Thermostate with Humidity Sensor Error Reading
  • 3 months later...
Hmmm. I just found this thread after I replaced my 2.0 dongle with a 2.3 dongle on a Venstar 1900.
The 2.3 is not reporting humidity changes. I have to query it.
Plus the humidity it reports is about 10% more than with the 2.0. I just put it in so I'll have to watch this for a day or two to verify.
Any updates on getting automatic humidity reports like with the 2.0 dongle?
3.1.13
My 2.3 dongle reports humidity just fine without querying. In fact querying sometimes gets back a value of 2 x Cool setpoint which is bad. If you think the humidity is 10% too high then you can calibrate it from the thermostat.
Yes, it reports everything else automatically whether I change the set point or mode on the thermostat or with the ISY. And the thermostat reports inside temp changes automatically.
I may have jumped the gun on the high humidity reporting. Breathing on it too much, maybe. :oops: I still need to watch it for a day or so.
I did replace the dongle following the excellent procedure posted here. http://forum.universal-devices.com/viewtopic.php?f=26&t=6811&p=52014&hilit=dongle#p52014
If you think removing the thermostat from the ISY and setting it up again from scratch would help, I can try that. I just dont' want to do it unnecessarily.
D'oh! That got it. I wasn't familiar with that option; even though, humidity was being reported with the old dongle.
I guess the good news is you got the "report humidity" option working. :D
Thanks, as always.
