Flashing green light cant find isy
The Second or Third Light Is Blinking
  • Signature failure
  • Old BIOS
Please contact support.
The Third Light Is Constantly On While Everything Else Is Off
  • This means that that flash chip is corrupted
  • Request a Flash Chip from support@universal-devices.com
  • Once received, unplug Polisy, open the screws on the four corners, and install it as shown in the image below
  • Plug Polisy back in
  • Immediately after the unit is up and while still plugged in, unplug the Flash Chip, then SSH to polisy and run the following commands:
    • sudo pkg update && sudo pkg upgrade and wait for completion
    • sudo /usr/local/etc/udx.d/static/udxops.sh update.bios.force
    • Wait for the unit to reboot
I have had similar findings with an ISY99i and ISY994i.
Bad power supply and flashing power on led.
On 2/16/2024 at 9:14 AM, Blackbird said:
I did that and Michel suggested trying a different power supply and that worked.  Very thankful for all of your help and his.
Oh man, so happy I found this thread.  I was in a panic yesterday morning.  Thanks to Amazon, $7, and same day delivery, I was back up and running by dinner time.
Amazon power supply for Polisy
Edited by carealtor
fix link
I see this power supply rated at 0.6A.  Glad it's working, but the power supply recommendation for Polisy, from Michel, is for it to be rated up to 2.0A.
Well, I just checked my original power adapter that came with the Polisy and it's 1 amp.  It appears the original and the adapter I bought on Amazon are EXACTLY the same adapters.  No argument from me that a 2 amp might be better for longevity.
