status is "Ready to Arm" when Elk is not ready to arm
Since 5.7.0 New issue.  Elk Module says status is "Ready to Arm" when Elk is not ready to arm.  Now the whole thing is wonky again.  Ugh....
Solved by CoolToys
Put in a ticket. UDI wants to see it and fix it for the rest of the users.
Are you talking about Elk Module or Elk node server? The Elk Model is most likely not supported in v5.7.0.
Sorry @DennisC, you are correct, I meant to say Elk node server.  @larryllix, I am on the road a lot, and have not reconfigured my VPN so I will have to wait until I get home to double check I didn't make a change and that the Elk M1 thinks it is transmitting, and then submit a ticket.  Probably Wednesday or Thursday before I can get to it.
@Geddy, Sorry I did search for Elk first and found nothing.
Well this is embarrassing....I had the "free" 30day trial, and it expired.  Paid for the node server, Elk problems solved.
