zwave+ Schlage deadbolts - No longer reporting user number
Remote address so difficult to do much in a physical way until I am on-site.
I recently updated ISY to 5.3.4 and since then (I think) both my Schlage BE469ZP dead bolts no longer report the user number on the main node in the user number field (see pic). It remains blank.
I have programs that utilize this information that no longer function. The user number DOES still appear in the Access Control Device node (see pic)
I don't appear to have any zwave comms issues, nothing has changed on the ISY aside from the firmware update.
The issue happens using both Schlage locks I have on-site, so we can rule out an individual lock.
I have not attempted any form of synchronize / update neighbors / repair links as I don't think it has anything to do with the problem, but please do correct me if I am mistaken.
Edited by mango
Updated pics
Here is a snippet from the log relating to the door being unlocked by user 5:
Entry / Front Door / Front Door	Status	Unlocked	Mon 2022/05/16 12:53:02 PM	System	Log
Entry / Front Door / Front Door Access Control	An alarm occurred (values are different for each device type)	6	Mon 2022/05/16 12:53:02 PM	System	Log
Entry / Front Door / Front Door Access Control	The user access code that associated with the most recent Alarm	5	Mon 2022/05/16 12:53:02 PM	System	Log
Here is an older log entry when user number used to work:
Entry / Front Door / Front Door	The user access code that associated with the most recent Alarm	10	Fri 2021/10/01 05:59:45 PM	System	Log
Entry / Front Door / Front Door	Status	Unlocked	Fri 2021/10/01 05:59:45 PM	System	Log
It appears the way the ISY is organizing the zwave lock data is now different since the firmware upgrade(?)
Edited by mango
I was weary to revert firmware remotely and have been able to attend site, revert to firmware 5.3.0 and sure enough everything works as before - user number is assigned to door lock node and my programs work correctly. Interestingly there is now no information presented through Access Control Alarm node, it is blank with 5.3.0.
So, is this a bug with 5.3.4?
Perhaps has the way the ISY communicates with zwave / Schlage locks has been adjusted / upgraded between 5.3.0 and 5.3.4? Not sure. If anyone knows I am keen to learn.
Edited by mango
typos
I believe the User number is now populated in a child node name "Access Control", but no longer appears in the main node.
Hi Javi,
Thank you for explaining. Is there a change log that documents changes such as these?
Would there be a way in the next release to revert back to also having the user number in the main node? That way it would be an easy path to refresh the programming, as I tested using the child node Access control, but as we can see in the log, the sequence is now different, and my existing programming does not function if I substitute the child node for the main node. This is what I presently have with 4.3.0, which has been working fine for a long time.
Control - [ID 003F][Parent 0042]
Folder Conditions for 'Control'
[FrontDoor] Battery Level - [ID 0004][Parent 003F]
        'Entry / Front Door / Front Door' Battery Level <= 50%
        Resource '[FrontDoor] Battery Low'
[FrontDoor] Jammed - [ID 0005][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' Status is Jammed
        Resource '[FrontDoor] Jammed'
[FrontDoor] State Unknown - [ID 0006][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' Status is Unknown
        Resource '[FrontDoor] State Unknown'
[FrontDoor] Trigger Locked - [ID 0007][Parent 003F]
        'Entry / Front Door / Front Door' Status is Locked
        Run Program '[FrontDoor] U0 Locked' (If)
[FrontDoor] Trigger Unlocked - [ID 0008][Parent 003F]
        'Entry / Front Door / Front Door' Status is Unlocked
        Run Program '[FrontDoor] U0 Unlocked' (If)
[FrontDoor] U0 Locked - [ID 0009][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' User Number is 0
        Resource '[FrontDoor] U0 Locked'
        Run Program '[FrontDoor] U1 Locked Rob' (If)
[FrontDoor] U0 Unlocked - [ID 000A][Parent 003F][Not Enabled]
        Resource '[FrontDoor] U0 Unlocked'
        Run Program '[FrontDoor] U1 Unlocked Rob' (If)
