Govee node server PG3 does not start
tlightne
You could try deleting and re-install the node server again.  It looks like the required "govee-api-laggat" python library didn't get installed.
If that doesn't help, then you'll need to post the installation errors from the PG2 or PG3 log file.
Deleted Govee NS and reinstalled same error. Here is the PG3 log file,
Thanks..
6/5/2022, 17:31:26 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:59:41:e4_11 to broker pg3_broker 6/5/2022, 17:31:30 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Requirement already satisfied: udi_interface>=3.0.18 in /var/polyglot/.local/lib/python3.8/site-packages (from -r requirements.txt (line 1)) (3.0.46) 6/5/2022, 17:31:30 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Collecting govee-api-laggat 6/5/2022, 17:31:30 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Using cached govee_api_laggat-0.2.2-py3-none-any.whl (23 kB) 6/5/2022, 17:31:30 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Requirement already satisfied: pyisy!=2.1.5,<3.0.0,>2.0 in /var/polyglot/.local/lib/python3.8/site-packages (from udi_interface>=3.0.18->-r requirements.txt (line 1)) (2.1.4) 6/5/2022, 17:31:30 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Requirement already satisfied: python-dotenv in /var/polyglot/.local/lib/python3.8/site-packages (from udi_interface>=3.0.18->-r requirements.txt (line 1)) (0.20.0) 6/5/2022, 17:31:30 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Requirement already satisfied: markdown2 in /var/polyglot/.local/lib/python3.8/site-packages (from udi_interface>=3.0.18->-r requirements.txt (line 1)) (2.4.2) 6/5/2022, 17:31:30 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Requirement already satisfied: netifaces in /usr/local/lib/python3.8/site-packages (from udi_interface>=3.0.18->-r requirements.txt (line 1)) (0.11.0) 6/5/2022, 17:31:30 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Requirement already satisfied: paho-mqtt in /var/polyglot/.local/lib/python3.8/site-packages (from udi_interface>=3.0.18->-r requirements.txt (line 1)) (1.6.1) 6/5/2022, 17:31:31 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Requirement already satisfied: certifi>=2021.10.8 in /usr/local/lib/python3.8/site-packages (from govee-api-laggat->-r requirements.txt (line 2)) (2021.10.8) 6/5/2022, 17:31:31 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Collecting events>=0.3 6/5/2022, 17:31:31 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Using cached Events-0.4.tar.gz (5.6 kB) 6/5/2022, 17:31:31 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Preparing metadata (setup.py): started 6/5/2022, 17:31:33 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Preparing metadata (setup.py): finished with status 'done' 6/5/2022, 17:31:33 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Collecting pexpect>=4.8.0 6/5/2022, 17:31:33 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Using cached pexpect-4.8.0-py2.py3-none-any.whl (59 kB) 6/5/2022, 17:31:33 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Collecting dacite>=1.6.0 6/5/2022, 17:31:33 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Using cached dacite-1.6.0-py3-none-any.whl (12 kB) 6/5/2022, 17:31:33 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Collecting bios>=0.1.2 6/5/2022, 17:31:33 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Using cached bios-0.1.2.tar.gz (4.7 kB) 6/5/2022, 17:31:33 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Preparing metadata (setup.py): started 6/5/2022, 17:31:35 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Preparing metadata (setup.py): finished with status 'done' 6/5/2022, 17:31:35 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Requirement already satisfied: aiohttp>=3.7.1 in /usr/local/lib/python3.8/site-packages (from govee-api-laggat->-r requirements.txt (line 2)) (3.7.4.post0) 6/5/2022, 17:31:35 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Collecting pygatt>=4.0.5 6/5/2022, 17:31:35 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Using cached pygatt-4.0.5.tar.gz (40 kB) 6/5/2022, 17:31:35 [pg3] debug: NSChild: Govee(12) /bin/sh ./install.sh: Preparing metadata (setup.py): started 6/5/2022, 17:31:48 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_tetMC has published message on udi/pg3/frontend/isy/admin to broker pg3_broker 6/5/2022, 17:31:48 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"783ebc25-e310-4fe9-a233-ef42d2028c06","uuid":"00:0d:b9:59:41:e4","token":"zDN2s(bDGqgU1m)=","name":"AmbientPoly","nsid":"","expires":0,"nickname":null,"profileNum":1,"timeAdded":1649355701638,"timeStarted":null,"timeModified":1649355701638,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"c96c436b-b38c-4d9c-a57b-a7664a8ffab9","uuid":"00:0d:b9:59:41:e4","token":"c6z*&gA2QJ-*))xP","name":"NOAA","nsid":"f55281ba-15ba-4116-9396-5905d2a2215e","expires":0,"nickname":null,"profileNum":2,"timeAdded":1650312758194,"timeStarted":1653857771868,"timeModified":1653857777777,"version":"2.0.2","branch":"master","url":"https://pg3store.isy.io/v2/node servers/production/udi-noaa-poly.zip","home":"/var/polyglot/pg3/ns/00:0d:b9:59:41:e4_2","log":"logs/debug.log","logLevel":"ERROR","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},
Looks like it installed correctly. The node server author will have to take a look at it to figure out why it's not working.
@bpwwer Sent message to Developer Automationgeek and he no longer has time to support the Govee Node server. Any suggestions for where we go from here?
Thank you
Here is his response:
If no one wants to maintain it, we'll probably have to pull it from the store, or maybe just move it to the non-production store so someone could work on debugging it if they desire.
I took a quick look at it and it seems like one of the dependencies isn't installing.  This is not uncommon as many of the Python modules are written for Linux and don't include packages specifically for FreeBSD.  Sometimes they'll build without any issues on FreeBSD, other times they don't.  In this case the build is failing.  I didn't dig into why it was failing.
@bpwwer Is there a way to notify the developer community that Automation geek is no longer supporting any of his node servers to see if anybody wants to pick up support for any of them?
Thank again for all you do.
@Michel KohanimIs this something you can do?
      38.2k
      381.2k
