NEW....Hue Bridge Pro (New Black Unit)
Hello all,
Well, the Hue saga never ends with me obviously.  I just updated to the New Black Hue Bridge Pro, and as you can see below, I am having nothing but problems getting it connected or even finding it.  I've done all the steps I've done previously with no luck.  Can someone let me know if the New Bridge Hue Pro works with the current plug-in.
2025-09-17 15:13:45.511 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message stop
2025-09-17 15:13:45.512 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING stop
2025-09-17 15:13:45.512 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS stop message {} from Polyglot
2025-09-17 15:13:45.512 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down.
2025-09-17 15:13:45.512 Thread-34 (stop) udi_interface INFO hue:stop: Hue NodeServer is stopping
2025-09-17 15:13:50.008 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: UDI interface initializing
2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: User=None
2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b902651c_1
2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b902651c_1
2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjU6MWMiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IkRFQlVHIiwidG9rZW4iOiJDbXo0c1JWcmZQKnpTJmFLIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjMuMjEiLCJpc3lWZXJzaW9uIjoiNS45LjEiLCJlZGl0aW9uIjoiRnJlZSJ9
2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: Loading interface module
2025-09-17 15:13:50.038 MainThread udi_interface INFO interface:<module>: Loading MQTT module
2025-09-17 15:13:50.529 MainThread udi_interface INFO interface:<module>: MQTT module loaded
2025-09-17 15:13:50.750 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module
2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading node module
2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading custom module
2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading isy module
2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading OAuth module
2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: UDI interface initialized
2025-09-17 15:13:50.752 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.18 Starting...
2025-09-17 15:13:50.754 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.3.21 [ISY: 5.9.1, Slot: 1]
2025-09-17 15:13:50.754 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.51', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}
2025-09-17 15:13:50.755 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883
2025-09-17 15:13:50.755 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version
2025-09-17 15:13:50.755 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b902651c_1.cert key: 0021b902651c_1.key ca: /usr/local/etc/ssl/certs/ud.ca.cert
2025-09-17 15:13:50.756 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: huebridge not found in database.
2025-09-17 15:13:50.756 MainThread udi_interface.interface INFO interface:addNode: Adding node Hue(huebridge) [None]
2025-09-17 15:13:50.756 MainThread udi_interface INFO hue:__init__: Started Hue Protocol
2025-09-17 15:13:50.758 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds.
2025-09-17 15:13:50.808 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success
2025-09-17 15:13:50.808 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:1c_1 - MID: 2 Result: 0
2025-09-17 15:13:50.849 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0']
2025-09-17 15:13:50.896 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getAll
2025-09-17 15:13:50.896 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getAll
2025-09-17 15:13:50.896 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '1220b861-bdaf-4e9a-b14a-b036e5f81906', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'customparams', 'value': '{"bridges":"[\\"192.168.17.253\\"]","Debug":""}', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.897 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:load: CUSTOM: load {'bridges': '["192.168.17.253"]', 'Debug': ''}
2025-09-17 15:13:50.897 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'cf26dfa8-0433-4556-88bb-22ca5caf8e17', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'customtypeddata', 'value': '{}', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.897 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:load: CUSTOM: -- checking bridges / ["192.168.17.253"]
2025-09-17 15:13:50.897 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'e8411887-ff53-4071-908d-1338a65fcda8', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'notices', 'value': '{}', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.899 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getNsInfo
2025-09-17 15:13:50.899 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:load: CUSTOM: -- checking Debug /
2025-09-17 15:13:50.900 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}
2025-09-17 15:13:50.900 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving
2025-09-17 15:13:50.900 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'df6ae4f6-0863-41f2-a051-a12910732623', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'nsdata', 'value': 'null', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.900 Thread-2 (parameter_handler) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2025-09-17 15:13:50.900 Command udi_interface.interface DEBUG interface:_handleInput: Key nsdata should be passed to node server.
2025-09-17 15:13:50.900 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Saved bridges information is not found
2025-09-17 15:13:50.901 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'c51c5480-5d5a-4624-9846-4b57d30d1493', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'oauth', 'value': 'null', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.901 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Reading bridges configuration: ['192.168.17.253']
2025-09-17 15:13:50.901 Command udi_interface.interface DEBUG interface:_handleInput: Key oauth should be passed to node server.
2025-09-17 15:13:50.901 Thread-2 (parameter_handler) udi_interface INFO phue:connect: Attempting to connect to the bridge...
2025-09-17 15:13:50.901 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getNsInfo
2025-09-17 15:13:50.902 Thread-2 (parameter_handler) udi_interface INFO phue:connect: Error opening config file, will attempt bridge registration
2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '137fb83b-0c96-47dc-b395-a75f847075d4', 'uuid': '00:21:b9:02:65:1c', 'name': 'Twinkly', 'nsid': 'f5f38126-56f2-4f1d-a1d4-a175b0639096', 'expires': 0, 'nickname': None, 'profileNum': 6, 'developerMode': 0, 'timeAdded': 1719296895682, 'timeStarted': 1758085659768, 'timeModified': 1758085664245, 'version': '3.0.0', 'edition': 'Free', 'branch': 'main', 'url': 'https://github.com/UniversalDevicesInc-PG3/udi-twinkly-nodeserver.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_6', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'twinkly_poly.py', 'shortPoll': 60, 'longPoll': 300, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '', 'noLicense': 0, 'latestVersion': '3.0.0', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '1cd02c69-534c-4de5-a782-ff0edb8a384f', 'uuid': '00:21:b9:02:65:1c', 'name': 'Ecobee', 'nsid': 'af1f50a2-7aaf-43c1-aa53-276b2587cb22', 'expires': 0, 'nickname': None, 'profileNum': 12, 'developerMode': 0, 'timeAdded': 1719297099268, 'timeStarted': 1758085660972, 'timeModified': 1758085664024, 'version': '3.1.5', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Ecobee.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_12', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":2,"name":"Debug + Session Verbose","value":"DEBUG_SESSION_VERBOSE","level":8},{"id":1,"name":"Debug + Session","value":"DEBUG_SESSION","level":9}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'ecobee-poly.py', 'shortPoll': 60, 'longPoll': 180, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '503a1f86-943d-4f44-8c0c-ed4e9c4fd2e1', 'noLicense': 0, 'latestVersion': '3.1.5', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '59504506-250f-419b-bef3-67048712c138', 'uuid': '00:21:b9:02:65:1c', 'name': 'Blink', 'nsid': '02b66257-0f05-4624-9c27-6855c828c844', 'expires': 0, 'nickname': None, 'profileNum': 8, 'developerMode': 0, 'timeAdded': 1719297099290, 'timeStarted': 1758085659353, 'timeModified': 1758085663771, 'version': '0.4.8', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-Blink.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_8', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'udiBlinkController.