z-wave groups, scenes and associations
i set up my eisy using 5.6.4
just updated to 5.7.0
i only use z-wave for water detection, smoke/co2 detectors and blinds
i have 4 repeaters installed
i want to have 3 blinds open or close at the same time - these are iblinds z-wave motors
they install to the eisy as either of these two device types
image.png.8b4194d6b40ea7ef0c675dc5a2d596f0.pngimage.png.6faea63b3ef0f1ea55a22d684b1b1e3b.png
Z-Wave Command Classes
iblinds Supported Command Classes – cc:5E,85,59,86,72,5A,73,26,25,80,70
Command Class Association Group Info V2
Command Class Association V2
Command Class Basic V2
Command Class Battery
Command Class Device Reset Locally
Command Class Manufacturer Specific V2
Command Class Powerlevel
Command Class Switch Binary
Command Class Switch Multilevel V4
Command Class Version V2
Command Class Z-Wave+ Info V2
iblinds V2 Product Details
Z-Wave Specific Device Type: Window Covering – Endpoint and Position Aware, CLASS_B_MOTOR_CONTROL Z-Wave Generic Device Type: Multilevel Switch
Z-Wave Role Type: Listening Sleeping Slave
Manufacturer ID: 0287
Product Type ID: 0x0003
Product ID: 0x000D
and
SWITCH_BINARY SUPERVISION
ASSOCIATION V2 FIRMWARE UPDATE MD V5
ASSOSCIATION GROUP INFO BATTERY
TRANSPORT SERVICE V2 MULTILEVEL SWITCH
VERSION V2 CONFIGURATION
MANUFACTURER SPECIFIC INDICATOR V3
DEVICE RESET LOCALLY Z-WAVE PLUS INFO V2
POWERLEVEL MULTI CHANNEL ASSOCIATION V3
SECURITY V2 WINDOW COVERING V1
iblinds V3 Product Details
Z-Wave Specific Device Type: Window Covering – Endpoint and Position Aware, CLASS_C_MOTOR_CONTROL
Product Type ID: 0x0004
Product ID: 0x0071, 0x0072
reading this
https://www.vesternet.com/en-us/pages/z-wave-groups-scenes-associations
i should be able to use a group to open/close all 3 blinds with one command
i have individual blinds in an insteon scene with a keypad button and that seems to work
adding 3 blinds to an insteon scene does not
the blinds will open /close with alexa
the manufacturer said it should work, depending on the controller
i have not seen a direct answer here when asked about setting up associations, groups or z-wave scenes - other than 'if it supports it there will be an option in the drop down menu in the scene' - and not sure anyone has seen that on any device
x-ray node definition
<nodeDefs>
    <nodedef nls="119" id="ZY066_1">
        <sts>
            <st editor="_51_0_R_0_101_N_IX_DIM_REP" id="ST"/>
            <st editor="_51_0_R_0_100" id="BATLVL"/>
            <st hide="T" editor="ZY_ERR" id="ERR"/>
        </sts>
        <cmds>
            <sends>
                <cmd id="DON"/>
                <cmd id="DOF"/>
                <cmd id="FDUP"/>
                <cmd id="FDDOWN"/>
                <cmd id="FDSTOP"/>
            </sends>
            <accepts>
                <cmd id="DON">
                    <p optional="T" editor="ZY_DIM_PERCENT" init="ST" id=""/>
                    <p optional="T" editor="ZY_RR" id="RR"/>
                </cmd>
                <cmd id="DOF"/>
                <cmd id="DFON"/>
                <cmd id="DFOF"/>
                <cmd native="F" id="BRT"/>
                <cmd native="F" id="DIM"/>
                <cmd id="FDUP">
                    <p optional="T" editor="ZY_DIM_PERCENT" init="ST" id="STARTLEVEL"/>
