:17 PM, glarsen said: There is also a restriction on which characters the ELK can display...for instance if a degree or percent symbol is embedded in the string, nothing will display. Ask me how I know this...? Expand Thanks for that, adding raw to the end worked.
DennisC Posted April 1, 2022 Posted April 1, 2022 (edited) On 4/1/2022 at 10:03 PM, JimboAutomates said: The $ and { do not count, what counts is what they resolve to. The 16 character limit is on the ELK, nothing I can do about it. For illegal characters like the degree, I though the API I was using already took care of that, but sounds like it's not. I'll put in a fix when I get time, but for now you can add .raw to not get the formatted value. Expand Thanks to @glarsen, using the raw value has it working. There is no issue with it the way it is, as long as we know the situation. Maybe updating the documentation would help? Edited April 1, 2022 by DennisC Spelling
glarsen Posted April 2, 2022 Posted April 2, 2022 (edited) @Javi, @JimboAutomates, I think this update must have broken something with UD Mobile. I get "java.lang.error: Node Status Relation Cursor is empty. NodeId: 1551. Control:0.500. I have restarted the ISY and the reloaded the app with no change. Edit: The node status fields all display, but none of the CMD fields appear. All of the grouped nodes show. Edited April 2, 2022 by glarsen
Javi Posted April 2, 2022 Posted April 2, 2022 Thanks @glarsen, this error is likely related to an invalid init value for a command parameter. @JimboAutomates, do you have an init value set to "0" for a NodeDef.Accepts.Parameter somewhere? 1
Jimbo.Automates Posted April 2, 2022 Author Posted April 2, 2022 On 4/2/2022 at 11:34 PM, Javi said: Thanks @glarsen, this error is likely related to an invalid init value for a command parameter. @JimboAutomates, do you have an init value set to "0" for a NodeDef.Accepts.Parameter somewhere?Yes, probably in a complex cmdp structure I'll send you the nodedef when I get home.Sent from my Pixel 6 Pro using Tapatalk 1
Jimbo.Automates Posted April 3, 2022 Author Posted April 3, 2022 On 4/2/2022 at 7:38 PM, glarsen said: @Javi, @JimboAutomates, I think this update must have broken something with UD Mobile. I get "java.lang.error: Node Status Relation Cursor is empty. NodeId: 1551. Control:0.500. I have restarted the ISY and the reloaded the app with no change. Edit: The node status fields all display, but none of the CMD fields appear. All of the grouped nodes show.Does this happen on sync? Or when you open that node in UD Mobile?Sent from my Pixel 6 Pro using Tapatalk
glarsen Posted April 3, 2022 Posted April 3, 2022 When the Area node is opened in UD Mobile. The zones are fine. 1
Jimbo.Automates Posted April 4, 2022 Author Posted April 4, 2022 (edited) On 4/3/2022 at 9:02 PM, glarsen said: When the Area node is opened in UD Mobile. The zones are fine. Expand This is fixed in 3.2.2, but there is still an issue which I think will require an update to UD Mobile. I apologize to @Javi that I didn't give him access to this to test with the new editor that Chris added before this was released. Edited April 4, 2022 by JimboAutomates
DennisC Posted April 4, 2022 Posted April 4, 2022 On 4/4/2022 at 12:26 AM, JimboAutomates said: This is fixed in 3.2.2, but there is still an issue which I think will require an update to UD Mobile. I apologize to @Javi that I didn't give him access to this to test with the new editor that Chris added before this was released. Expand After running the update and syncing UD Mobile, the error changed to: java.lang.Error:UOM Suffix is null. 500
Jimbo.Automates Posted April 4, 2022 Author Posted April 4, 2022 On 4/4/2022 at 1:20 AM, DennisC said: After running the update and syncing UD Mobile, the error changed to: java.lang.Error:UOM Suffix is null. 500Yes already provided that info to @Javi Sent from my Pixel 6 Pro using Tapatalk
Javi Posted April 4, 2022 Posted April 4, 2022 On 4/4/2022 at 1:20 AM, DennisC said: After running the update and syncing UD Mobile, the error changed to: java.lang.Error:UOM Suffix is null. 500 Expand Thanks, the new UOMs have not been updated on the app side, they should be in the next release. 1
DennisC Posted April 8, 2022 Posted April 8, 2022 On 4/4/2022 at 1:31 PM, Javi said: Thanks, the new UOMs have not been updated on the app side, they should be in the next release. Expand Hi @Javi, Just checking, if the expectations was that the recent releases were to fix the UOM error, it hasn't. I am still getting that error.
Javi Posted April 8, 2022 Posted April 8, 2022 On 4/8/2022 at 11:22 AM, DennisC said: Hi @Javi, Just checking, if the expectations was that the recent releases were to fix the UOM error, it hasn't. I am still getting that error. Expand Hi @Dennis, Not yet fixed, the last release was already in the pipeline.
