replacing SD card - will it work with 32GB card?
Bought a new SD card that's 32GB and, when I double checked the instructions on how to replace it, it says "ISY supports up to a 16GB SD card". See https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Replacing/Formatting_an_SD_Card
It's a bit old so thinking it's outdated, and I wasn't able to find anything smaller than 32GB. Is it just a case that it won't format/use more than 16GB (no big deal), or will using a bigger SD card actually fail?
Solved by Techman
The ISY994 supports a 32gb SD card. I'm currently using one as are many other forum members.
The following is from the link you provided.
"The ISY994i takes a MicroSD card. The max size is 32GB. Please look for a card with the newer A1 rating (A2 also works, but will fallback to A1 because the ISY994 does not provide hardware support required for A2). All other process steps below remain the same.]"