                </cmd>
                <cmd id="FDDOWN">
                </cmd>
                <cmd id="FADE">
                    <p editor="ZY_MLS_DIR" id="DIR"/>
                    <p optional="T" editor="ZY_MLS_DIR" id="DIR2"/>
                    <p optional="T" editor="ZY_RR" id="STEP2"/>
                </cmd>
                <cmd id="FDSTOP"/>
                <cmd id="QUERY"/>
                <cmd id="CONFIG">
                    <p editor="_107_0_R_0_255" id="NUM"/>
                    <p editor="ZY_CONFIG" id="VAL"/>
                </cmd>
                <cmd id="WDU"/>
            </accepts>
        </cmds>
        <links>
            <ctl/>
            <rsp>
                <link gid="ASSOC" linkdef="ASSOC"/>
                <link gid="ASSOC" linkdef="ASSOC_MC"/>
                <link gid="BASIC" linkdef="BASIC"/>
                <link gid="BASIC" linkdef="BASIC_MC"/>
                <link gid="MLSW" linkdef="MLSW"/>
                <link gid="MLSW" linkdef="MLSW_MC"/>
            </rsp>
        </links>
    </nodedef>
</nodeDefs>
associations
All Assocations for node 66 (0x42)
Assocation version=2 groups=1
 | Group  1 : max=1   [01]
device object
Z-Wave Database for uid=66.0 (0x42.00)
Isy Primary Node: id=226 addr=[ZY066_1]
ZW-Type: 4.17.0 (0x04.0x11.0x00)
Mfg Specific: mid=647 tid=3 pid=13
ZWave+ RoleType=0 NodeType=0
Flags: initialized=T agi=F alwaysAwake=F
Security: No Security
--- 12 Command Classes ---
    32  x20 V2 I S       BASIC
    37  x25 V2 I S       SWITCH_BINARY
    38  x26 V4 I S       SWITCH_MULTILEVEL
    89  x59 V2 I S       ASSOCIATION_GROUP_INFO
    90  x5a V1 I S       DEVICE_RESET_LOCALLY
    94  x5e V2 I S       ZWAVEPLUS_INFO
   112  x70 V0 I S       CONFIGURATION
   114  x72 V2 I S       MANUFACTURER_SPECIFIC
   115  x73 V1 I S       POWERLEVEL
   128  x80 V1 I S       BATTERY
   133  x85 V2 I S       ASSOCIATION
   134  x86 V2 I S       VERSION
--- 2 AGI ---
  grp=  1 cc=0x80.03 profile=0x00.01 maxRsp=1  /1   BATTERY
  grp=  1 cc=0x5A.01 profile=0x00.01 maxRsp=1  /1   DEVICE_RESET_LOCALLY
--- Status Map (3 records) ---
[ 0] 0x26/SWITCH_MULTILEVEL    recId=1      sgid=119 ST       uom=51 prec=0 namemap=27 | min=0 max=101
[ 1] 0x25/SWITCH_BINARY        recId=1      sgid=147 ST       uom=78 prec=0 namemap=0 | predef=2
[ 2] 0x80/BATTERY              recId=1      sgid=119 BATLVL   uom=51 prec=0 namemap=0 | min=0 max=100
--- Control Map (0 records) ---
--- Responder Map (10 records) ---
[ 0] sgid=119   ASSOC   ASSOC           (1,  1)
[ 1] sgid=119   ASSOC   ASSOC_MC        (1, 51)
[ 2] sgid=119   BASIC   BASIC           (2,  2)
[ 3] sgid=119   BASIC   BASIC_MC        (2, 52)
[ 4] sgid=147   BSW     BSW             (3,  3)
[ 5] sgid=147   BSW     BSW_MC          (3, 53)
[ 6] sgid=119   MLSW    MLSW            (4,  4)
[ 7] sgid=119   MLSW    MLSW_MC         (4, 54)
[ 8] sgid=259   SCENE   SCENE_RSP       (5,  6)
[ 9] sgid=259   SCENE   SCENE_RSP_MC    (5, 56)
--- Status Callbacks ---
[ 0] 0x25/SWITCH_BINARY        id=0        path="level"
[ 1] 0x26/SWITCH_MULTILEVEL    id=0        path="level"
[ 2] 0x80/BATTERY              id=0        path="last"
--- Control Callbacks ---
device/channel database object
    32  x20 V2 I S       BASIC
--- 2 AGI ---
are these devices installing correctly?