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '119ff071-becc-4671-9134-501a040a40ef', 'noLicense': 0, 'latestVersion': '0.4.8', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4f558c4c-e814-4cc0-93ea-1b03ce8dec7c', 'uuid': '00:21:b9:02:65:1c', 'name': 'FlumeWater', 'nsid': '3437f14b-7a1c-4361-815f-91476a627007', 'expires': 0, 'nickname': None, 'profileNum': 11, 'developerMode': 0, 'timeAdded': 1719297099301, 'timeStarted': 1758085660259, 'timeModified': 1758085665689, 'version': '3.1.1', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/FlumeWater.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_11', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'flumewater-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '731353c7-6151-4d79-a92b-29133377ec78', 'noLicense': 0, 'latestVersion': '3.1.1', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'dccefcdb-7335-410b-9dee-46cacbad10ba', 'uuid': '00:21:b9:02:65:1c', 'name': 'Kasa', 'nsid': '47434058-cf83-4ad5-b7ed-c0faa511fe60', 'expires': 0, 'nickname': None, 'profileNum': 7, 'developerMode': 0, 'timeAdded': 1719297399369, 'timeStarted': 1758085663448, 'timeModified': 1758146397061, 'version': '3.1.4', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Kasa.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_7', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'kasa-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'tplkasactl', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '4b3754d8-1092-45a5-8f69-e1c9dccf66ea', 'noLicense': 0, 'latestVersion': '3.1.4', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4a3345c7-51a5-4730-a148-5edaa75384ff', 'uuid': '00:21:b9:02:65:1c', 'name': 'ST-Inventory', 'nsid': 'c126923a-afcd-4e6d-9e46-58576796f551', 'expires': 0, 'nickname': None, 'profileNum': 2, 'developerMode': 0, 'timeAdded': 1719297399376, 'timeStarted': 1758085659573, 'timeModified': 1758085661423, 'version': '1.0.12', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/pg3_inventory.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_2', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'node', 'executable': 'st-inventory.js', 'shortPoll': 300, 'longPoll': 600, 'allowIsyAccess': 1, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'bf792bfd-00e9-44c2-8399-ef547f9bbd88', 'noLicense': 0, 'latestVersion': '1.0.12', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '0c1e8d33-1ae8-456b-8e19-d4a50712e775', 'uuid': '00:21:b9:02:65:1c', 'name': 'Bluetooth', 'nsid': '40b26907-c607-4a7d-be8d-86d1776525b2', 'expires': 0, 'nickname': None, 'profileNum': 14, 'developerMode': 0, 'timeAdded': 1719297399379, 'timeStarted': 1758085659726, 'timeModified': 1758085663567, 'version': '1.0.7', 'edition': 'Free', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/bluetooth-1.0.7.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_14', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bluetooth.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'c0c55d0d-9fb8-472f-8099-271c2be07c75', 'noLicense': 0, 'latestVersion': '1.0.7', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '8a6bea85-6ccb-4cf4-b327-e85fa24720bc', 'uuid': '00:21:b9:02:65:1c', 'name': 'AudioPlayer', 'nsid': 'c582beed-644f-44c8-8145-d676b4f035fd', 'expires': 0, 'nickname': None, 'profileNum': 15, 'developerMode': 0, 'timeAdded': 1719297399383, 'timeStarted': 1758085659456, 'timeModified': 1758085664325, 'version': '1.3.7', 'edition': 'Professional', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/audio-player-1.3.7.pro.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_15', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'audio-player.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 600, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '10726ac8-0534-4ae5-b420-0ac193173365', 'noLicense': 0, 'latestVersion': '1.3.7', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'b0e96f94-9512-466f-b625-4ddf29d34b37', 'uuid': '00:21:b9:02:65:1c', 'name': 'Notification', 'nsid': '132e8dd7-e452-41dd-80f1-6a7da660f00b', 'expires': 0, 'nickname': None, 'profileNum': 3, 'developerMode': 0, 'timeAdded': 1719297699427, 'timeStarted': 1758085659974, 'timeModified': 1758085664371, 'version': '3.6.16', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Notification.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_3', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'notification-poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '94dd0ef7-6d1d-4c34-81bd-dcb87632c130', 'noLicense': 0, 'latestVersion': '3.6.16', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'bafc00c2-44da-47f9-9c84-0e5a749a99c6', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaEV2', 'nsid': '50dfa8d4-e3cf-4eb6-a4de-ffa59b84ed1d', 'expires': 1749513600000, 'nickname': None, 'profileNum': 4, 'developerMode': 0, 'timeAdded': 1733199479420, 'timeStarted': 1739322036051, 'timeModified': 1749612568895, 'version': '0.1.53', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-TeslaEV2', 'home': '/var/polyglot/pg3/ns/0021b902651c_4', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaEV2main.py', 'shortPoll': 600, 'longPoll': 7200, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '4d74d631-e454-48cd-8015-5b1b2b29b18d', 'noLicense': 0, 'latestVersion': '0.1.53', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'ca83ef2c-0c3d-44e1-a759-da87d9a1121c', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaPW2', 'nsid': '09a306c6-ba96-4ed6-8beb-e915947d826a', 'expires': 0, 'nickname': None, 'profileNum': 5, 'developerMode': 0, 'timeAdded': 1733543469307, 'timeStarted': 1758085660562, 'timeModified': 1758085967347, 'version': '0.1.30', 'edition': 'Standard', 'branch': 'main', 'url': '\thttps://github.com/Panda88CO/udi-teslaPW2', 'home': '/var/polyglot/pg3/ns/0021b902651c_5', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaPW2main.py', 'shortPoll': 300, 'longPoll': 1800, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '2866fa15-622e-4147-9436-a7051a13e261', 'noLicense': 0, 'latestVersion': '0.1.30', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'e0e6f8cc-28ee-455b-8ff9-7a89b1cae867', 'uuid': '00:21:b9:02:65:1c', 'name': 'BambuLab', 'nsid': 'e9d207b0-a165-40e9-b747-38eafa498f2d', 'expires': 0, 'nickname': None, 'profileNum': 9, 'developerMode': 0, 'timeAdded': 1756887683457, 'timeStarted': 1758085660766, 'timeModified': 1758085663587, 'version': '1.0.2', 'edition': 'Standard', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/udi-bambu-poly.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_9', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bambu_poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '6505bfd9-eae9-493c-bb18-f484a55166b8', 'noLicense': 0, 'latestVersion': '1.0.2', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '3049e206-a3d8-43cd-b872-f84d65752f63', 'uuid': '00:21:b9:02:65:1c', 'name': 'Hue', 'nsid': 'e3adc119-1d74-4986-84c6-cfebb19e94df', 'expires': 0, 'nickname': None, 'profileNum': 1, 'developerMode': 0, 'timeAdded': 1758088049234, 'timeStarted': 1758147229924, 'timeModified': 1758147230875, 'version': '0.1.11', 'edition': 'Free', 'branch': 'master', 'url': 'https://github.com/exking/udi-hue-pg3.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_1', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'hue.py', 'shortPoll': 15, 'longPoll': 60, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '', 'noLicense': 0, 'latestVersion': '0.1.11', 'dbVersion': 1} from Polyglot
2025-09-17 15:13:50.904 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]}
2025-09-17 15:13:50.906 Thread-2 (parameter_handler) udi_interface ERROR hue:connect: Cannot find Hue Bridge
2025-09-17 15:13:50.918 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom
2025-09-17 15:13:50.918 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom
2025-09-17 15:13:50.918 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot
2025-09-17 15:13:50.918 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot
2025-09-17 15:13:50.918 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}
2025-09-17 15:13:50.957 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2025-09-17 15:13:51.025 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode
2025-09-17 15:13:51.026 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode
2025-09-17 15:13:51.026 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS addnode message {'id': '00a0f77b-8805-4636-8324-cd0b06f6f83e', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1758142636749, 'timeModified': 1758142636749, 'dbVersion': 1} from Polyglot
2025-09-17 15:13:51.026 Thread-5 (start) udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot.
