ISY994i as Z-Wave Controller?
This may be a dumb question but with INSTEON going away, can I use my ISY994i with the Z-wave daughter card to simply be a Z-wave controller?  We just moved from our house to a condo and I don't really want to go through the INSTEON installation process based on the company's status. I don't think I need the PLM to control Z-wave devices do I?  I'm obviously a novice in the Z-wave world and am sad that INSTEON is going away.  (Maybe some other company will swoop in and buy them and keep it alive.  One can hope,).
I also have a Honeywell Lyric Security Controller in the Condo we bought which also does Z-wave so maybe I can just use that?
Thanks for any help/guidance.
Hi @Kentinada,
The ISY will work without a PLM, but you may need to manually update to the Z-Wave only firmware or it will remain in safe mode.  This is a simple process of downloading the firmware file, then point the ISY to the location of the downloaded zip file from the Admin Console ->  Help -> Manually Upgrade ISY.
I'm moving from Insteon to Z-Wave using a 994i and so far so good.  I haven't found anything as nice as the Keypadlinc(s) but so far I've got Kwikset, Leviton, Zooz, and GE Enbrighten stuff on my Z-Wave (500) network and all is well.  And a few remaining Insteon devices.
On 5/18/2022 at 2:31 PM, Javi said:
Hi @Kentinada,
@Javi thanks.  I've looked for the Z-wave firmware in the wiki and can't find it.  Can anyone point me to it?
Also, my Z-wave version is 6.81.00.  Is that still current?  Not sure if I need an upgrade or not.  I added this Z-wave daughter card to my ISY994i a while ago.    Thanks!!
One other question: I'm thinking I should probably do a factory reset on my entire ISY994i/Z-wave combo since we're in a new house and I'm getting off of INSTEON.  I think I should start clean.  Agree?
for ISY994 version 5.3.4 check this thread:
In step 3 (download firmware), there are 2 links to choose from.  The first is for ISY994's with a PLM, the second is for ISY994's without a PLM.
It's not in the wiki. It's where it's always been under the sub forum software releases and updates> current releases.
***Thanks to @MrBill who alerted me that there is a link in the wiki which will take you to the current release subforum. I was incorrect saying it's not there.***
Edited by lilyoyo1
Sorry @lilyoyo1 it's been a while since I've done much with my ISY.  It just ran and I didn't have to think about it.  Now, moving to a new home and with getting out of INSTEON, it's taking me a bit to jump back in.
No worries. Just showing how easy it is to find general information like this on the forums now. @Geddyput in a lot of time and effort to clean things up and make the every day items much easier to locate and use
Edited by lilyoyo1
40 minutes ago, GJ Software Products said:
My 994i reports Z-Wave version at 6.82.01 . I was looking to see if this was the latest but I can't seem to find anything (yet).
That's the latest and only version for the isy
That's the latest and only version for the 500 series z-wave board.  300 series reports 4.55.00.