how can i create a group with all 3 blinds to respond to an open/close command from my eisy?
its z-wave - each command is slow and waits for nack/ack - tried lots of things
 if i could assign the devices to a common association group, one command to that group should operate all the devices at one time
but i cannot find a way in the eisy to assign devices to a association group
when a discussion gets close to asking, the thread is ghosted and closed
thought i'd try the direct question
incidentally - i can create an eisy scene and add the z-wave blind - add a keypad button - and it works - and it works with alexa
gets more complicated with 3 blinds with one button
these are opened/closed at sunrise/sunset - rarely any other way - you have to add a 5-8 second delay between z-wave commands
but still - association groups are the closest thing to insteon scenes - and i suspect lots of people here would pee their panties if we could implement them - lots of people want virtual 3-way switches and this should accomplish that for them
the web link above is the easiest explanation of associations, groups and scenes in the z-wave world that i have found
i contacted the iblinds seller and he said the blinds had the capability - and should work IF the controller can handle it - so i posted the specs of how the devices install and the command sets the devices support - and some of the xray screen shots of how they installed on my eisy
i don't see any way to do it in the eisy unless it is setting some parameters'
i suspect it does not support it - which is why the replies stop
i also suspect others have other controllers then swap controllers to primary or use zooz sticks then transfer - none of which i an interested in doing
i have resisted a deep dive into z-wave - and so far been successful
be nice to have an answer without having to learn the internals of z-wave - if i understand it correctly, z-wave is not an open system and could be why people are not free to discuss it online
I really doubt I can help you here (it's been a long time since I did this), but I still use associations for some Z-Wave lights in a bathroom.
One of the dimmers controls two others (these are Zooz Zen77 dimmers).  You have to put all the devices in a scene in your eISY, and one of the devices has to be the controller.  You need to put the "Basic Association" nodes you want (sometimes there is more than one - in my case I have one for on/off and one for dimming) of the controlling device into the scene as controllers, and then the other devices as responders.  See screenshots.
This seems to be mostly reliable (on/off is reliable, but dimming is a bit hit or miss).  It's not as seamless as an Insteon scene by any means.  I believe the devices have to be in close proximity to one another for this to work, and the devices talk directly to one another, not through your ISY software.
aha -  huge step forward
how did you get the association set up - that caused the entry names 'basic assoc 2' or 3
I've been experimenting with Zwave basic associations using on/off switches, and yes there is a way to do it, but your device has to support it.  When you add a device, if associations are supported, you should get one of the "Basic Assoc" nodes shown above, and these are what you use to directly link multiple devices in a group.
i asked the device manufacturer before starting this thread.  and seeing little help here.  this is what they said:
iBlidns supports Associaton, but there is a catch: the Associated controlling device needs to support beaming (have the ability to send a special command to wake up the iblidns motor). It's also important that the Z-Wave hub follows the correct process when making the Z-Wave associations.   We've noticed that most hubs don't.
Here's an article written by Dr.Zwave: https://drzwave.blog/2021/02/01/controlling-flirs-via-associations/
the cited article is a little over my head, but it seems that if supporting the 'flirs' is part of the standard but not supported here.  i am thinking that my step 1 is getting any kind of association set up.  i see where others have done it here but they have an option under the dropdown menu (when in an insteon scene) for some z-wave options.  nothing on my system has any z-wave option.  which is why i posted the manufactures specs on what it should support and the xrays on how the iesy did install.  i was hoping that might identify if the devices are installing correctly.
that was the way my pointy head reasoned out the problem.
i don't use much z-wave but before i began, installed 4 repeaters.  aeotec v6.  ordered the same brand in v7 so i can rule out z-wave versions as being a problem.  they should arrive tomorrow.
thanks for the reply
it would be interesting to know what command class supports associations - and what z-wave version - and what device types
then if it supports the beam or flirs or wakeup call to the device
then its on to return routes
i think the article on that uses a zooz software (controller and zooz usb radio) which would be z-wave centered - notsomuch with the eisy
looks like my first step is to find out why my devices install without the additional entries for association
during the include (or 'interview'), what needs to be passed to the eisy for it to add those entries?