2025-09-17 15:13:51.026 Thread-5 (start) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving
2025-09-17 15:13:51.026 Command udi_interface.interface DEBUG interface:_handleAddNode: add node response: {'id': '00a0f77b-8805-4636-8324-cd0b06f6f83e', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1758142636749, 'timeModified': 1758142636749, 'dbVersion': 1}
2025-09-17 15:13:51.027 Thread-5 (start) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2025-09-17 15:13:51.030 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'installprofile': {'reboot': False}}
2025-09-17 15:13:51.031 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]}
2025-09-17 15:13:51.083 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom
2025-09-17 15:13:51.083 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom
2025-09-17 15:13:51.084 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot
2025-09-17 15:13:51.084 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot
2025-09-17 15:13:51.084 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}
2025-09-17 15:13:51.122 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2025-09-17 15:13:52.028 MQTT udi_interface.interface INFO interface:_message: Profile installation finished
2025-09-17 15:14:04.928 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:14:04.928 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:14:04.929 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:14:19.933 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:14:19.934 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:14:19.934 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:14:34.937 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:14:34.937 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:14:34.938 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:14:49.924 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll
2025-09-17 15:14:49.924 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll
2025-09-17 15:14:49.924 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot
2025-09-17 15:14:49.965 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:14:49.965 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:14:49.965 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:15:04.942 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:15:04.942 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:15:19.947 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:15:19.947 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:15:19.947 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:15:34.951 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:15:34.951 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:15:34.951 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:15:49.961 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll
2025-09-17 15:15:49.961 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll
2025-09-17 15:15:49.961 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot
2025-09-17 15:15:50.002 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:15:50.002 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:15:50.002 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:16:04.959 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:16:04.959 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:16:04.959 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:16:34.967 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:16:34.967 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:16:34.967 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:16:49.928 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll
2025-09-17 15:16:49.928 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll
2025-09-17 15:16:49.928 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot
2025-09-17 15:16:49.969 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:16:49.969 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:16:49.969 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:17:04.971 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:17:04.971 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:17:04.971 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:17:19.980 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:17:19.980 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:17:19.980 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:17:34.988 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:17:34.988 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:17:34.988 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:17:49.930 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll
2025-09-17 15:17:49.930 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll
2025-09-17 15:17:49.930 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot
2025-09-17 15:17:49.989 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:17:49.989 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:17:49.989 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:18:04.993 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:18:04.993 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:18:04.993 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:18:34.996 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:18:34.996 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:18:34.996 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:18:49.937 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll
2025-09-17 15:18:49.937 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll
2025-09-17 15:18:49.937 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot
2025-09-17 15:18:49.997 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:18:49.997 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:18:49.997 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:19:05.001 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:19:05.001 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:19:05.001 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:19:20.003 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:19:20.003 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:19:20.003 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:19:35.011 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:19:35.012 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:19:35.012 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:20:05.016 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:20:05.016 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:20:05.016 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:20:20.020 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:20:20.020 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:20:20.020 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:20:35.026 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:20:35.026 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:20:35.026 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:20:49.945 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll
2025-09-17 15:20:49.945 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll
2025-09-17 15:20:49.945 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot
2025-09-17 15:20:50.028 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:20:50.028 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:20:50.028 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:21:05.037 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:21:05.037 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:21:05.037 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:21:20.045 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:21:20.046 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:21:20.046 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:21:35.047 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:21:35.047 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:21:35.047 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:22:35.059 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:22:35.059 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:22:35.059 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-09-17 15:22:49.964 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll
2025-09-17 15:22:49.964 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll
2025-09-17 15:22:49.964 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot
2025-09-17 15:22:50.059 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-09-17 15:22:50.060 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-09-17 15:22:50.060 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
Solved by Geddy
1 hour ago, GSutherland said:
Hello all,
Goodness Mr early adopter... How is the bridge outside of the system? Do you notice a difference? Have you tried to see if network resources work with it?
I've noticed the bridge is really faster than the previous in response to my iPhone control for all my whole house network and also I feel like it reaches farther so I don't have lights on the outside of the perimeter having issues.  It's nice to have Wi-Fi and wired built into it....... and the amount of lights you can add to. It's pretty impressive cause I'm at 49 went away from the previous one that would not take anymore. This one I believe goes up to 150.
Seeing that the hue plugin was developed on unofficial api (based on previous posts about this plugin) and hasn't been updated in a while (years?)...I would hazard a guess that the "pro" hub is not supported. If you tried all the usual tricks and still cannot get it to connect, it might not be using the same methods that the plugin is using to identify and communicate allowing successful connection.
Fun that there's a new hub for hue.
I remember that the Hue api for a long time has been "version 1", and that they introduced a more secure version 2, hinting that version 1 would eventually be unsupported. Maybe that was the reason for requiring that you now log in to your Hue account on their phone app. If that's the case, then the plugin would need to be rewritten to use the newer api.
Following this thread, my Hue Bridge Pro arrives shortly. I will let you know if I find a method that works!
A quick search turned up this AI answer:
"No, the Hue Bridge Pro does not support the deprecated V1 API; it requires the V2 API to function".
So that's that. You might need to access your Hue devices as Matter devices instead, which the new bridge supports.
Question....
Hue devices use Matter that the new bridge supports V2 API
But can I use Matter on the EISY to add and program HUE control my lights
Or should I wait till a New Version API that support hue again on EISY NODES
thanks
I doubt that someone will rewrite the Hue plugin to use the V2 API. I'd try Matter, which is still in beta on the eisy. Matter was specifically created to allow interoperability between systems, and this is a good example of that. You'll probably get the basic functionality, minus some of the fancier features.
Question, how should I start setting up matter in order to start reading the Hugh because I'm having no luck in finding it
Same problem, same question, but with some success.  I enabled Matter in the config screen on EISY.  Then went to the Hue App/Setting/Smart Home/+/Other Apps and got a MATTER Pairing Code.  I went to the UDI app/Matter/Add Device and entered the pairing code.  I now have my Hue Bulbs (unnamed) as "ZM 002.# On-Off Switch" which gives me basic on/off functionality.  They come on in the last color I set.  This doesn't really work for me as I need to be able to select hue scenes with effects and colors.  I don't really need direct control over color.  I'm wondering if scenes are exposed in matter and might be supported in the future.  Having the names come through would also be nice, or a new Polyglot plug-in.
Edited by Lore
Hello, I just wanted to let you know that I installed it with no luck of it working yet....  but I'm trying a couple of different things, but I want to send you something.....
2025-10-07 23:16:42.412 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down.
2025-10-07 23:16:42.413 Thread-827 (stop) udi_interface INFO hue:stop: Hue NodeServer is stopping
2025-10-07 23:16:47.043 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2025-10-07 23:16:47.043 MainThread udi_interface INFO __init__:<module>: UDI interface initializing
2025-10-07 23:16:47.043 MainThread udi_interface INFO __init__:<module>: User=None
2025-10-07 23:16:47.043 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b902651c_1
2025-10-07 23:16:47.043 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b902651c_1
2025-10-07 23:16:47.043 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjU6MWMiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IklORk8iLCJ0b2tlbiI6Imh4eUZaKkh1SyppTjI4VCsiLCJtcXR0SG9zdCI6ImxvY2FsaG9zdCIsIm1xdHRQb3J0Ijo4ODgzLCJzZWN1cmUiOjEsImlzUEczeCI6dHJ1ZSwicGczVmVyc2lvbiI6IjMuMy4yMiIsImlzeVZlcnNpb24iOiI2LjAuMCIsImVkaXRpb24iOiJGcmVlIn0=
2025-10-07 23:16:47.044 MainThread udi_interface INFO __init__:<module>: Loading interface module
2025-10-07 23:16:47.066 MainThread udi_interface INFO interface:<module>: Loading MQTT module
2025-10-07 23:16:47.574 MainThread udi_interface INFO interface:<module>: MQTT module loaded
2025-10-07 23:16:47.787 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module
2025-10-07 23:16:47.787 MainThread udi_interface INFO __init__:<module>: Loading node module
2025-10-07 23:16:47.787 MainThread udi_interface INFO __init__:<module>: Loading custom module
2025-10-07 23:16:47.788 MainThread udi_interface INFO __init__:<module>: Loading isy module
2025-10-07 23:16:47.788 MainThread udi_interface INFO __init__:<module>: Loading OAuth module
2025-10-07 23:16:47.788 MainThread udi_interface INFO __init__:<module>: UDI interface initialized
2025-10-07 23:16:47.788 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.18 Starting...
