Zigbee support?
I realize Thread/Matter support is coming sometime after March 2023, however there was mention about enabling Zibgee. I notice there are lots more Zigbee alternatives (and cheaper too) for Zigbee things like motion sensors, wall switches etc. than ZWave.
I think all would be enabled at the same time since Matter uses zigbee
Oh ok, I am sure I seen somewhere way back that there was a possibility of enabling zigbee in meantime, while waiting for thread/matter firmware to get finalized.
Don't know if the date still holds, but I found this on the eisy page in UD store:
Device Support
  • INSTEON Support – Requires a PLM (not included): 2413S, 2413U, or 24487U. If you are using 2413S (serial/RS232), then you will need our Serial PLM Kit
  • Z-Wave Support – Requires our ZMatter USB dongle (not included)
  • Zigbee / Matter Support – Requires our ZMatter USB dongle (not included). Zigbee and Matter support will not be available till 03/2023
  • 100s of other devices and services are supported through our awesome and vetted third-party developed node servers (plugins). Here’s the list
As I have the HA Yellow Box, I am tempted to try out Zigbee especially as I noticed on Amazon that Zigbee devices are significantly cheaper than Zwave. However,  adding another eco system may be a pain. So maybe I just wait to see if Matter takes off,
Device Support
With all of the bugs so far, I wouldn't hold my breath
At this point in time, that sounds like a wise decsion.
I understand that Thread RF protocol is based off Zigbee, but there are differences . Matter runs on Ethernet (WiFi, wired LAN), and Thread. A Thread border router is used to communicate between these two different networks. From what I am reading, I get the impression that it should be possible to have an EISY, Polisy (anything running IoX) see Thread based matter devices without a ZMatter board, as long as you have a Thread border router of some sort... eg. my Apple Homepod Mini should allow this. I guess we will find out soon hopefully.
Edited by brians
Yes, I watch a few HA Youtube channels and am starting to become envious of all the Zigbee options available, and in fact am more interested/excited about Zigbee now than Matter :)
However there are issues with Zigbee (And Thread/Matter too) being in 2.4Ghz and interference that could alter my experience if I actually used. When (if?) I get my skyconnect USB for HA, I'll pickup a Zigbee device to experiment with.
Edited by brians
Keep us informed 😁
I'm aware of how it runs. Because of past statements from Michel, I wouldn't be surprised if they released both together as it makes sense from a development standpoint
I think interference issues are overblown. I've done enough installs with C4 and hue bulbs without having issues. Granted, every home is different so it can potentially happen. If there were to be wide ranging issues, I can see it being more from lower quality devices than better quality ones.
In addition, depending on UDIs implementation, you may be able to set the channel that ZigBee uses outside the range your network uses
So...just like all the Z-Wave issues "we've" been having? I think the biggest issue is while there's a "Z-Wave" standard not all manufacturers adhere to it as some might hope. I feel for UDI in that their support ticket could will probably jump significantly again once the additional devices are supported.
🤞 My hope is users realize that it's not UDI but the device manufacturer devices (UDI is trying to support) that are causing the problems. Most haven't considered this being case with the Z-Wave debacles many faced.