thanks @brians for reporting his research
replaced my repeaters
ordered a zooz s2 stick
downloaded silabs simplicity studio
The current in-force specification package for certification is available here.
hopefully - set up zooz stick with simplicity studio - include zooz into iesy z-wave network
and that will import the devices into the pc controller
set up group associations on the pc
export those changes to the eisy
control that group from the eisy
I'll be interested on how this works for you.  Even more so on how you include the Zooz stick into the eisy z-wave network.  Will Simplicity Studio let you put the Zooz stick in Association mode that you can discover with eisy?  Then once the HomeIDs are aligned it sounds like you're going to use Simplicity Studio to reach into the z-wave device without having to use IoX?  I wish I had a Development platform to play with, all I've got is Production running my entire house so I hate to screw anything up.  Epically on a Sunday!  <lol>
reading this again
its obvious that ud does not install most z-wave devices correctly - though they will never comment on it - and do not want to get into associations and groups and scenes
i plan to set up the pc controller - add it to the eisy - set up the associations and test
then do another 'interview' on the eisy and see if it picks up the associations and creates a resource to control that group of associations from the eisy
then - to push my luck - set up an insteon scene with the blinds and a keypad button to control the blinds - then - get really greedy - and expose it to alexa
i have one need for z-wave associations or groups or scenes - to open/close 3 blinds with one command - if i needed more than that, i would not do it - unless i accepted the fact that all the z-wave stuff would have to be documented carefully and set up/modified from the pc controller
if i used mostly z-wave, i'd get a different controller and not use the eisy
i am not interested in the basic association that does not involve a controller like the eisy - i want to control it from the eisy - there are other associations where the controller is involved and the devices do not have to be in range of each other
it might require setting up a return route if the eisy does not send a wakeup before the command to control the device - adding the return route does that - i can set up that return route with the pc controller - however - i doubt the eisy 're-interview' would know about the return route - or what to do with it if it does know about it - so a wakeup might not flow from the eisy
the pc controller has a sniffer capability so i can probably see what it is and is not sending
I broke down & added the PC Controller to the eisy z-wave network but it didn't populate with the existing z-wave devices on the matter dongle.  Maybe I didn't wait long enough?  Please post if you get it to work.
Thanks everyone for your extensive research on this.
If you can find a way to get Group 2 Associations working using the Zooz stick, we should present this to UD (as their promise was to have associations working under eisy or Polisy the same way).  I too suspect there's something missing in their application.
got my xoox s2 stick 700 today
connected it to my pc - opened silamb pc controller (tools - z-wave pc controller) - associated the stick with the pc controller
opened eisy - opened event viewer (3 - device communications events)
network management - select learn mode (button) - nwi (button)
eisy - z-wave - add a z-wave device
got this
these are the devices listed in my eisy
note the zy 074 controller entry was added to the eisy
the eisy is the primary controller - pc controller is secondary
this is what was added to the pc controller
in the pc controller - the node info for the eisy
in the pc controller - the node info for the pc controller itself
interesting
turning to the 3 blinds i want to group - device numbers 62, 63 and 64
focusing on one device - 62
eisy xray - device /channel database object
Z-Wave Database for uid=62.0 (0x3e.00)
Isy Primary Node: id=426 addr=[ZY062_1]
ZW-Type: 4.17.7 (0x04.0x11.0x07)
Mfg Specific: mid=647 tid=4 pid=114
Security: S0 S2Unauth
--- 18 Command Classes ---
    32  x20 V2 I S   Sec BASIC
    37  x25 V2 I S   Sec SWITCH_BINARY
    38  x26 V4 I S   Sec SWITCH_MULTILEVEL
    85  x55 V2 I S       TRANSPORT_SERVICE
    89  x59 V3 I S   Sec ASSOCIATION_GROUP_INFO
    90  x5a V1 I S   Sec DEVICE_RESET_LOCALLY