2025-10-07 23:16:47.791 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.3.22 [ISY: 6.0.0, Slot: 1]
2025-10-07 23:16:47.791 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.51', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}
2025-10-07 23:16:47.792 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883
2025-10-07 23:16:47.792 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version
2025-10-07 23:16:47.792 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b902651c_1.cert key: 0021b902651c_1.key ca: /usr/local/etc/ssl/certs/ud.ca.cert
2025-10-07 23:16:47.793 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: huebridge not found in database.
2025-10-07 23:16:47.793 MainThread udi_interface.interface INFO interface:addNode: Adding node Hue(huebridge) [None]
2025-10-07 23:16:47.793 MainThread udi_interface INFO hue:__init__: Started Hue Protocol
2025-10-07 23:16:47.795 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds.
2025-10-07 23:16:47.844 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success
2025-10-07 23:16:47.844 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:1c_1 - MID: 2 Result: 0
2025-10-07 23:16:47.885 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0']
2025-10-07 23:16:47.922 Thread-2 (parameter_handler) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2025-10-07 23:16:47.923 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Saved bridges information is not found
2025-10-07 23:16:47.924 Thread-2 (parameter_handler) udi_interface INFO hue:connect: No bridge configuration found, trying discovery...
2025-10-07 23:16:47.924 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: Exception in thread
2025-10-07 23:16:47.924 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: Thread-2 (parameter_handler)
2025-10-07 23:16:47.924 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: :
2025-10-07 23:16:47.924 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2025-10-07 23:16:47.924 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 1045, in _bootstrap_inner
2025-10-07 23:16:47.925 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: self.run()
2025-10-07 23:16:47.925 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 982, in run
2025-10-07 23:16:47.926 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs)
2025-10-07 23:16:47.926 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b902651c_1/hue.py", line 63, in parameter_handler
2025-10-07 23:16:47.926 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: self.connect()
2025-10-07 23:16:47.926 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b902651c_1/hue.py", line 119, in connect
2025-10-07 23:16:47.926 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: hub_list = HueBridge.discover_bridges()
2025-10-07 23:16:47.926 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-07 23:16:47.927 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: ^
2025-10-07 23:16:47.927 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: NameError
2025-10-07 23:16:47.927 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: :
2025-10-07 23:16:47.927 Thread-2 (parameter_handler) udi_interface ERROR udi_interface:write: name 'HueBridge' is not defined
2025-10-07 23:16:47.991 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2025-10-07 23:16:48.085 Thread-5 (start) udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot.
2025-10-07 23:16:48.085 Thread-5 (start) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2025-10-07 23:16:48.218 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2025-10-07 23:16:49.882 MQTT udi_interface.interface INFO interface:_message: Profile installation finished
Thanks, please re-install, I think I've got that fixed, I have not tested discovery from zero yet. Worst case you can add bridge IP and secret manually :)
Hello,
I just did the update to Ver 1.1... here is what I got
Waiting for it to ask me to push the BIG sound button.  I have not put in the IP address in the fields like I had to do before unless it still needs it.
2025-10-08 13:58:10.777 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message stop
2025-10-08 13:58:10.777 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING stop
2025-10-08 13:58:10.778 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS stop message {} from Polyglot
2025-10-08 13:58:10.778 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down.
2025-10-08 13:58:10.778 Thread-6 (stop) udi_interface INFO hue:stop: Hue NodeServer is stopping
2025-10-08 13:58:15.318 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2025-10-08 13:58:15.318 MainThread udi_interface INFO __init__:<module>: UDI interface initializing
2025-10-08 13:58:15.318 MainThread udi_interface INFO __init__:<module>: User=None
2025-10-08 13:58:15.318 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b902651c_1
2025-10-08 13:58:15.318 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b902651c_1
2025-10-08 13:58:15.318 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjU6MWMiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IkRFQlVHIiwidG9rZW4iOiJoeHlGWipIdUsqaU4yOFQrIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjMuMjIiLCJpc3lWZXJzaW9uIjoiNi4wLjAiLCJlZGl0aW9uIjoiRnJlZSJ9
2025-10-08 13:58:15.318 MainThread udi_interface INFO __init__:<module>: Loading interface module
2025-10-08 13:58:15.340 MainThread udi_interface INFO interface:<module>: Loading MQTT module
2025-10-08 13:58:15.811 MainThread udi_interface INFO interface:<module>: MQTT module loaded
2025-10-08 13:58:16.008 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module
2025-10-08 13:58:16.009 MainThread udi_interface INFO __init__:<module>: Loading node module
2025-10-08 13:58:16.009 MainThread udi_interface INFO __init__:<module>: Loading custom module
2025-10-08 13:58:16.009 MainThread udi_interface INFO __init__:<module>: Loading isy module
2025-10-08 13:58:16.009 MainThread udi_interface INFO __init__:<module>: Loading OAuth module
2025-10-08 13:58:16.010 MainThread udi_interface INFO __init__:<module>: UDI interface initialized
2025-10-08 13:58:16.010 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.18 Starting...
2025-10-08 13:58:16.013 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.3.22 [ISY: 6.0.0, Slot: 1]
2025-10-08 13:58:16.014 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.51', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}
2025-10-08 13:58:16.014 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883
2025-10-08 13:58:16.014 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version
2025-10-08 13:58:16.015 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b902651c_1.cert key: 0021b902651c_1.key ca: /usr/local/etc/ssl/certs/ud.ca.cert
2025-10-08 13:58:16.015 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: huebridge not found in database.
2025-10-08 13:58:16.015 MainThread udi_interface.interface INFO interface:addNode: Adding node Hue(huebridge) [None]
2025-10-08 13:58:16.015 MainThread udi_interface INFO hue:__init__: Started Hue Protocol
2025-10-08 13:58:16.017 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds.
2025-10-08 13:58:16.066 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success
2025-10-08 13:58:16.066 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:1c_1 - MID: 2 Result: 0
2025-10-08 13:58:16.108 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0']
2025-10-08 13:58:16.162 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getAll
2025-10-08 13:58:16.162 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getAll
2025-10-08 13:58:16.162 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '5f472940-01ae-4908-8a0b-c1ba115b710a', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'notices', 'value': '{}', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.162 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}
2025-10-08 13:58:16.163 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getNsInfo
2025-10-08 13:58:16.163 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '921abaed-04ca-4b16-aaee-58a00aecdade', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'nsdata', 'value': 'null', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.163 Command udi_interface.interface DEBUG interface:_handleInput: Key nsdata should be passed to node server.
2025-10-08 13:58:16.163 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '25d186f0-0e96-4358-b2ae-f5f237e98a4c', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'oauth', 'value': 'null', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.163 Command udi_interface.interface DEBUG interface:_handleInput: Key oauth should be passed to node server.
