Difference between Polisy and EISY? Why upgrade?
I have been using a Polisy since it was first introduced.  I upgraded from the ISY 994i
What is the difference between my Polisy and the eisy? Why would I want to upgrade at this time (other than to take advantage of the price increase)
My primary use is managing Insteon devices and some programming
If you don't have a need to upgrade, not experiencing problems or limitation, I'd stay as you are. Not sure the time and $ involved would serve you vs investing in additional automations. Maybe proactively change your SD card in your ISY.
The product history is
- ISY 994
- Node server capability added years ago and a separate server was needed
- Policy became UDIs official method of hosting node servers
- eisy does both functions in one box
Edited by paulbates
Why change my SD card?
I don't have my ISY 994 anymore.  I am only using Polisy box.
Edited by EDilks
I am considering this as well, given the coming price hikes.  For those that have moved from Polisy to EISY, I'm curious is there's any difference in execution times. The Polisy and its predecessor have always an annoying lag when executing stuff via programs.
I'm also wondering if it's reasonable to consider the potential increase in nodes and the Matter/Thread rollout progresses. That could mean adding many more devices to Polisy.  Does EISY have higher capacity overall?
Any time lag perceived by a human is from the comm protocol being used. Insteon is a very slow protocol once you add in all the transmission security, echoing and retries of any bad device or noise picked up and translated to valid signals fr devices that don't exist. Of course it is fast enough in a clean system. I always needed to put in Wait 1-2 seconds between every group of 3 Insteon devices or buffers would overflow and lose commands and statuses.
WiFi and some other protocols are much faster.
ISY was only about 200 MHz CPU while polISY is aprox 1,000 MHz, and multi-processor core. It is not slow to a human.
The initial question hasn't been answered: how much faster is the eisy compared to the Polisy? It would be interesting to know.
From recollection when the eisy was released there is marginal differences on the surface level as far as IoX and Plugins are considered. I think all the underlying programming that UD handles is the same (or at least very close to identical).
The reason for the eisy introduction when it was released was lack of ability to source the hardware for the Polisy (one of those issues that can be blamed on covid and the supply chain issues that followed).
As stated above if you've got a working Polisy at this time just keep it updated. UD pledged to support the Polisy for several years after the eisy was released. That timeframe I do not recall for certain, but think it was several years. We are a couple of years since the eisy was released so expect the Polisy to continue to be supported for a few more years as long as UD can keep the code for the two devices similar.
I moved from Polisy to eisy when the eisy was released. I do not experience any difference in my use. I have a mid-size Insteon install (~70 nodes +/-), 6 z-wave devices, 4 zigbee devices, and maybe 5 plugins. I don't get crazy with programming or variables.
Since the underlying IoX code is identical there's no "speed" difference. I'm sure the device processing power might be different/better, but at the end of things IoX computes the change and sends signals out via the PLM so there's not any speed difference, at least probably not that a we could tell in the real world use (as @larryllix points out).
I think the answer may be the speed difference is irrelevant to any home automation user if you use any remote devices via a communications protocol.
If you want to listen to music while watching a 4K video and still have your HA operate at the same speed, there my be somewhat of a difference.
IOW: in polISY and eISY the CPU will be 95% of it's speed wasted, waiting for the comm line to talk to, or hear back from, it's peripheral devices.
Thanks for the replies, and that is pretty well what I expected: there there would be no real difference, at least as far as making an "upgrade" from Polisy to eisy worthwhile is concerned. I'm happy about that. I first got the eisy, and then came across a used Polisy with the ZMatter board that cost me little more than the ZMatter board itself. I have the Polisy as my "lab" system and as a standby spare if the eisy should die an untimely death.
The only thing that I'm jealous of Eisy owners over is the ability to connect an HDMI monitor and run a gui on FreeBSD.  That would be kind of cool, but tbh it would not make it work better as an automation controller than my Polisy does.  Or maybe if I were a plugin developer, doing it all on one device - with a gui - would be a step up.  But I don't have the chops - yet.  Now that I'm retired, though, who knows?
-Tom
-Tom
That's another purpose of my Polisy as a test controller: to learn plugin programming. I've done a couple of simple plugins to get the hang of it. It's a steep learning curve
theoretically, at some point we will get a http GUI that runs on the Polisy/Eisy box.  Perhaps the Eisy will perform better when this task is layered on top?  But I wouldn't think it would matter unless they really do something fantastic with the self-hosted web interface (like video and live action stuff vs just a console similar the java one).
Hello Forum folks.  I'm new to this forum however being a member for many years I still had to re-sign up due to credential issues. I've been using UDI 994 ISY for many years.  I've read the forum's responses to this (Polisy-EISY) topic and have learned nothing.  I'm a long time Insteon house and survived Insteon's fall and resurrection.  I purchased several more Insteon devices including, yes, the i series of devices.  To my disappointment, I learned the hard way, my ISY does not support these new devices.   Insteon support recommended I purchase UDI's latest product, the EISY.  Outside of still being totally incapable of discriminating between Polisy and EISY, all I really want to know is;  When I upgrade (to EISY or Polisy) will my existing programs and scenes be recognized without re-writing or altering them.   Any help is appreciated.
There is a migration process (UD links to it in their email release). Although you can also review the UD Wiki for the eisy user guide that has the migration process included.
https://wiki.universal-devices.com/Eisy:User_Guide
In typical migrations from ISY994 to eisy most Insteon is simply moved to the new device. Everything should look and act exactly the same. There are some issues that have been posted about here (probably a while back now), but I think the process is fairly straight forward and seems to work (the posts here about it not working might be rare cases because most won't come to the forums to post "it worked as described").
And the option of what to upgrade to is simple...only the eisy is available from UD at this time. The Polisy is no longer available. That's why this topic is asking about upgrading from the Polisy to eisy.
Thanks so much you guys for such a quick response.  I will enjoy looking at the links and their instructions.
Today, the main difference between Polisy and eisy are the hardware capabilities. On the software side, both are similar.
However, one big difference is that some of the upcoming features will only be available on eisy:
  • The matter-server, which allows to expose IoX devices to matter & homekit.
  • The new eisy-ui service
The new eisy-ui service will provide a unified access to IoX, PG3, and some of the portal features as well. It will also serve the new web UI which will allow you to have a web-based customizable dashboard-like UI. Eventually it will completely replace the java based admin console.
Polisy will still benefits from updates to IoX and PG3, but new features like the matter-servert and eisy-ui service will only be available on eisy as it needs that extra power thar eisy provides.
Thanks!  Thats exactly what I was looking for.  Purchase made!
I want to prepare my system for the migration to eisy. The instructions I have been given indicate I should start from a recent isy version before migration.  I figured that activity could be initiated from UDI console Help button.  I chose the only selection "Manually Upgrade Kelcher Smart Home" that came close.  It appears it is a backup function.  It appears the word Upgrade means Backup, right?   My question is how do I download the most recent isy version of software.  Any help is appreciated.
Is there an ETA on when we will be able to use Homekit?
- ISY 994
um - no love for the isy26?
ha nerdz are constantly begging for a constraint - but can never identify the constraint, just throw money into guessing until a 'solution' is found
bmercier gave the answer to the question
you are not cpu constrained - you are not memory constrained - the data bus architecture is not a problem - not wifi - not a slow powerline - all that stuff is speculation here
upgrade for new functions or features - or just because its fun