   108  x6c V1 I S       SUPERVISION
   112  x70 V4 I S   Sec CONFIGURATION
   114  x72 V2 I S   Sec MANUFACTURER_SPECIFIC
   115  x73 V1 I S   Sec POWERLEVEL
   122  x7a V5 I S   Sec FIRMWARE_UPDATE_MD
   128  x80 V1 I S   Sec BATTERY
   133  x85 V2 I S   Sec ASSOCIATION
   134  x86 V3 I S   Sec VERSION
   135  x87 V3 I S   Sec INDICATOR
   142  x8e V3 I S   Sec MULTI_CHANNEL_ASSOCIATION
   159  x9f V1 I S   Sec SECURITY_2
--- 6 AGI ---
  grp=  1 cc=0x80.03 profile=0x00.01 maxRsp=5  /5   BATTERY
  grp=  1 cc=0x5A.01 profile=0x00.01 maxRsp=5  /5   DEVICE_RESET_LOCALLY
  grp=  1 cc=0x71.05 profile=0x00.01 maxRsp=5  /5   NOTIFICATION
  grp=  1 cc=0x25.03 profile=0x00.01 maxRsp=5  /5   SWITCH_BINARY
  grp=  1 cc=0x26.03 profile=0x00.01 maxRsp=5  /5   SWITCH_MULTILEVEL
  grp=  1 cc=0x6A.04 profile=0x00.01 maxRsp=5  /5   WINDOW_COVERING
[ 0] 0x26/SWITCH_MULTILEVEL    recId=1      sgid=107 ST       uom=51 prec=0 namemap=27 | min=0 max=101
[ 2] 0x80/BATTERY              recId=1      sgid=107 BATLVL   uom=51 prec=0 namemap=0 | min=0 max=100
--- Responder Map (18 records) ---
[ 0] sgid=107   ASSOC   ASSOC_S2UN      (1, 41)
[ 1] sgid=107   ASSOC   ASSOC_MC_S2UN   (1, 91)
[ 2] sgid=107   BASIC   BASIC_S2UN      (2, 42)
[ 3] sgid=107   BASIC   BASIC_MC_S2UN   (2, 92)
[ 4] sgid=147   BSW     BSW_S2UN        (3, 43)
[ 5] sgid=147   BSW     BSW_MC_S2UN     (3, 93)
[ 6] sgid=107   MLSW    MLSW_S2UN       (4, 44)
[ 7] sgid=107   MLSW    MLSW_MC_S2UN    (4, 94)
[ 8] sgid=107   ASSOC   ASSOC_S0        (1, 11)
[ 9] sgid=107   ASSOC   ASSOC_MC_S0     (1, 61)
[10] sgid=107   BASIC   BASIC_S0        (2, 12)
[11] sgid=107   BASIC   BASIC_MC_S0     (2, 62)
[12] sgid=147   BSW     BSW_S0          (3, 13)
[13] sgid=147   BSW     BSW_MC_S0       (3, 63)
[14] sgid=107   MLSW    MLSW_S0         (4, 14)
[15] sgid=107   MLSW    MLSW_MC_S0      (4, 64)
[16] sgid=107   ASSOC   ASSOC           (1,  1)
[17] sgid=107   ASSOC   ASSOC_MC        (1, 51)
pc controller shows
the device specs from the manufacturer
SECURITY V2
WINDOW COVERING V1
note that the associations classes (and others) are missing in the pc controller (the devices are added to the pc controller by querying the eisy - not by 'interviewing' or adding each device by having the pc controller querying the devices themselves)
secondary controllers are not allowed to add devices (unless you set specific parameters that i am unfamiliar with)
i have been looking for a way to have the pc controller 'interview' the devices to see if it added the command classes the device supports - no success as yet
and looking for a way to modify the command classes of devices in the pc controller - no success yet
it would be interesting to undo the connection and add one of the devices (i have some new ones) to the pc controller with the pc controller as primary - might have to do that
as i understand it, in the pc controller i can set up or modify associations (main menu - associations tile) - that window lists nothing eligible for associations (not surprising since the eisy did not return those command classes to the pc controller)
i have repeaters, water detectors, smoke/co2 detectors and these blind motors - that is it - not one listed as association eligible in the pc controller
the silabs tool has a z-wave sniffer - i'll look into running the sniffer as the eisy is adding the pc controller and sending the device information - that will tell me if the pc controller is not asking for all the info - or if the eisy is not sending the info
pages 62 and 63 of this guide
https://www.silabs.com/documents/public/user-guides/INS13114.pdf
detail what primary and secondary controllers are allowed to do
this is interesting - the blind motors i an working with are their newest - version 3 - i have a couple of their version 2 devices - and here is the info in the pc controller for the older devices
association command classes are there (you evidently have to select the node info button to populate the info)
and now they are on the associations panel of the pc controller
that node info query is issued from the pc controller stick
the eisy xray of device/channel database object of device 58 (old motor version)
Z-Wave Database for uid=58.0 (0x3a.00)
Isy Primary Node: id=419 addr=[ZY058_1]
    32  x20 V2 I S       BASIC
--- 2 AGI ---
i'll investigate the difference when the device adds specific device class 0x07 instead of 0x00