2025-10-08 13:58:16.164 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving
2025-10-08 13:58:16.164 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getNsInfo
2025-10-08 13:58:16.164 Thread-2 (parameter_handler) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2025-10-08 13:58:16.164 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '137fb83b-0c96-47dc-b395-a75f847075d4', 'uuid': '00:21:b9:02:65:1c', 'name': 'Twinkly', 'nsid': 'f5f38126-56f2-4f1d-a1d4-a175b0639096', 'expires': 0, 'nickname': None, 'profileNum': 6, 'developerMode': 0, 'timeAdded': 1719296895682, 'timeStarted': 1759315221208, 'timeModified': 1759732609803, 'version': '3.0.0', 'edition': 'Free', 'branch': 'main', 'url': 'https://github.com/UniversalDevicesInc-PG3/udi-twinkly-nodeserver.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_6', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'twinkly_poly.py', 'shortPoll': 60, 'longPoll': 300, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '', 'noLicense': 0, 'latestVersion': '3.0.0', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.164 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Saved bridges information is not found
2025-10-08 13:58:16.165 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '1cd02c69-534c-4de5-a782-ff0edb8a384f', 'uuid': '00:21:b9:02:65:1c', 'name': 'Ecobee', 'nsid': 'af1f50a2-7aaf-43c1-aa53-276b2587cb22', 'expires': 0, 'nickname': None, 'profileNum': 12, 'developerMode': 0, 'timeAdded': 1719297099268, 'timeStarted': 1759315223461, 'timeModified': 1759732609847, 'version': '3.1.5', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Ecobee.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_12', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":2,"name":"Debug + Session Verbose","value":"DEBUG_SESSION_VERBOSE","level":8},{"id":1,"name":"Debug + Session","value":"DEBUG_SESSION","level":9}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'ecobee-poly.py', 'shortPoll': 60, 'longPoll': 180, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '503a1f86-943d-4f44-8c0c-ed4e9c4fd2e1', 'noLicense': 0, 'latestVersion': '3.1.5', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.165 Thread-2 (parameter_handler) udi_interface INFO hue:connect: No bridge configuration found, trying discovery...
2025-10-08 13:58:16.165 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '59504506-250f-419b-bef3-67048712c138', 'uuid': '00:21:b9:02:65:1c', 'name': 'Blink', 'nsid': '02b66257-0f05-4624-9c27-6855c828c844', 'expires': 0, 'nickname': None, 'profileNum': 8, 'developerMode': 0, 'timeAdded': 1719297099290, 'timeStarted': 1759315219345, 'timeModified': 1759732609715, 'version': '0.4.8', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-Blink.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_8', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'udiBlinkController.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '119ff071-becc-4671-9134-501a040a40ef', 'noLicense': 0, 'latestVersion': '0.4.8', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.166 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4f558c4c-e814-4cc0-93ea-1b03ce8dec7c', 'uuid': '00:21:b9:02:65:1c', 'name': 'FlumeWater', 'nsid': '3437f14b-7a1c-4361-815f-91476a627007', 'expires': 0, 'nickname': None, 'profileNum': 11, 'developerMode': 0, 'timeAdded': 1719297099301, 'timeStarted': 1759315222103, 'timeModified': 1759732609836, 'version': '3.1.1', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/FlumeWater.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_11', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'flumewater-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '731353c7-6151-4d79-a92b-29133377ec78', 'noLicense': 0, 'latestVersion': '3.1.1', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.166 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'dccefcdb-7335-410b-9dee-46cacbad10ba', 'uuid': '00:21:b9:02:65:1c', 'name': 'Kasa', 'nsid': '47434058-cf83-4ad5-b7ed-c0faa511fe60', 'expires': 0, 'nickname': None, 'profileNum': 7, 'developerMode': 0, 'timeAdded': 1719297399369, 'timeStarted': 1759315232837, 'timeModified': 1759956064594, 'version': '3.1.4', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Kasa.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_7', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'kasa-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'tplkasactl', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '4b3754d8-1092-45a5-8f69-e1c9dccf66ea', 'noLicense': 0, 'latestVersion': '3.1.4', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.166 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4a3345c7-51a5-4730-a148-5edaa75384ff', 'uuid': '00:21:b9:02:65:1c', 'name': 'ST-Inventory', 'nsid': 'c126923a-afcd-4e6d-9e46-58576796f551', 'expires': 0, 'nickname': None, 'profileNum': 2, 'developerMode': 0, 'timeAdded': 1719297399376, 'timeStarted': 1759356263532, 'timeModified': 1759356263953, 'version': '1.0.12', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/pg3_inventory.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_2', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'node', 'executable': 'st-inventory.js', 'shortPoll': 300, 'longPoll': 600, 'allowIsyAccess': 1, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'bf792bfd-00e9-44c2-8399-ef547f9bbd88', 'noLicense': 0, 'latestVersion': '1.0.12', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.166 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '0c1e8d33-1ae8-456b-8e19-d4a50712e775', 'uuid': '00:21:b9:02:65:1c', 'name': 'Bluetooth', 'nsid': '40b26907-c607-4a7d-be8d-86d1776525b2', 'expires': 0, 'nickname': None, 'profileNum': 14, 'developerMode': 0, 'timeAdded': 1719297399379, 'timeStarted': 1759315220837, 'timeModified': 1759732609775, 'version': '1.0.7', 'edition': 'Free', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/bluetooth-1.0.7.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_14', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bluetooth.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'c0c55d0d-9fb8-472f-8099-271c2be07c75', 'noLicense': 0, 'latestVersion': '1.0.7', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.166 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '8a6bea85-6ccb-4cf4-b327-e85fa24720bc', 'uuid': '00:21:b9:02:65:1c', 'name': 'AudioPlayer', 'nsid': 'c582beed-644f-44c8-8145-d676b4f035fd', 'expires': 0, 'nickname': None, 'profileNum': 15, 'developerMode': 0, 'timeAdded': 1719297399383, 'timeStarted': 1759315220233, 'timeModified': 1759732609763, 'version': '1.3.7', 'edition': 'Professional', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/audio-player-1.3.7.pro.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_15', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'audio-player.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 600, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '10726ac8-0534-4ae5-b420-0ac193173365', 'noLicense': 0, 'latestVersion': '1.3.7', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.166 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'b0e96f94-9512-466f-b625-4ddf29d34b37', 'uuid': '00:21:b9:02:65:1c', 'name': 'Notification', 'nsid': '132e8dd7-e452-41dd-80f1-6a7da660f00b', 'expires': 0, 'nickname': None, 'profileNum': 3, 'developerMode': 0, 'timeAdded': 1719297699427, 'timeStarted': 1759315221090, 'timeModified': 1759732609789, 'version': '3.6.16', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Notification.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_3', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'notification-poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '94dd0ef7-6d1d-4c34-81bd-dcb87632c130', 'noLicense': 0, 'latestVersion': '3.6.16', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.166 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'bafc00c2-44da-47f9-9c84-0e5a749a99c6', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaEV2', 'nsid': '50dfa8d4-e3cf-4eb6-a4de-ffa59b84ed1d', 'expires': 1749513600000, 'nickname': None, 'profileNum': 4, 'developerMode': 0, 'timeAdded': 1733199479420, 'timeStarted': 1739322036051, 'timeModified': 1759185526932, 'version': '0.1.53', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-TeslaEV2', 'home': '/var/polyglot/pg3/ns/0021b902651c_4', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaEV2main.py', 'shortPoll': 600, 'longPoll': 7200, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '4d74d631-e454-48cd-8015-5b1b2b29b18d', 'noLicense': 0, 'latestVersion': '0.1.53', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.167 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'ca83ef2c-0c3d-44e1-a759-da87d9a1121c', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaPW2', 'nsid': '09a306c6-ba96-4ed6-8beb-e915947d826a', 'expires': 0, 'nickname': None, 'profileNum': 5, 'developerMode': 0, 'timeAdded': 1733543469307, 'timeStarted': 1759315221632, 'timeModified': 1759732609815, 'version': '0.1.30', 'edition': 'Standard', 'branch': 'main', 'url': '\thttps://github.com/Panda88CO/udi-teslaPW2', 'home': '/var/polyglot/pg3/ns/0021b902651c_5', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaPW2main.py', 'shortPoll': 300, 'longPoll': 1800, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '2866fa15-622e-4147-9436-a7051a13e261', 'noLicense': 0, 'latestVersion': '0.1.30', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.167 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'e0e6f8cc-28ee-455b-8ff9-7a89b1cae867', 'uuid': '00:21:b9:02:65:1c', 'name': 'BambuLab', 'nsid': 'e9d207b0-a165-40e9-b747-38eafa498f2d', 'expires': 0, 'nickname': None, 'profileNum': 9, 'developerMode': 0, 'timeAdded': 1756887683457, 'timeStarted': 1759315222679, 'timeModified': 1759732609728, 'version': '1.0.2', 'edition': 'Standard', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/udi-bambu-poly.