Elk Alarm integration
Eisy is on the way.  zMatter shipping 12/27.
Currently on isy, elk screens/integration is part of the admin console.  When I back up ISY and install in eisy will this ELK setup port over?
If not, how do I get Elk setup with eisy?
Thanks @lilyoyo1 Not a hardcore developer and havent used Node Servers so far.  Any easy way of getting my isy elk config into the Node Server and integrating with eisy?
Anyone have a step by step process?
Edited by TheA2Z
@TheA2Z
Before you do the below,
  • Conduct a regular backup
  • Export a text copy of all programs: Go to programs and right click My Programs and select Copy Folder to Clipboard. Open text editor and paste, save.
Migration of Elk:
  • If you have the Elk module on the ISY994 you will need to install the ELK Node Server to restore ELK functionality. The node server version will have different node addresses and some slightly different naming.
  • Programs that used the ELK have to be reconfigured for the new ELK nodes.
  • After rebooting the ISY post migration and the ELK NS install, the programs that need attention will be highlighted in yellow as they show up on the programs/summary page. Refer to Program text file if backed up earlier for rebuilding.
  • At that point it is just a matter of restoring the new ELK nodes back into the programs.
  • Speak and query aren't available on version PG2 but will be added to PG3 in the future.
Edited by dbwarner5
