2852-222 leak sensor misses heartbeat, +future HA
Go to solution Solved by paulbates,
I have a 2852-222 leak sensor that has been working for many years.  I replaced the battery a couple months ago with a Lithium AA battery.  A week ago it missed heartbeats for a couple days.  I went and checked, and the battery is good.  I put it back in it's place figuring removing the battery would reset any issue.  It didn't, still missing heartbeat every day.  I went and got it today to test it.  When I view it in the ISY it shows Wet Off/Dry On as it should, and Heartbeat is On.  If I set it on a wet paper towel it shows Wet On/Dry Off.   So it appears to be working.  Is there a way to test the heartbeat?  I was planning to leave it upstairs with me for a day or two and see it resolves, but not sure why it is suddenly missing hearbeat...?
Also,  I have wondered for a while, what are people using for Leak Sensors these days?  Should I be looking for a different solution, wifi ones, or what?  I don't have a ton of Insteon devices but I have enough that I should be thinking of a migration strategy to something that is supported, but havent been following the state of the art in home automation for quite a few years now...  Any advice is appreciated.
-Tom
My experience with Insteon sensor, battery only devices, especially after long periods of use, is to factory reset them, right-click in iox and pick "restore device". Doesn't always work but easy to try and frequently fixes it
Thanks.  I just did restore device (before I read your message) just for kicks.  Is factory reset different or the same as Restore Device?
-Tom
I suspect you are saying I should do a factory reset on the device first (remove battery, hold set button, install battery) and THEN "restore device"?
Also, I noticed in the Program Summary that my other working leak sensors show "Running Then" in the Activity field for the Variable Control 2 program and have a Next Scheduled Run set for tomorrow for the Variable Control 3 program, whereas this (not working) sensor doesn't show "Running Then" or have a Next Scheduled Run time set...
-Tom
Yes.. factory reset then restore device. It also must be in linking mode first.
The "running then" is normal for the typical battery monitoring programs
Ok, I factory reset the device, put it in linking mode and did Restore Device.  I also rebooted the ISY for the fun of it.  Now the programs for this misbehaving leak sensor are also showing "Running Then" and a Next Scheduled Run time as well.  So hopefully it is back in sync.
Thanks for your help,
-Tom
A few years ago, I needed to replace several old Insteon leak sensors. I almost bought six but ended up transitioning to YoLink.
I've been very happy with them, and the YoLink plugin for the eisy. YoLink operates fine separately without the plugin if you're still running an ISY.
I got a couple of YoLink valve controllers and a temp sensor later. Everything works great.
Edited by auger66
I've also been using the Yolink leak sensors. Only a few months with them, but they seem to work well. I have some other YoLink temp/humidity sensors that I've been using for longer and they really operate good with the eisy + plugin. Since you posted in the ISY994 area it's not a product you would be able to integrate into the ISY as it does require the plugin to bring into the IoX/ISY system.
Outside of the ISY I do like the YoLink app (it's basic) and expect that with their hub and app you would be able to monitor  for and be notified of leaks easily. The range on the YoLink devices is fantastic. I expect battery life to be great as I have been able to get ~18 +/-months on the temp/humidity sensors.
Paulbates suggestion worked, after factory reset and restore the Leak Sensor started registering heartbeat again.
Thanks for the info and suggestion of the YoLink, I will look into it.   Thanks, Geddy for the further info.   I did some brief reading and if I understand correctly Home Assistant seems to be the way many people are moving for home automation.  I see that HA can integrate in with the ISY or newer UD systems as well as a host of others.  I assume that's the idea, one ring to rule them all...?  Seems like HA should be the next step I should take and I can keep my ISY if or until I decide to decommission it and it's devices and move to something else.  If I have the wrong idea on things please correct me.
Thanks again for all who helped.
-Tom
@Geddy I have an ISY and the Yolink plug-in and it works great.
However, I recently found that I can not add any new Yolink devices so that they appear in the ISY.  And, unfortunately, UD does not support the ISY.  This may be the straw that makes me switch to the EISY.
Ross
      378.5k