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_9', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bambu_poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '6505bfd9-eae9-493c-bb18-f484a55166b8', 'noLicense': 0, 'latestVersion': '1.0.2', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.167 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '6067fdb0-ef35-4bcb-9906-8a30c2bf4439', 'uuid': '00:21:b9:02:65:1c', 'name': 'iox-matter', 'nsid': 'd193c79a-dcb1-427c-aabf-3efd5feb8f27', 'expires': 1775025189000, 'nickname': None, 'profileNum': 10, 'developerMode': 0, 'timeAdded': 1759300394762, 'timeStarted': 1759390244438, 'timeModified': 1759732609740, 'version': '1.3.0', 'edition': 'Standard', 'branch': None, 'url': 'https://pg3store.isy.io/v2/nodeservers/beta/matter.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_10', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'matter.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 1, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Beta', 'option': 'bda318b7-2bd7-47e1-a788-50c24c48979b', 'noLicense': 0, 'latestVersion': '1.3.0', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.167 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'f83d8020-b5bc-475a-8f2e-bddf164a55e5', 'uuid': '00:21:b9:02:65:1c', 'name': 'Hue', 'nsid': 'b8518958-ab70-4555-9d4f-a2da8df86122', 'expires': 0, 'nickname': None, 'profileNum': 1, 'developerMode': 0, 'timeAdded': 1759859313952, 'timeStarted': 1759957095179, 'timeModified': 1759957096142, 'version': '1.0.1', 'edition': 'Free', 'branch': 'huev2', 'url': 'https://github.com/exking/udi-hue-pg3.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_1', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'hue.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Beta', 'option': 'a3f28572-0cdd-43c4-a538-ccddf4de8e20', 'noLicense': 0, 'latestVersion': '1.0.1', 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.174 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]}
2025-10-08 13:58:16.189 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom
2025-10-08 13:58:16.189 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom
2025-10-08 13:58:16.189 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot
2025-10-08 13:58:16.189 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot
2025-10-08 13:58:16.189 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}
2025-10-08 13:58:16.232 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2025-10-08 13:58:16.285 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode
2025-10-08 13:58:16.285 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode
2025-10-08 13:58:16.285 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS addnode message {'id': 'cebce479-5837-4acb-b568-75b61c363c30', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1759859325474, 'timeModified': 1759859325474, 'dbVersion': 1} from Polyglot
2025-10-08 13:58:16.286 Command udi_interface.interface DEBUG interface:_handleAddNode: add node response: {'id': 'cebce479-5837-4acb-b568-75b61c363c30', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1759859325474, 'timeModified': 1759859325474, 'dbVersion': 1}
2025-10-08 13:58:16.286 Thread-5 (start) udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot.
2025-10-08 13:58:16.286 Thread-5 (start) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving
2025-10-08 13:58:16.286 Thread-5 (start) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2025-10-08 13:58:16.290 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'installprofile': {'reboot': False}}
2025-10-08 13:58:16.290 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]}
2025-10-08 13:58:16.375 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom
2025-10-08 13:58:16.376 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom
2025-10-08 13:58:16.376 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot
2025-10-08 13:58:16.376 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot
2025-10-08 13:58:16.376 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}
2025-10-08 13:58:16.418 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2025-10-08 13:58:17.809 MQTT udi_interface.interface INFO interface:_message: Profile installation finished
The pop-up finally appeared saying go push the BIG button, and then restart the node.  After I hit the sink button and restarted it still no connection and has not populated with any of the devices, but here is the script.
2025-10-08 14:33:14.098 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2025-10-08 14:32:14.091 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-10-08 14:32:14.091 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-10-08 14:33:14.098 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2025-10-08 14:33:14.098 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2025-10-08 14:33:22.315 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message stop
2025-10-08 14:33:22.315 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING stop
2025-10-08 14:33:22.315 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS stop message {} from Polyglot
2025-10-08 14:33:22.315 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down.
2025-10-08 14:33:22.315 Thread-9 (stop) udi_interface INFO hue:stop: Hue NodeServer is stopping
2025-10-08 14:33:26.872 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2025-10-08 14:33:26.872 MainThread udi_interface INFO __init__:<module>: UDI interface initializing
2025-10-08 14:33:26.872 MainThread udi_interface INFO __init__:<module>: User=None
2025-10-08 14:33:26.872 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b902651c_1
2025-10-08 14:33:26.872 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b902651c_1
2025-10-08 14:33:26.873 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjU6MWMiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IkRFQlVHIiwidG9rZW4iOiJoeHlGWipIdUsqaU4yOFQrIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjMuMjIiLCJpc3lWZXJzaW9uIjoiNi4wLjAiLCJlZGl0aW9uIjoiRnJlZSJ9
2025-10-08 14:33:26.873 MainThread udi_interface INFO __init__:<module>: Loading interface module
2025-10-08 14:33:26.895 MainThread udi_interface INFO interface:<module>: Loading MQTT module
2025-10-08 14:33:27.369 MainThread udi_interface INFO interface:<module>: MQTT module loaded
2025-10-08 14:33:27.568 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module
2025-10-08 14:33:27.568 MainThread udi_interface INFO __init__:<module>: Loading node module
2025-10-08 14:33:27.568 MainThread udi_interface INFO __init__:<module>: Loading custom module
2025-10-08 14:33:27.569 MainThread udi_interface INFO __init__:<module>: Loading isy module
2025-10-08 14:33:27.569 MainThread udi_interface INFO __init__:<module>: Loading OAuth module
2025-10-08 14:33:27.569 MainThread udi_interface INFO __init__:<module>: UDI interface initialized
2025-10-08 14:33:27.569 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.18 Starting...
2025-10-08 14:33:27.573 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.3.22 [ISY: 6.0.0, Slot: 1]
2025-10-08 14:33:27.573 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.51', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}
2025-10-08 14:33:27.573 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883
2025-10-08 14:33:27.574 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version
2025-10-08 14:33:27.574 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b902651c_1.cert key: 0021b902651c_1.key ca: /usr/local/etc/ssl/certs/ud.ca.cert
2025-10-08 14:33:27.574 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: huebridge not found in database.
2025-10-08 14:33:27.574 MainThread udi_interface.interface INFO interface:addNode: Adding node Hue(huebridge) [None]
2025-10-08 14:33:27.575 MainThread udi_interface INFO hue:__init__: Started Hue Protocol
2025-10-08 14:33:27.577 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds.