and here is a thought - i think the security has to be the same level for this crap to work - i'll investigate that rabbit hole too
after that - i'll have to look into setting a return route - but it will have to be to the eisy radio - not the pc controller radio - i think that can be done with the pc controller - from what i think i know now
interesting - database object for new devices (that show fewer command classes and no association capability
--- 6 AGI ---
and the older device
--- 2 AGI ---
note that window_covering is missing from the older devices
from the z-wave alliance specifications book linked way above
2.2.16 Basic Window Covering Command Class, version 1 [OBSOLETED]
Warning: THIS COMMAND CLASS HAS BEEN OBSOLETED
New implementations MUST NOT support this command class.
New window covering device implementations SHOULD support the Window Covering Command
Class, version 1.
however - there is a new window covering command class
2.2.117 Window Covering Command Class, version 1
The Window Covering Command Class is used to control window covering devices.
The Window Covering Command Class is an actuator control command class. Refer to Section 2.1.6.
2.2.117.1 Terminology
A window covering device may be closed or open. The term closed represents the lowest light throughput,
while open represents the highest light throughput.
A window covering device may provide one or more properties such as up/down movement combined
with for example slats angle control.
Each of the available properties is advertised. A window covering device may offer precise control of
the position of a property or it may offer a more limited movement control, where it is possible to
start and stop movement in one of two directions but where the target position cannot be specified.
If a window covering parameter is marked as position unknown, this indicates that the actual property
can only be controlled via start and stop of movement.
The parameters controlling edges are identified as outlined in Table 2.529.
neither is listed in any of the queries as a command class so its probably not a problem
the really good news is i don't know unix - got as far as grep and decided that cleaning bathrooms was more fun
notes to self
hmmm - agi  - looks like that is association group information
listed in the command classes for the older devices (in pc controller) (that do show up in the pc controller on the associations tile) but not the newer devices
looks like there might be an import problem between the pc controller and the eisy
installing a blind motor on a virgin pc controller would be interesting - but that is a lotta work - sigh
altering the pc controller as it is now to allow installs to the secondary is iffy - those portable device are to be wirelessly connected - but pc controller has it listed - i'd have to bone up on how it works before screwing with that
the new devices show the command class for window covering v1 but the eisy does not show that
all the stuff about installing devices 'close to the eisy' is crap - install it where it will reside
I read through this thread with great interest since I have new Bali Z-Wave shades and was planning to connect them to EISY/Zmatter. I purchased the Bali ZWave controller and have the shades connected to it currently but would like the additional flexibility/control that EISY provides. Here are my observations on how things work with the Bali ZWave controller -
- Using the Bali Zwave controller with their App there is no way to group shades together for simultaneous control. The App allows you to control each shade individually where they each move independently. Moving the shades to an end point is not a problem since they will all end up at the end point eventually. You can also have the shades go to an intermediate point although this is not a precise point since it is controlled by a slider for each shade.
- I connected the controller to Alexa which works fine but is similar to controlling the shades with the App. To get the Shades to all move as a group I have to add each shade as a separate Action in the associated Alexa Routine. When the Alexa voice command is issued each shade (in my case 4) start moving at different points in time and eventually go to the same end point. It looks a bit weird while moving. Alexa routines do allow you to specify a % open which works quite well. The Bali App does not allow a % (just an approximate slider position for each shade).