[FrontDoor] U1 Locked Rob - [ID 000B][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' User Number is 1
        Resource '[FrontDoor] U1 Locked Rob'
        Run Program '[FrontDoor] U2 Locked Matt' (If)
[FrontDoor] U1 Unlocked Rob - [ID 000C][Parent 003F][Not Enabled]
        Resource '[FrontDoor] U1 Unlocked Rob'
        Run Program '[FrontDoor] U2 Unlocked Matt' (If)
[FrontDoor] U10 Locked Guest - [ID 000D][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' User Number is 10
        Resource '[FrontDoor] U10 Locked Guest'
        Run Program '[FrontDoor] U11 Locked Guest Spare' (If)
[FrontDoor] U10 Unlocked Guest - [ID 000E][Parent 003F][Not Enabled]
        Resource '[FrontDoor] U10 Unlocked Guest'
        Run Program '[FrontDoor] U11 Unlocked Guest Spare' (If)
[FrontDoor] U11 Locked Guest Spare - [ID 000F][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' User Number is 11
        Resource '[FrontDoor] U11 Locked Guest Spare'
        Run Program '[FrontDoor] State Unknown' (If)
[FrontDoor] U11 Unlocked Guest Spare - [ID 0010][Parent 003F][Not Enabled]
        Resource '[BackDoor] U11 Unlocked Guest Spare'
[FrontDoor] U2 Locked Matt - [ID 0011][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' User Number is 2
        Resource '[FrontDoor] U2 Locked Matt'
        Run Program '[FrontDoor] U3 Locked Christy' (If)
[FrontDoor] U2 Unlocked Matt - [ID 0012][Parent 003F][Not Enabled]
        Resource '[FrontDoor] U2 Unlocked Matt'
        Run Program '[FrontDoor] U3 Unlocked Christy' (If)
[FrontDoor] U3 Locked Christy - [ID 0013][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' User Number is 3
        Resource '[FrontDoor] U3 Locked Christy'
        Run Program '[FrontDoor] U4 Locked Hein' (If)
[FrontDoor] U3 Unlocked Christy - [ID 0014][Parent 003F][Not Enabled]
        Resource '[FrontDoor] U3 Unlocked Christy'
        Run Program '[FrontDoor] U4 Unlocked Hein' (If)
[FrontDoor] U4 Locked Hein - [ID 0015][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' User Number is 4
        Resource '[FrontDoor] U4 Locked Hein'
        Run Program '[FrontDoor] U5 Locked Margaret' (If)
[FrontDoor] U4 Unlocked Hein - [ID 0017][Parent 003F][Not Enabled]
        Resource '[FrontDoor] U4 Unlocked Hein'
        Run Program '[FrontDoor] U5 Unlocked Margaret' (If)
[FrontDoor] U5 Locked Margaret - [ID 0018][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' User Number is 5
        Resource '[FrontDoor] U5 Locked Housekeeper'
        Run Program '[FrontDoor] U6 Locked Dan' (If)
[FrontDoor] U5 Unlocked Margaret - [ID 001E][Parent 003F][Not Enabled]
        Resource '[FrontDoor] U5 Unlocked Housekeeper'
        Run Program '[FrontDoor] U6 Unlocked Dan' (If)
[FrontDoor] U6 Locked Dan - [ID 001F][Parent 003F][Not Enabled]
        'Entry / Front Door / Front Door' User Number is 6
        Resource '[FrontDoor] U6 Locked Dan'
        Run Program '[FrontDoor] U10 Locked Guest' (If)
[FrontDoor] U6 Unlocked Dan - [ID 0021][Parent 003F][Not Enabled]
        Resource '[FrontDoor] U6 Unlocked Dan'
        Run Program '[FrontDoor] U10 Unlocked Guest' (If)
49 minutes ago, mango said:
Hi Javi,
I'm not sure if it's documented, but has been this way for almost 2 years. It may be related to a zwave improvement.  The number should be the same assuming the "User Number" status value is used (not the "Access Control" status value).
I don't quite follow your programs, but here is one of mine to send a message when users 1, 2, or 3 unlock the door.
Disarm from keypad front door - [ID 009C][Parent 009D]
        'ZW 014 Schlage Door Lock - ki / ZW 014 Access Control Alarm' Access Control is Keypad unlock
    And (
             'ZW 014 Schlage Door Lock - ki / ZW 014 Access Control Alarm' User Number is 1
          Or 'ZW 014 Schlage Door Lock - ki / ZW 014 Access Control Alarm' User Number is 2
          Or 'ZW 014 Schlage Door Lock - ki / ZW 014 Access Control Alarm' User Number is 3
        Do Something
EDIT: Keep in mind user 0 is automated control or pressing the schlage button to lock the door.
Thanks Javi, I shall have to fiddle around.
The programming I am presently using was gleaned from here I think some time ago from another member.
