Enabling Z-wave module using UD mobile
Most likely very few users would notice, but I believe I found a couple of bugs.
#1
When enabling Z-wave module using UD mobile it somehow disabled the Insteon module that has always been enabled. I had to utilize the admin console to figure out why my Insteon devices were not responding. Found the Insteon module not selected directly after enabling the Z-wave module using UD mobile.
#2
When disabling Z-wave module using UD mobile, it crashes the entire Insteon network. To get the Insteon network back up and running correctly, you have to re-start IOX, and then query all Insteon devices.
Setup - Polisy running 5.59, PG3 version 3.120 UD mobile IOS
This is not a big deal as it is easily resolved, just thought I would pass this along.
Edited by MBell
spelling
Solved by Javi
#1
#2
Hi @MBell,
Thanks for the report.  I tried but cannot replicate the issue.  Are you using the Z-Matter module or Zooz USB stick?
Update: Replicated.  Looking for cause
4 hours ago, Javi said:
Hi @MBell,
Your welcome.
Thank you for the prompt resolution.