2025-10-08 14:33:27.629 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success
2025-10-08 14:33:27.629 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:1c_1 - MID: 2 Result: 0
2025-10-08 14:33:27.670 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0']
2025-10-08 14:33:27.718 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getAll
2025-10-08 14:33:27.718 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getAll
2025-10-08 14:33:27.718 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '5f472940-01ae-4908-8a0b-c1ba115b710a', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'notices', 'value': '{}', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.718 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}
2025-10-08 14:33:27.718 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '921abaed-04ca-4b16-aaee-58a00aecdade', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'nsdata', 'value': 'null', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.718 Command udi_interface.interface DEBUG interface:_handleInput: Key nsdata should be passed to node server.
2025-10-08 14:33:27.719 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '25d186f0-0e96-4358-b2ae-f5f237e98a4c', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'oauth', 'value': 'null', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.719 Command udi_interface.interface DEBUG interface:_handleInput: Key oauth should be passed to node server.
2025-10-08 14:33:27.719 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving
2025-10-08 14:33:27.719 Thread-2 (parameter_handler) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2025-10-08 14:33:27.720 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Saved bridges information is not found
2025-10-08 14:33:27.720 Thread-2 (parameter_handler) udi_interface INFO hue:connect: No bridge configuration found, trying discovery...
2025-10-08 14:33:27.726 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]}
2025-10-08 14:33:27.727 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getNsInfo
2025-10-08 14:33:27.727 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getNsInfo
2025-10-08 14:33:27.727 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '137fb83b-0c96-47dc-b395-a75f847075d4', 'uuid': '00:21:b9:02:65:1c', 'name': 'Twinkly', 'nsid': 'f5f38126-56f2-4f1d-a1d4-a175b0639096', 'expires': 0, 'nickname': None, 'profileNum': 6, 'developerMode': 0, 'timeAdded': 1719296895682, 'timeStarted': 1759315221208, 'timeModified': 1759732609803, 'version': '3.0.0', 'edition': 'Free', 'branch': 'main', 'url': 'https://github.com/UniversalDevicesInc-PG3/udi-twinkly-nodeserver.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_6', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'twinkly_poly.py', 'shortPoll': 60, 'longPoll': 300, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '', 'noLicense': 0, 'latestVersion': '3.0.0', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.728 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '1cd02c69-534c-4de5-a782-ff0edb8a384f', 'uuid': '00:21:b9:02:65:1c', 'name': 'Ecobee', 'nsid': 'af1f50a2-7aaf-43c1-aa53-276b2587cb22', 'expires': 0, 'nickname': None, 'profileNum': 12, 'developerMode': 0, 'timeAdded': 1719297099268, 'timeStarted': 1759315223461, 'timeModified': 1759732609847, 'version': '3.1.5', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Ecobee.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_12', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":2,"name":"Debug + Session Verbose","value":"DEBUG_SESSION_VERBOSE","level":8},{"id":1,"name":"Debug + Session","value":"DEBUG_SESSION","level":9}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'ecobee-poly.py', 'shortPoll': 60, 'longPoll': 180, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '503a1f86-943d-4f44-8c0c-ed4e9c4fd2e1', 'noLicense': 0, 'latestVersion': '3.1.5', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.728 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '59504506-250f-419b-bef3-67048712c138', 'uuid': '00:21:b9:02:65:1c', 'name': 'Blink', 'nsid': '02b66257-0f05-4624-9c27-6855c828c844', 'expires': 0, 'nickname': None, 'profileNum': 8, 'developerMode': 0, 'timeAdded': 1719297099290, 'timeStarted': 1759315219345, 'timeModified': 1759732609715, 'version': '0.4.8', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-Blink.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_8', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'udiBlinkController.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '119ff071-becc-4671-9134-501a040a40ef', 'noLicense': 0, 'latestVersion': '0.4.8', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.728 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4f558c4c-e814-4cc0-93ea-1b03ce8dec7c', 'uuid': '00:21:b9:02:65:1c', 'name': 'FlumeWater', 'nsid': '3437f14b-7a1c-4361-815f-91476a627007', 'expires': 0, 'nickname': None, 'profileNum': 11, 'developerMode': 0, 'timeAdded': 1719297099301, 'timeStarted': 1759315222103, 'timeModified': 1759732609836, 'version': '3.1.1', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/FlumeWater.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_11', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'flumewater-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '731353c7-6151-4d79-a92b-29133377ec78', 'noLicense': 0, 'latestVersion': '3.1.1', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.728 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'dccefcdb-7335-410b-9dee-46cacbad10ba', 'uuid': '00:21:b9:02:65:1c', 'name': 'Kasa', 'nsid': '47434058-cf83-4ad5-b7ed-c0faa511fe60', 'expires': 0, 'nickname': None, 'profileNum': 7, 'developerMode': 0, 'timeAdded': 1719297399369, 'timeStarted': 1759315232837, 'timeModified': 1759956064594, 'version': '3.1.4', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Kasa.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_7', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'kasa-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'tplkasactl', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '4b3754d8-1092-45a5-8f69-e1c9dccf66ea', 'noLicense': 0, 'latestVersion': '3.1.4', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.728 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4a3345c7-51a5-4730-a148-5edaa75384ff', 'uuid': '00:21:b9:02:65:1c', 'name': 'ST-Inventory', 'nsid': 'c126923a-afcd-4e6d-9e46-58576796f551', 'expires': 0, 'nickname': None, 'profileNum': 2, 'developerMode': 0, 'timeAdded': 1719297399376, 'timeStarted': 1759356263532, 'timeModified': 1759356263953, 'version': '1.0.12', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/pg3_inventory.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_2', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'node', 'executable': 'st-inventory.js', 'shortPoll': 300, 'longPoll': 600, 'allowIsyAccess': 1, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'bf792bfd-00e9-44c2-8399-ef547f9bbd88', 'noLicense': 0, 'latestVersion': '1.0.12', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.728 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '0c1e8d33-1ae8-456b-8e19-d4a50712e775', 'uuid': '00:21:b9:02:65:1c', 'name': 'Bluetooth', 'nsid': '40b26907-c607-4a7d-be8d-86d1776525b2', 'expires': 0, 'nickname': None, 'profileNum': 14, 'developerMode': 0, 'timeAdded': 1719297399379, 'timeStarted': 1759315220837, 'timeModified': 1759732609775, 'version': '1.0.7', 'edition': 'Free', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/bluetooth-1.0.7.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_14', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bluetooth.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'c0c55d0d-9fb8-472f-8099-271c2be07c75', 'noLicense': 0, 'latestVersion': '1.0.7', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.728 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '8a6bea85-6ccb-4cf4-b327-e85fa24720bc', 'uuid': '00:21:b9:02:65:1c', 'name': 'AudioPlayer', 'nsid': 'c582beed-644f-44c8-8145-d676b4f035fd', 'expires': 0, 'nickname': None, 'profileNum': 15, 'developerMode': 0, 'timeAdded': 1719297399383, 'timeStarted': 1759315220233, 'timeModified': 1759732609763, 'version': '1.3.7', 'edition': 'Professional', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/audio-player-1.3.7.pro.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_15', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'audio-player.