Portal dead again?
Solved by bmercier
Yeah, I think so.  I'll reach out to the guy I did last time.
UD is normally so rock solid, when something goes wrong, I don't even think UD, so I start with my normal suspect, my network. lol
Edited by QBS
Hi,
Mine is also showing Offline and when I attempt to login to https://my.isy.io, I am getting HTTP error 500. So then I attempted to login from the main Universal Devices webpage: https://www.universal-devices.com/login/?redirect_to=https%3A%2F%2Fwww.universal-devices.com%2Fmy-account%2F
And when I do so, I get this reponse:
Hope, they are aware and will soon fix the problem.
Larry
And just when I was trying to debug Tasker. I found my error and then getting a 500. I'm like wait... WHAT?
Same here …
The ISY portal is down for me too. Alexa says to re-enable the skill.
The web login is down too. returns a HTTP error 500 at login.
Hope the Universal Devices team is on the case.
Chiming in......can log into my local console, can't connect with the UD Mobile app (ERROR: Could not get credentials (11):("code":503,"error":"server_error","error_description":"server_error") oAuth Error
Cannot connect to ISY portal. Http error 500.
When I connect locally to the admin console, i see Portal Integration - UDI Offline.
Edited by alambertus
@bmercier My Alexa is complaining about no contact with ISY Portal again also.
ooops...didn't see you were on it already.
Same thing here. Alexa reports "topology was destroyed"
Same problem here. Everything on Alexa is working, and my ISY99 is working through the app, but no Alexa integration is not working!!  Dang.  This not good.  Why is this happening?  Did we get an answer from before?
Hopefully now they know how to quickly fix it.  Anyone submit a support request?
Any updates on this??
Ditto just as I was reprogramming things, thought I had really screwed up my app, now I see everyone is having issues, hopefully a simple fix soon.
9 minutes ago, Brewtrooper said:
... my ISY99 is working through the app, but no Alexa integration is not working!!
Which "app" are you referring to? The only way I can control any devices is through UDS Admin console on my PC on same LAN. Is that the "app" you are referring to?
Edited by RYost
Sorry.  Yes.  I meant that I was connecting via the admin console via local IP address direct connect.  Not sure why I said "app".
There is an official App “UD MOBILE”
and it’s pretty good,
https://apps.apple.com/us/app/ud-mobile/id1550618148
Still its a work in progress but no need for PC or Java admin console.
 It is working now and not effected by the current web portal being down again.
Dashboard is working for me.  Just not Alexa.
