tmorse305 Posted October 13, 2022 Posted October 13, 2022 (edited) Hi @Panda88, I tried to install the node server(trial) but I get an error, see attached. The NS actually looks like it installs. It appears on the dashboard but only for a few minutes but then disappears as though it was never installed. The process is repeatable. Suggestions? Thanks Update. I tried to restart PG3 to see if it would make a difference, it did not. PG3 log attached from PG3 reboot. I see 1 error related to Blink: 10/12/2022, 19:27:01 [pg3] error: createNS: ReferenceError: status is not defined at checkLicense (/var/polyglot/node_modules/@universaldevices/pg3/lib/services/node servers.js:688:95) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Object.createNs (/var/polyglot/node_modules/@universaldevices/pg3/lib/services/node servers.js:451:5) log from boot.zipFetching info... Edited October 13, 2022 by tmorse305 More information
Solution tmorse305 Posted October 13, 2022 Author Solution Posted October 13, 2022 Upgrade to PG3 3.1.11 fixed the problem
