shawnv Posted 18 hours ago Posted 18 hours ago Hi all, Been a long time ISY user, upgraded to EISY many months ago and it’s been working fine. Was running version just prior to the Matter upgrade (been waiting on that). Today, there was a several hour power outage. Power came back on and realized some things were not working (specifically Polyglot Ring integration). Attempted to login to Polyglot and got an error. Then tried the portal and EISY was connected there. Figured maybe it didn’t startup correctly when the power came back so went to reboot EISY… now nothing is online. Upon further investigation I was looking through UD mobile and saw that it stated “Upgrade in progress. Do not power off”. WTH? I didn’t invoke an upgrade, now it’s dead, cannot ping it, doesn’t show up anywhere…Ethernet port shows activity, but that’s all I have. Where do I go from here. Many thanks in advance for any help. I realize I’ll likely need to open a support ticket, but of course it’s the weekend. Quote
paulbates Posted 18 hours ago Posted 18 hours ago Based on your write-up, it seems that it's the eISY. One possibility is if there was a brown out, the hardware of the eISY could have been affected by that. Have you tried unplugging the eISY and the PLM, if you have Insteon. Wait 30 seconds... Plug in the PLM, wait 10 seconds and plug in the eISY? Quote
shawnv Posted 18 hours ago Author Posted 18 hours ago Thanks Paul, I haven’t done anything with the PLM. I cannot access the ISY, which, maybe I’m wrong but the PLM is a different branch that should not affect general connectivity via UD mobile, Java app, or portal. Quote
paulbates Posted 18 hours ago Posted 18 hours ago The PLM shouldn't affect the ISY, but if it was a brown out and it affected the eISY, it may have affected the PLM too. My comment was more about pulling the plug on the eISY versus rebooting as it could be the electronics affected, not the software 1 Quote