- I also purchased the premium remote with the shades and it has different behavior than the Gateway/App. The instructions are very explicit that when you add the remote it has to be added after all of the shades have been added (paired) to the Controller/Hub. The process for adding the remote is to first pair it with the ZWave controller/Hub and then pair it separately with each shade. Once each shade has been paired with the remote you can then create "Channels" in the remote to "associate" shades into groups. The remote then issues commands to individual channels where all shades move and stop synchronously. In my case I have 10 shades and 3 channels, 2 channels of 4 and 1 channel of 2 shades.
Based on RPerrault's description of ZWave Association, I suspect the remote is being added to each shade as a secondary controller which supports the ZWave association function. I also suspect the ZWave ControlIer/Hub does not support the Association function since no grouping of shades is possible in the Bali App. I should add that you can purchase the shades without the ZWave controller and only use a remote to control them. In this case it is likely that the remote is the primary ZWave controller and still includes the Association function.
At this point I haven't decided if I will transition the Shades to EISY based on the experience RPerrault described in this thread. I'm well aware that I can write programs to create the virtual groups Scenes) of shades but with the underlying problem of issuing commands over a spaced out interval of time. If I decide to give it a try I'll report back on the status.
it could be that the interview process is not completing when including the device on the eisy (but for all the newer devices?)
from https://z-wave.me/files/manual/z-way/Introduction.html#
"The interview process does not only detect all information from the device; it also tests the connectivity of the device. Certain communication may fail. Another good reason for such a failure is that a battery-operated device goes into deep sleep mode too fast. ... In most cases, it’s OK to just redo the interview and wake up the device.
If the second attempt at the interview fails, the controllers gives the option to accept the result or to redo the entire process."
i suspect the eisy makes the decision for us and does not notify if the process does not completely finish - just a thought on why all the command classes are not present
ok - so where do we get the info from the interview?  the device returns some device type info that determines what command classes the device supports
the eisy shows all the command classes for the newer blind motor - all agree with the manufacturer's claim except one
window covering v1
but -
"Window Covering Generic Device Class (Not recommended)
NOTICE: It is not RECOMMENDED to use this generic device class for new devices. Instead, it is RECOMMENDED to base devices of this category on the Multi-level switch generic device class with the Multi-position Motor specific device class."
and it seems the eisy does use the multilevel switch to control the blinds, as recommended
it looks like the eisy knows all the command classes from the devices - the pc controller does not (it got the info from the eisy - not from its own interview with the devices)
the device information is sent to the pc controller when you include it to the eisy - the information is correct for the older blind motors, but not the new
the eisy is not interested in helping us with associations and groups and scenes - which is why i thought i could set up those from the pc controller - but the correct command classes are not present in the pc controller - the pc controller does NOT have the newer motors as eligible for associations because the command classes are not there - it DOES show the older motors as eligible but those are not the ones i want to group together
so what about the posts on having a drop down menu selection for z-wave associations
"Please see @mmb's image above, note the dropdown with Default. For each device in a scene, you will see at least Default and Command. Now, click on the switches within the scene, in the picture above ZW_024. You will see the same dropdown. Now, if the switch supports Z-Wave scenes, you will see Z-Wave Scene in the drop down (but this is rare). If the device supports it, you will also see Z-Wave Association (much more prevalent). In short, if and only if your device supports it, you should use either Z-Wave Scene or Z-Wave Association. If your device does not support it, you will not see those options."
i have both older and newer blinds motors in scenes - neither show the z-wave associations option - i suspect the only devices that DO have that option are sensors - even though other devices do support associations
even so, i don't understand why that option would be there because i don't see a way to set up associations in the eisy - or maybe selecting that option sets up the association (i doubt that) - i also wonder what selecting that option would do if it is present
back to my plan - to set up the association outside the eisy - then on the eisy, interview with update - since the pc controller does not show the motors as eligible for association, that won't happen (it does not know about the correct command classes sent from the eisy)
older devices
newer devices
or maybe the pc controller builds its own command class list from the device classes
i don't see a way to modify the command class list for devices in the pc controller (to add the missing command classes for the newer motors)
might have to look into the z-way tool
