Login via https://isy.universal-devices.com/start.jnlp
I have forgotten how to save the java login as an icon on my desktop.
@aLf question is what computer OS are you running?
Windows, macOS, other?
Wiki directions: https://wiki.universal-devices.com/Main_Page#Quick_Start_Guides
Make sure you're using the basic Java you get when visting: https://www.java.com/en/ (current version 8 Update 421 - Don't download "crazy" java versions thinking a higher number is better...those are typically for only specific use cases. IoX Launcher is developed with "generic" java installed on standard operating systems.)
Depending on your computer operating system the process gets tricky if not Windows based.
Thanks.  My memory is good, but short and getting shorter.  Appreciate your help.
In addition to the above, I like to go to http://<I.P.address of eisy>:8080/admin.jnlp
This will load a direct icon to the admin console of your device and makes login much faster. Only works locally.
