Admin Consol seems in endless loop
Am a snow bird and have a second home.  Just arrived for the winter and none of my insteon programs were working - not sure how long they were out.  Connected to the admin consol which showed all links to devices x'ed out (dead).  Rebooted isy to no effect.  Then rebooted PLM and all devices showed as recognized but then admin consol immediately started to re-link devices.  This went on overnight for maybe 12-15 hours.  I finally closed admin consol then restarted and it picked up where it left off with the linking, which going on 2 hours in this latest iteration.  Am reluctant to reboot ISY or PLM with the re-linking in progress.
Any suggestions ?
What's your ISY firmware and UI versions?
Is the power led on your PLM on?
What leds on the ISY front panel are on?
5.2.0 on firmware and ui
power light on plm green
no led on isy other than power (on).
Well,  solved it by accident. Rebooted both PLM and ISY.  Then, instead of going to admin consol went to dashboard, which re-loaded my programs (which btw had disappeared from the admin consol).  I closed the dashboard down, loaded the admin consol and it then re-linked my devices and all now seems OK.  -- Sometimes dumb luck is the best solution...
Thanks anyway for your help.
That sounds like Firmware and UI (i.e. admin console) versions not matching.   Are your ISY's at both locations using the same versions?  do you use the IoX launcher or local copies of the admin console?  Windows or Mac?
