General Question regarding integration
How well does this plugin work? I have several landscape lights and would like to create a cascading effect where each individual light turns on sequentially along a pathway through a program in the EISY.
@midrar from my personal use of the plugin it works fine. Others have had issues getting it to work or other issues, but for my simple setup this works fine. I haven't attempted to "cascade" lights, but having lights activate when other triggers occur has worked well since setting this up when I got my eisy.
Be sure you set an IP reservation for the Hue hub in your router so it is always at the same IP address. The plugin doesn't like if/when the hub IP changes.
  • 2 months later...
I've had no problem using this plug-in to turn on my hue lights with my Insteon switches and, closer to what you're doing, animating my yard lights to match audio explosions, etc.
      380.1k
