Missing names in node definition
Any guess on why some yolink devices are missing the name in the node info (xray and rest/status) and others are not. For example, this leak sensor:
<properties>
        <property name="Sensor Temperature" uom="17" formatted="72&#xb0;F" value="72" id="CLITEMP"/>
        <property name="" uom="25" formatted="Dry" value="0" id="GV0"/>
        <property name="" uom="25" formatted="High" value="4" id="GV1"/>
        <property name="" uom="25" formatted="DON/DOF" value="0" id="GV2"/>
        <property name="Connection State" uom="25" formatted="Online" value="0" id="GV20"/>
        <property name="Nodeserver Status" uom="25" formatted="Connected" value="1" id="ST"/>
    </properties>
It is not a problem with the admin console because that has all the names right:
This Temp Humidity sensor has all the names filled in:
    <properties>
        <property name="Battery Level" uom="25" formatted="High" value="4" id="BATLVL"/>
        <property name="Current Rel Humidity (%)" prec="1" uom="51" formatted="43.3%" value="433" id="CLIHUM"/>
        <property name="Sensor Temperature" prec="1" uom="17" formatted="73.2&#xb0;F" value="732" id="CLITEMP"/>
        <property name="Low Temp Alarm" uom="25" formatted="Normal" value="0" id="GV1"/>
        <property name="Low Temp Limit" prec="1" uom="17" formatted="64.4&#xb0;F" value="644" id="GV10"/>
        <property name="High Temp Limit" uom="17" formatted="95&#xb0;F" value="95" id="GV11"/>
        <property name="Low Humidity Limit" uom="51" formatted="0%" value="0" id="GV12"/>
        <property name="High Humidity Limit" uom="51" formatted="100%" value="100" id="GV13"/>
        <property name="High Temp Alarm" uom="25" formatted="Normal" value="0" id="GV2"/>
        <property name="Low Humidity Alarm" uom="25" formatted="Normal" value="0" id="GV4"/>
        <property name="High Humidity Alarm" uom="25" formatted="Normal" value="0" id="GV5"/>
        <property name="Battery Alarm" uom="25" formatted="Normal" value="0" id="GV7"/>
        <property name="Alarm triggered" uom="25" formatted="Normal" value="0" id="GV8"/>
        <property name="Command Setting" uom="25" formatted="DON/DOF" value="0" id="GV9"/>
    </properties>
I have the latest everything and restarted everything.
Andy
I found the difference  - I use global naming for some of the common parameters - these do not seem to propagate to the REST - but works with AC.
Not sure if global naming is supported but it works with AC
Maybe ask UDI if it is a bug or if I cannot use global naming
I'll fix it if global naming is not supported (but it is some extra work (and a lot of testing) -
2 minutes ago, Panda88 said:
i believe it is real.   it is not the nls file is parsed.   i am using global definition for some common nodes.  it seems the rest does not pick this
Yes I've seen that. But my question is - Were you able to reproduce the problem?
This was the response I received from the ticket:
Chris Jahn
replied
3 hours ago
Hi Andy,
We are in the process of fixing and enhancing the NLS capabilities for node servers.  Problems like this are fixed in the new code.
      37.3k
      373.6k
