RRoyceus Posted August 9, 2023 Posted August 9, 2023 CMDWhen I am synchronizing my UD Mobile I keep getting an error “Could not match CMD split …. In family 10”. Any idea what this means and how to corrrect it?
Javi Posted August 9, 2023 Posted August 9, 2023 For the numbered errors it appears the Node Server in slot 6 has invalid definitions causing parsing issues in the app. Although this should not cause "The request timed out". Do you get "The request timed out" on every try? What Node Server is in slot 6?
RRoyceus Posted August 9, 2023 Author Posted August 9, 2023 Node 6 is Hubitat. The request time out is because I kept the window open too long as I wrote the post. I normally do not get that error
Javi Posted August 9, 2023 Posted August 9, 2023 Great. The app should function with these errors although the Hubitat Node Server may not show formatted values. I'll try to notify the NS developer so they can correct the issue.
RRoyceus Posted August 10, 2023 Author Posted August 10, 2023 On 8/9/2023 at 10:47 PM, Javi said: Great. The app should function with these errors although the Hubitat Node Server may not show formatted values. I'll try to notify the NS developer so they can correct the issue. Expand Thank you
Javi Posted August 10, 2023 Posted August 10, 2023 @RRoyceus, what version of the Hubitat Node Server causes these errors?
RRoyceus Posted August 12, 2023 Author Posted August 12, 2023 On 8/10/2023 at 2:32 PM, Javi said: @RRoyceus, what version of the Hubitat Node Server causes these errors? Expand Thank you for the help: Version 1.0.10
Javi Posted August 12, 2023 Posted August 12, 2023 I have notified the developer about the issue. Being as there are multiple reports for the same issues, I suggest posting on the Hubitat subform so that the Node Server Developer can respond directly. https://forum.universal-devices.com/forum/426-hubitat/
