Could not match CMD split
CMDWhen I am synchronizing my UD Mobile I keep getting an error “Could not match CMD split …. In family 10”.   Any idea what this means and how to corrrect it?
For the numbered errors it appears the Node Server in slot 6 has invalid definitions causing parsing issues in the app.  Although this should not cause "The request timed out".
Do you get "The request timed out" on every try?  What Node Server is in slot 6?
Node 6 is Hubitat.  The request time out is because I kept the window open too long as I wrote the post.  I normally do not get that error
Great.  The app should function with these errors although the Hubitat Node Server may not show formatted values.  I'll try to notify the NS developer so they can correct the issue.
Thank you
@RRoyceus,  what version of the Hubitat Node Server causes these errors?
Thank you for the help:
Version 1.0.10