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 600, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '10726ac8-0534-4ae5-b420-0ac193173365', 'noLicense': 0, 'latestVersion': '1.3.7', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.728 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'b0e96f94-9512-466f-b625-4ddf29d34b37', 'uuid': '00:21:b9:02:65:1c', 'name': 'Notification', 'nsid': '132e8dd7-e452-41dd-80f1-6a7da660f00b', 'expires': 0, 'nickname': None, 'profileNum': 3, 'developerMode': 0, 'timeAdded': 1719297699427, 'timeStarted': 1759315221090, 'timeModified': 1759732609789, 'version': '3.6.16', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Notification.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_3', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'notification-poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '94dd0ef7-6d1d-4c34-81bd-dcb87632c130', 'noLicense': 0, 'latestVersion': '3.6.16', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.728 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'bafc00c2-44da-47f9-9c84-0e5a749a99c6', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaEV2', 'nsid': '50dfa8d4-e3cf-4eb6-a4de-ffa59b84ed1d', 'expires': 1749513600000, 'nickname': None, 'profileNum': 4, 'developerMode': 0, 'timeAdded': 1733199479420, 'timeStarted': 1739322036051, 'timeModified': 1759185526932, 'version': '0.1.53', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-TeslaEV2', 'home': '/var/polyglot/pg3/ns/0021b902651c_4', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaEV2main.py', 'shortPoll': 600, 'longPoll': 7200, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '4d74d631-e454-48cd-8015-5b1b2b29b18d', 'noLicense': 0, 'latestVersion': '0.1.53', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.729 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'ca83ef2c-0c3d-44e1-a759-da87d9a1121c', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaPW2', 'nsid': '09a306c6-ba96-4ed6-8beb-e915947d826a', 'expires': 0, 'nickname': None, 'profileNum': 5, 'developerMode': 0, 'timeAdded': 1733543469307, 'timeStarted': 1759315221632, 'timeModified': 1759732609815, 'version': '0.1.30', 'edition': 'Standard', 'branch': 'main', 'url': '\thttps://github.com/Panda88CO/udi-teslaPW2', 'home': '/var/polyglot/pg3/ns/0021b902651c_5', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaPW2main.py', 'shortPoll': 300, 'longPoll': 1800, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '2866fa15-622e-4147-9436-a7051a13e261', 'noLicense': 0, 'latestVersion': '0.1.30', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.729 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'e0e6f8cc-28ee-455b-8ff9-7a89b1cae867', 'uuid': '00:21:b9:02:65:1c', 'name': 'BambuLab', 'nsid': 'e9d207b0-a165-40e9-b747-38eafa498f2d', 'expires': 0, 'nickname': None, 'profileNum': 9, 'developerMode': 0, 'timeAdded': 1756887683457, 'timeStarted': 1759315222679, 'timeModified': 1759732609728, 'version': '1.0.2', 'edition': 'Standard', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/udi-bambu-poly.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_9', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bambu_poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '6505bfd9-eae9-493c-bb18-f484a55166b8', 'noLicense': 0, 'latestVersion': '1.0.2', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.729 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '6067fdb0-ef35-4bcb-9906-8a30c2bf4439', 'uuid': '00:21:b9:02:65:1c', 'name': 'iox-matter', 'nsid': 'd193c79a-dcb1-427c-aabf-3efd5feb8f27', 'expires': 1775025189000, 'nickname': None, 'profileNum': 10, 'developerMode': 0, 'timeAdded': 1759300394762, 'timeStarted': 1759390244438, 'timeModified': 1759732609740, 'version': '1.3.0', 'edition': 'Standard', 'branch': None, 'url': 'https://pg3store.isy.io/v2/nodeservers/beta/matter.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_10', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'matter.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 1, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Beta', 'option': 'bda318b7-2bd7-47e1-a788-50c24c48979b', 'noLicense': 0, 'latestVersion': '1.3.0', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.729 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'f83d8020-b5bc-475a-8f2e-bddf164a55e5', 'uuid': '00:21:b9:02:65:1c', 'name': 'Hue', 'nsid': 'b8518958-ab70-4555-9d4f-a2da8df86122', 'expires': 0, 'nickname': None, 'profileNum': 1, 'developerMode': 0, 'timeAdded': 1759859313952, 'timeStarted': 1759959206733, 'timeModified': 1759959207699, 'version': '1.0.1', 'edition': 'Free', 'branch': 'huev2', 'url': 'https://github.com/exking/udi-hue-pg3.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_1', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'hue.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Beta', 'option': 'a3f28572-0cdd-43c4-a538-ccddf4de8e20', 'noLicense': 0, 'latestVersion': '1.0.1', 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.768 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom
2025-10-08 14:33:27.769 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom
2025-10-08 14:33:27.769 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2025-10-08 14:33:27.769 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot
2025-10-08 14:33:27.769 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot
2025-10-08 14:33:27.769 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}
2025-10-08 14:33:27.843 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode
2025-10-08 14:33:27.843 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode
2025-10-08 14:33:27.844 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS addnode message {'id': 'cebce479-5837-4acb-b568-75b61c363c30', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1759859325474, 'timeModified': 1759859325474, 'dbVersion': 1} from Polyglot
2025-10-08 14:33:27.844 Command udi_interface.interface DEBUG interface:_handleAddNode: add node response: {'id': 'cebce479-5837-4acb-b568-75b61c363c30', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1759859325474, 'timeModified': 1759859325474, 'dbVersion': 1}
2025-10-08 14:33:27.844 Thread-5 (start) udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot.
2025-10-08 14:33:27.844 Thread-5 (start) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving
2025-10-08 14:33:27.845 Thread-5 (start) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2025-10-08 14:33:27.851 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'installprofile': {'reboot': False}}
2025-10-08 14:33:27.851 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]}
2025-10-08 14:33:27.904 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom
2025-10-08 14:33:27.904 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom
2025-10-08 14:33:27.904 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot
2025-10-08 14:33:27.904 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot
2025-10-08 14:33:27.904 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}
2025-10-08 14:33:27.944 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2025-10-08 14:33:29.425 MQTT udi_interface.interface INFO interface:_message: Profile installation finished
It thinks it found your bridge at 192.168.1.46 - does this address look correct? Can you SSH to eisy and do like:
curl -kv https://192.168.1.46/api -d '{"devicetype":"polyglot#huev2", "generateclientkey":true}' -H 'Content-Type: application/json'
ideally you should see an error that button was not pressed:
[{"error":{"type":101,"address":"","description":"link button not pressed"}}]
Nope, not my right IP address. Here is a screenshot of my info.IMG_5742.HEIC
hope this helps.....
Well, I have great news. It worked perfectly had me push the button. I restarted it like typical and it populated everything I wanted to send you a screenshot of what I set in the settings because single hash marks will not work and I sent you the logs also to help you see what was happening in the background.
I'm gonna start programming my lights back in and see how they work and I'll get back to you if there's any issues or you can have me do any more testing as I beta test for Apple and a whole bunch of other people...
Thank you once again I hope you get your new unit soon also..... I was gonna be testing all my hue lights with my 8K Hue Sync but it just broke and signify it sending me a new unit. I wonder if one day it will allow me to tie that in to Insteon switches so I can have a switch thou enable and disable tracking of lights would be nice.
Cause when I watch TV, I like it having effects and my wife hates it and she would love to have a button so she could hit so she doesn't have to go in the hue app and turn it off and on
just a thought,
Gary
Screenshot 2025-10-08 at 9.57.36 PM.heic Hue_10-8-2025_75710_PM.zip Hue_10-8-2025_75711_PM.zip
just a thought,
Gary
Screenshot 2025-10-08 at 9.57.36 PM.heic 793.12 kB · 2 downloads Hue_10-8-2025_75710_PM.zip 65.37 kB · 0 downloads Hue_10-8-2025_75711_PM.zip 1.93 MB · 0 downloads
Oh, you're fancy.
