Homeseer and Eisay. Is there a future?
I have an ISY 994i/IR Pro that I have been running since it came out. I bought a Polisy Pro but could never use it as I could find a PLM.
So, I bought a Eisay and a new PLM, but before installing it, I wondered if it will communicate with Homeseer via the insteon plugin that has been working my ISY.
Has anyone come across this situation? Can Eisay work with homeseer?
Solved by nccasinc
  • 4 weeks later...
I had some time try try to get this to work. Homeseer knows the IP address of the Eisy but under the status Page there is nothing listed. I deleted the plugin and then reinstalled but i get the same result.
Anything I could try? I have a lot if interaction between these two platforms.
As far as I know, it should work with the eisy, but it's possible that a recent firmware update breaks the plug-in.  Does the plug-in log anything that might indicate what the problem is?
I'm seeing the same issue within the last few days, the last eisy device update date in HS is 6/10/2023 10:21:44 PM an the log is full of the following message:image.thumb.png.accbdc5462b7717685d63774745ae91c.png
2 hours ago, Michaelv said:
I di not change the credentials
they are the default ones.
What have you set the IP address/port too?
What shows up in the log when you start the plug-in?
Mine has worked fine for several months.  Be sure your EISY iP address is xx,xx,xx,xx:8080.  You have to specify the port number :8080 for the EISY.  Hope this works for you.  Had the same issue as you at first!!!!
