Lightning Strike near house
I lost two 2477D's when lighting hit near my home and tripped a breaker. They are both exhibiting the same behavior: The Load wire is always hot now regardless of the status or what is pressed on the paddle. I was wondering if there is any mechanism in the circuitry that might cause this? Does it need to be opened and some sort of breaker reset? I opened one of them and didn't see any visible signs of damage, so it made me wonder if there was any other mechanical or memory reset that may need to be tripped.
Thanks in advance!
Edited by smithlevenson
If these devices have triacs in them, they could be blown, which often causes them to be shorted out and appear as being on constantly.
You can try doing a factory reset on the switch, then a restore device. If that doesn't fix the issue then It's possible that a component in the switch was damaged by the volltage surge in which case you'll need to replace the switch
The switch uses triacs.
Edited by Techman
If the status on your controller appears to be correct but the load is always on, then that's a good indication that the control electronics survived, but the power triac didn't. That would usually be repairable.
I too would suspect the shorted triac if everything else still looks OK.
I could not read the part number on it. In the FCC Database internal photos. It is mounted on one of the sides of the heat sink. With what looks like a rivet. It also shows a switching supply IC (LNK354GN) for running its electronics power source.
Edited by Brian H
Add information
I will check and see. It looks easy enough to test with a multimeter. Will report back.
I hate to repair something like a switch, but i am on ISY 994iz and the only new replacement looks to be the i3 Paddle. Upgrading the controller just to replace two switches feels bad, but my z-wave is already toast so it might make more sense just to get all my door locks back on the controller.
At worst, you might be able to turn it into a slave switch, if you have an otherwise good switch being used as a slave in a 3 way circuit somewhere else. Swap the switches and cap off the red load wire.
I have a few of these around the house.  I've re-purposed switches with bad triacs and bad paddle switches in areas where I don't need them.
I do "try" to put notes on the back of the switches to prevent me from re-re-purposing them (yes, this has bit me).
I tested the Triac and it has a short between 2 pins. I am not an expert so I am only going by what I could look up on YT, but apparently this is bad. I can't really see a safe way of replacing it since it needs a heat sink and a rivet to the case. I should be able to use two dummy switches to control 3 way's, but I will need one 2477 to actually control one of the lights. Probably not worth doing the full upgrade just for one switch.
Me too. Now I cut the red wire on bad triacs in my spares pile to within the literal inch of its life, so only a small wire nut can go on it and even I can't connect it to something 😜🤣
Has anyone ever replaced the triac on one of these? If so, do you have a triac part number? It looks like a regular TO-220 case. Just good stuff to know in case... It should be straightforward to drill out the rivet, unsolder it, and replace it.
Since it is dual band and has an RF section in it. You can find it in the FCC Database. Not overly clear but looked like a BTA12600S (cant see a possible letter following what I saw in the internal photos). That would be a TO-220.
https://apps.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Grantee SBP. Rest of the ID number. In this case. 2477D. Search and pick details. You should find internal and external photos. Probably more like other thing like test results and test photos. The parts list and schematics are confidential and you will not be able to find them. Should work with other ID numbers if dual band and have an RF section in them. Just a search of SBP alone should give a list of all modules in the database. Including the never released up dated PLM.
Edited by Brian H
Add a detail. Fix an error
I thought Insteon was originally open source and they had switch circuit board diagrams published. That also could have been a figment of my imagination. It's been a while.
You were pretty much spot-on Brian.  I opened up one of my old 2476D's.
Last letter is a "W".  BTA12-600SW.  Shows up OK below.  Looks much clearer with a 10x loop.
I don't think it was open source. Joe Dada and Smartlabs were extremely protective. I paid for a membership in the Developers Group. With a non disclosure agreement. Then after it abruptly ended most of all the documentation did end up online. They also didn't give UDI all the needed information on some modules. Like the Siren Module. That UDI reversed engineered and got pretty close to working near 100%. No firmware files where evver given out to upgrade your presently owned modules. Though you did need a programmer to mate with the 5 pin programming internal connector.
I can not comment on the present company. As I have seen nothing on good or still not giving the needed information.
Edited by Brian H
Thank you for checking the parts Id number. I knew it looked familiar. I believe it was in the older Lamplinc modules also. Module may have had a different wattage rating but that may have been differences in the heat sink.
Damn it. Now I am tempted to just fix the two bad Triacs. Not super pumped about having a re-soldered switch in my wall, but maybe I can use it right under a smoke detector ; ).
Have a close look at your switches before you start down this path.
  1. The PWB is inexpensive epoxy glass and rather easy to damage with heat.
  2. The Triac leads are bent at a right angle (you can see the bends in my photo) so the Triac can be riveted to the metal case and soldered into the board.  Save your old Triac so you have a "template" for bending the leads.
  3. You'll need a pop-rivet (or similar) and thermal paste to attach the new Triac to the AL case.
Not trying to talk you out of anything.  Just letting you know what is involved and what materials you'll need.
Absolutely. I am pretty sure I can manage it. I don’t love the thought of it in my walls, but no way would I use it if I wasn’t 100% confident the Triac was reinstalled to spec. I do appreciate the warning. It’s not a “simple” fix even though it is just one part soldered to a circuit board.
These are the specs for the triac in the current version of the 2477D Insteon wall Switch.  It can be purchased here at DigiKey BTA16-600CRG - Pinch
VALUE Rating
(Volts, Watts,
or Amps)
Tolerance Mfg Manufacturer Part #
16 Amp 600V Igt=25mA STMicro
BTA16-600C Standard
Chances are good that you would be able to use the triac out of an old X10 WS467 wall switch. Many of us have a box with several of those laying around, from our early automation days!
Don't count on it working.
The BTA12-600SW. Has a 10mA Logic Level trigger.
The standard one may not trigger correctly. Higher voltage or amperage rating would probably be fine. The 10mA Logic Level trigger maybe an issue. For the standard part.
Mouser has the exact part.  https://www.mouser.com/ProductDetail/STMicroelectronics/BTA12-600SWRG?qs=zgJYeb29rD5h9%2F6rjSG6BQ%3D%3D
Edited by Brian H
Add somethiing
